Magnitude of the P0128 code? - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 10-08-2019, 03:18 PM
McLarenBMW McLarenBMW is offline
Mein Auto: BMW E46 330Ci 5MT
How serious is this coolant thermostat code and how quickly should I replace it?
Old 10-08-2019, 08:40 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2003 330ci (5 speed)
Your tstat has “soft failed” in the open position. You wont reach full operating temp affecting fuel economy and likely wont get heat when it is really cold out. Beyond that, not super urgent but I wouldnt play around waiting too long. Cooling system issues and these engines are a potentially lethal (to your engine) problem.
Old 10-08-2019, 08:54 PM
Your tstat has "soft failed" in the open position. You wont reach full operating temp affecting fuel economy and likely wont get heat when it is really cold out. Beyond that, not super urgent but I wouldnt play around waiting too long. Cooling system issues and these engines are a potentially lethal (to your engine) problem.
Thanks, my car still reaches optimal temp but it takes a while for the needle to get to the middle
Old 10-08-2019, 08:57 PM
smolck's Avatar
ROLL TIDE!
Keep in mind, “middle” on the gauge can be anywhere from 160 degrees F to 225 or so, it is heavily buffered. If it was really cold outside, I bet the gauge stays left of center. They dont usually fail closed (causing an overheat) once they have failed open, but again, replacing it is cheap and easy, I wouldnt wait too long.
Old 10-09-2019, 10:14 AM
Keep in mind, "middle" on the gauge can be anywhere from 160 degrees F to 225 or so, it is heavily buffered. If it was really cold outside, I bet the gauge stays left of center. They dont usually fail closed (causing an overheat) once they have failed open, but again, replacing it is cheap and easy, I wouldnt wait too long.
You don't absolutely need to get a Wahler one, right? Aftermarket works too?
Old 10-09-2019, 10:23 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
I wonder why that is. Opening is by a wax-pellet linear motor that is more powerful than the shutting spring, itself quite powerful. When the engine is shut off and cools, the wax-pellet motor loses power and the spring becomes more powerful than the deenergized wax-pellet motor and shuts the thermostatic valve.
It's too bad that no one reliable has collected failure mode statistics.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 10-09-2019, 01:17 PM
smolck's Avatar
ROLL TIDE!
I have them fail closed and open on many cars. I didnt collect the data.
Old 10-09-2019, 01:18 PM
Can someone confirm if a Wahler is absolutely necessary or does aftermarket brand work as well?
Old 10-09-2019, 01:21 PM
smolck's Avatar
ROLL TIDE!
I’d go with Mahle, FCP has them on sale for $45 and a lifetime warranty. How can you lose? But Wahler works too, but dont cheap out and buy chinese garbage, not worth it.
Old 10-09-2019, 01:24 PM
I'd go with Mahle, FCP has them on sale for $45 and a lifetime warranty. How can you lose? But Wahler works too, but dont cheap out and buy chinese garbage, not worth it.
I'm Canadian, that Mahle is 80 bucks here. I got an aftermarket one on Amazon from Kimiss (whoever tf they are) and it looks high quality. Also not Chinese
Old 10-09-2019, 07:58 PM
smolck's Avatar
ROLL TIDE!
never heard of it. $80 for a proper thermostat is not bad. Taking chances with your cooling system is ill advised. Good luck
Old 10-09-2019, 08:17 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Get the proper thermostat. Mahle is the choice.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
