Fog Light Question - Bimmerfest - BMW Forums
Old 10-06-2019, 05:00 PM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
Fog Light Question
So i'm replacing my fog lights about every year or two. I've been using the inexpensive (i.e. cheap) Philips H8 bulbs which are 35 watts. In searching for replacements i've found some Hella H8 bulbs that are 55 watts. Can i safely use these in place of the 35 watt bulbs?
I don't need super bright bulbs. Don't have much fog here to the point that I need fog lights. I do like to keep the fog lights on for better visibility of me to others.
Link to bulbs i'm considering:
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
2002 530i
Old 10-06-2019, 05:08 PM
CSMBlack-540i CSMBlack-540i is offline
Search, Read, THEN Ask
Mein Auto: CDN 98 540i M62 3.15
You can also consider buying 55w H11 bulbs and modifying the tab to fit the H8 socket. Did that on another car and still fine
https://www.driveaccord.net/threads/...h11-mod.81990/
Can google for H8 to H11 conversion for other DIY about altering the tab.
That's probably with the H8 55w is. A H11 bulb with the H8 socket.
Old 10-06-2019, 05:28 PM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: e39, e83, e60
something like this
https://www.amazon.com/Innovited-Lig...0404502&sr=8-3
Specializing In Breaking Things Professionally
15486372<-----
Old 10-06-2019, 07:07 PM
540 M-Sport's Avatar
Mein Auto: M550i, 540M-Sport, Scud
I would want to confirm with some that has run 55watt in the fogs...being plastic housings, there is the risk of melting something. Also, I can guarantee the 55watt H8s will last significantly less than the stock 35watt. I have used higher watt bulbs in several applications over the past 30 years and in all cases the bulbs had shorter life. I've come full circle and just use stock bulbs now. I even tried the HIR bulbs in the fogs...they had about half the life of stock and the brighter bulb didn't make for a useful improvement as the limitation is the reflector and lens.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 10-07-2019, 01:54 AM
Burning2nd's Avatar
Under the lift arms
I run a 55watt HID
15486372<-----
Old 10-07-2019, 07:34 AM
Thanks. I think I'll just stick with the 35 watt H8 bulbs but try a different brand. The fogs aren't hard to change but I would like to get more life.
2002 530i
Old 10-07-2019, 11:03 AM
Originally Posted by Burning2nd View Post
I run a 55watt HID
HID might be a practical upgrade as they typically have longer life than halogen. How is the performance? Do they make them where they don't require separate ballasts?
Old 10-07-2019, 02:39 PM
Burning2nd's Avatar
Under the lift arms
my ballasts are screwed to the inside of the wheel well
as far as separate ballasts, ive only ever seen them with ballasts,
and for longer life, ive never replaced a HID bulb
give it a shot.. its cheap and it works good
15486372<-----
