FSC Activation Code - Page 4 - Bimmerfest - BMW Forums
Old 10-29-2014, 09:50 PM
TokenMaster's Avatar
TokenMaster TokenMaster is offline
Token Master
Mein Auto: Coded F30
If I remember correctly, the command line tool accepts both binary and ****** encoded format. That's why I only use E-Sys and the exe. No SWID Reader nor front end required.
Code My Bimmer| FDL Coding Video Guide -Blogger/Youtube | EST Software Token demo | E-Sys Launcher Premium and PRO
Never download already patched E-Sys from Torrent sites
Old 10-30-2014, 03:44 AM
nobody_47's Avatar
nobody_47 nobody_47 is offline
Mein Auto: 530xD F11
In my case I am using a front end tool.
If I try to use just the exe it pops up for 0,5sec and than its gone.
I donīt have the right experience for that maybe
What is the command line tool?
Old 10-30-2014, 09:55 AM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
The fsc.exe program is a command-line tool.
You need to start a command-line window (cmd.exe) and the navigate to the directory where the tool is located and then type fsc.exe
Old 10-31-2014, 01:12 AM
nobody_47's Avatar
Thought so, but I guess it needs to be more than just fsc.exe.
Because I got this message out of cmd:
C:\Users\Username>nbt.exe
Usage: nbt.exe -DE_FSC filename- Map code (AppID)- hex Year code (UpgradeID) -hex> [<7 digit VIN>]
Is is right, that I also have to give the information about input filename, map code,... ?
Old 10-31-2014, 10:51 AM
FrogmanF30's Avatar
Correct, you supply the binary .fsc file, then the map region code, and then the map year sequence code.
For North American Premium (CIC) 2015-1 map, the region code is 0x2d and the sequence code is 0x09.
For North American NEXT (NBT) 2015-1, the region code is 0xa8 and the sequence code is 0x06.
The front ends provide the table with the region and sequence numbers.
For example; in this case the original poster, he would type (for Europe NEXT 2014-2)
fsc.exe D09374_000DE001.fsc 0xa9 0x05
Old 10-31-2014, 11:50 AM
nobody_47's Avatar
Thank you very much for the really great explanation
Now I understood how the command line tool works.
But I think I will stick on the front end version because Iīm not an expert for binary, hexadecimal and decimal.
Old 10-31-2014, 12:11 PM
Token Master
FSC.exe does require base 64 encoded file. NBT.exe can use either. I use the latter. FSC uses it too
Old 10-31-2014, 12:27 PM
ap90500's Avatar
ap90500 ap90500 is offline
Mein Auto: F30 320d xDrive -14
I have never tried, can nbt.exe create map fsc for cic?
Old 10-31-2014, 12:30 PM
nobody_47's Avatar
no, for CIC you need fsc.exe
Old 10-31-2014, 12:32 PM
ap90500's Avatar
Thanks.
Old 11-15-2014, 01:53 AM
sophus sophus is offline
Mein Auto: 2014 535d
Hi, can anyone tell me what this fsc is for?
AppID 170(0xAA)
Old 11-15-2014, 04:53 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
AppID 170(0xAA)
0xAA is Road Map NEXT Australia for NBT Head Unit.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 11-22-2014, 05:02 PM
mtl_bimmer mtl_bimmer is offline
Mein Auto: BMW 320i xDrive
Originally Posted by shawnsheridan View Post
Well, that is the basic idea, but only the tip of the iceberg.
When you got your SAT Radio FSC Code, you should have received 3 files:
e.g. xxxxxxx_006F0001.xml
e.g. xxxxxxx_006F0001.der (FSC Code Certificate)
e.g. xxxxxxx_006F0001.fsc (FSC Code)
E-Sys => Options => Settings => FSC Tab => Certificate Field:
Load FSC Code Certificate (e.g. xxxxxxx_006F0001.der)
E-Sys => Comfort Mode => FSC => FSC Field:
Load FSC Code (e.g. xxxxxxx_006F0001.fsc. The FSC Code file must first be Base 64 Decoded or else E-Sys can not read it. (Use B64Dec for Decoding - http://4mhz.de/b64dec.html).
FA Field: Select "Read FA" to use cars current VO.
Parameter Fields: (Example for Sat Radio FSC Code and CIC):
Diagnostic Address (hex) = 63 (99 in Decimal for HU_CIC; I think the same for HU_NBT)
Application Number (dec) = 111 (6F in Hexidecimal - In FSC File Name, e.g xxxxxxx_006F0001.fsc)
Base Variant = HU_CIC (CIC module name, e.g. HU_CIC, HU_NBT, etc.)
Upgrade Index = 1 (In FSC File Name, e.g xxxxxxx_006F0001.fsc))
Select "Upgrade FSC" to Import and Activate FSC Code.
Select "Check FSC Status", and you should see:
AppID 111
UpgradeIndex 1
SWTType SWTclassic full
FSCStatus accepted
FSCCertStatus accepted
Hi Shawn,
I followed these steps on an F30 to activate my Sirius radio and got the accepted messages on both FSCStatus and FSCCertStatus.
What do I have to do next? Shall the sirius option appear on my iDrive? Need to reboot iDrive or something?
Thanks a lot!
Daniel
Old 11-22-2014, 06:08 PM
Originally Posted by mtl_bimmer View Post
Hi Shawn,
Thanks a lot!
Daniel
You will need to modify your VO to change 693_PREPARATION_SATELLITE_TUNER to 655_SATELLITE_TUNER, and then VO Code the Head Unit (CIC or NBT).
Old 11-22-2014, 09:04 PM
Awesome! Just did it and it worked!!
Thanks a lot.
Old 11-22-2014, 09:10 PM
Thanks a lot.
Old 11-25-2014, 11:52 AM
jpcampa jpcampa is offline
Mein Auto: F31
I import 9c fsc code but when I check the status the certstatus is not avalaible.... I follow the instruccions but no way....
Any idea?
Old 11-25-2014, 11:55 AM
ap90500's Avatar
Did you load cert (.der) in esys settings?
Old 11-25-2014, 12:02 PM
Mein Auto: F31
yes
Old 11-25-2014, 12:04 PM
ap90500's Avatar
Did you select "upgrade fsc"? What is your istep? Please post a screenshot from esys fsc status.
Old 11-25-2014, 12:30 PM
Mein Auto: F31
yes I upgrade... Give me a couple of hours and I post the screenshots
Old 11-25-2014, 03:46 PM
Mein Auto: F31
finally works!!! The only that I need was let the car sleep a bit ***55357;***56842;. My car is a f31 with 606 navi, 05 2014 production... with 6ns and the new navi.... and works fine!!!
thanks to all... specially shawn...
Old 11-25-2014, 05:02 PM
Great, Glad to hear it.
Old 11-26-2014, 03:05 AM
larry_bml larry_bml is offline
Mein Auto: 320dA e90
Hello all, I have a problem with FSC code too. I upgraded software for an F10 2010 with ISTA/P 2.53.3 , and I had this problem : when ISTA starts to save data from car, it can not save all FSC code, and when finalizing upgrade and trying to write FSC to car, it couldn't write the FSC code for Voice Control and Satellite Radio (I think) . Anyway , any time I want to upgrade software for CIC head unit, some FSC codes can not be saved and rewritten to the car. And after upgrade some futures are unusable. Can someone give me some advice for this problem?
Off topic.
Shawn , can you please give me a link for latest PSdZData for Esys?
Thank you.
Old 11-26-2014, 09:17 AM
Originally Posted by larry_bml View Post
...Off topic.
Thank you.
PM sent.
