Several engine codes!! Please help! No one seems to be able to pinpoint issue - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 10-06-2019, 02:09 AM
lake325ci lake325ci is offline
Bim_brt
Mein Auto: 2004 BMW 325CI
Well I have engine codes present in my car as well as all around crappy running! 2004 325ci vert. 203k miles. I'm going to add a pic of all the codes lol. Much easier. The weirdest thing is that any time it's having it's "Episode" all I have to do is turn off engine and restart. All is immediately well. But only for a bit. And then it's just a I going repetitive cycle. My mechanic is dumbfounded cuz of the car resetting itself after restart. He camw up with the dme maybe faulty. So Monday morning I'm supposed to send off my dme to A company that's going to test and repair if necessary. 400 if repairs needed. Otherwise 80 for diagnostic Any thoughts?
ID:	867155   Click image for larger version
Old 10-06-2019, 04:51 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
The blind leading the blind.
You need access to BMW Test Plans©. A DTC code does not identify a broken part to be changed but identifies a symptom that may be caused by any number of failed components or adjustments to be differentiated among by the BMW Test Plan© guide through the fault tree.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 10-06-2019, 05:48 AM
Bim_brt
You need access to BMW Test Plans©***xfe0f;. A DTC code does not identify a broken part to be changed but identifies a symptom that may be caused by any number of failed components or adjustments to be differentiated among by the BMW Test Plan©***xfe0f; guide through the fault tree.
I understand what you're saying but really?? Blind leading blind?? Not very nice just because u probably have owned several bmws and know A LOT about them not everyone has so please take it easy and try and refrain from the smarty pants comments ***x1f642; thanks
So anywho, where do I gain access to this text plan
Old 10-06-2019, 06:58 AM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
How long does it run well before it starts running rough? Maybe itís happening when your car is changing from open to closed loop? Have you looked at fuel trims at all when running rough?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 10-06-2019, 11:57 AM
Bim_brt
Originally Posted by BabyUnicornTaco View Post
How long does it run well before it starts running rough? Maybe it's happening when your car is changing from open to closed loop? Have you looked at fuel trims at all when running rough?
I'll post what I got from scanning it
Old 10-06-2019, 12:00 PM
Bim_brt
As soon as I accelerate as to pass or just speed up rapidly it Happens. Also, during this time it also acts like it's not going to shift, which freaks me out cuz it gets up to like 6-6500 every time. Doesnt make sense to me
Old 10-08-2019, 08:52 PM
smolck's Avatar
smolck smolck is online now
ROLL TIDE!
Mein Auto: 2003 330ci (5 speed)
Personally, I'd replace the 02 sensor that is throwing the code p0133 since it is relatively cheap and easy. See if any change and then if it seems better, replace the other one too (pre-cat only). What is the maintenance history of the car?
Blind leading the blind maybe, but I've been around enough to say thats at least "A problem" even if it isn't "THE problem".
