Coding Used EPS - Bimmerfest - BMW Forums
Old 06-11-2015, 05:00 PM
Antare Antare is offline
Mein Auto: F10 520d, E90 320i, E39
Coding Used EPS
Hi, EPS got water damaged and we bought a used EPS rack. Installed it and the car still gives out steering errors and disables power steering.
Checked that the part numbers and all are the same and I was wondering how to program the EPS from within ESYS? I would like to know how to do it in ESYS because I fear that ISTA-P might just brick the module.
Thanks in advance for any help
Old 06-12-2015, 02:53 AM
BMWzone BMWzone is offline
Mein Auto: F10 530d
You need a code EPS with Esys.
After connected car with enet-Choice your chassis-Expert Mode-Coding-Read FA-Activate FA-Read SVT-Go to EPS ECU-Detect CAFD for SWE-Choice CAFD
F10 530d 0911
Retrofit 223 245 248 2VB 2ND 316 337 3AH 4M5 416 ->451/488-->456 453 465 494 496 552 5AD 5AE 5AG NBT 654 FM2 610 620[CIC] 677 6NR 6WA & 6WB715 760 8TH[KAFAS2-FSC] KeyFOB Mperformance Gxx Series
Reset Kombi Gxx, Virginize VINs and Mileage
Old 06-13-2015, 12:39 PM
Will try this.
Old 06-13-2015, 01:44 PM
ac_schnitzer ac_schnitzer is offline
BMW user
Mein Auto: M550i
You need only VO EPS with your FA and everithing worked - tested on my Car 100% work dont need to flash ig but i suggest to flash it to have same I - level
Old 06-13-2015, 04:27 PM
ap90500's Avatar
ap90500 ap90500 is offline
Mein Auto: F30 320d xDrive -14
Yeah, vo-coding the EPS should be enough. I once coded one replaced EPS and it worked straight after vo-coding. There is one thing, servotronic. It is adaptive power steering force, and it is produced via software on cars with EPS. You must install original EPS FSC code, if you can. Limiting factor is production date of this donor EPS (if it came from a car with servotronic fsc). If this donor EPS is without servotronic FSC, then you can install repair FSC. Also if donor is older than original, then you can install repair FSC. If donor EPS is newer, maybe it is easiest to just remove servotronic from FA and code EPS.
Old 06-15-2015, 04:18 PM
Thanks for the help. I got my EPS coded and everything is working great! to everyone who helped.
Now to off to ode other stuff to the car
Old 01-13-2016, 10:03 AM
BMW-4-Life BMW-4-Life is offline
Mein Auto: 520d - manual - 2010
Hi guys, my F10's rack is worn out and I've bought a used replacement.
I have ISTA-P + D running OK over eNet cable ... but I'm waiting for my E-Sys token to be activated (some time in the next 48 hours) - so I can't use that for the moment.
Can I use ISTA-P to code in the replacement rack instead of E-Sys ?
The plan is to check that I have a compatible rack by plugging in the replacement and coding it in - before fitting it.
Many thanks.
Old 01-13-2016, 10:43 AM
Secret_Asian Secret_Asian is offline
Mein Auto: 535
no token needed for this step you can do it now
Old 01-13-2016, 01:01 PM
Thankyou, SA.
I'll give it a whirl.
Old 01-13-2016, 04:25 PM
Originally Posted by BMW-4-Life View Post
Thankyou, SA.
I think it's a pre-activation issue.
The installation guide says : -
"Since people have tried to exploit the generous free tool created by Token Master, he has implemented a
48 hour delay before the software can be used. It also will only function for 1 specific model, chosen by
chassis code, so be sure to set it correctly. Please see screenshots below:"
And I get the same "Abort" rather than "Launch now" option that the screenshot refers to.
The "Abort" option window auto-closes after 5 secs and E-sys opens.
And the "Connection via VIN" even shows the correct (ZGW) IP ... but the "Connect" button stays greyed out - regardless of what connection type is selected.
Looks like I'll have to wait the 48 hours.
But thanks for your input.
Old 01-18-2016, 08:28 AM
It turned out the PSZ data files were in the wrong location (garbled installation instructions).
So I've coded in E-sys to remember the last engine Start/Stop setting used.
And I've looked through some of the EPS FA settings - but I have no idea what to change to accommodate my (used) replacement rack !
Can it ALL be done in ISTA-P (rather than just the recalibratiion of the replacement rack) ?
Your kind help greatly appreciated.
Old 01-18-2016, 08:36 AM
I just re-read BMWzone's instructions - which I now understand, having used E-sys ... props and big thanks to you, BMWzone.
After connecting car with eNet : -
Expert Mode-Coding
Read FA
Activate FA
Read SVT
Select EPS ECU
Detect CAFD for SWE
Choose CAFD
Click Code
... and you'll finally be presented with a report in green font if coding was successful - or red if it wasn't.
Old 07-15-2016, 01:56 AM
The important thing when changing any rack is ensuring that the clock spring (which has an end-stop approx. 1.5 turns from centre in each direction) in the steering wheel remains in the centre position during operations.
Turning the steering wheel (unconstrained because it's disconnected from the rack) beyond the clock-spring's end-stop will break it.
The steering rack must also be in its centre position when re-mated to the steering column - or you risk breaking the clock-spring by taking it beyond its end-stop when turning the rack to full-lock.
Old 08-12-2016, 05:21 AM
Here's my old rack internals on video .... post-autopsy
Old 08-20-2016, 11:05 AM
atsapS atsapS is offline
Mein Auto: BMW
I got this at the moment:
F31 Pre Facelift with a used EPS motor installed because the original motors plastic cover was damaged by an accident.
Injected a caf file and vo coded the EPS module. Power steering still not working and now this is happening when the engine is on:
Only way to stop this is by shutting the engine off.
Anyone an idea?
Old 03-19-2017, 04:11 AM
fatfash fatfash is offline
Mein Auto: BMW X3 2012
I recently installed used EPS on my car, but tried VO coding but fails.On diagnosing ISTA/D says there is no power to the module which i have checked to be false. Does it have anything to do with the used steering rack i bought, because the donor rack is a 2017 model while my car is 2012. Any info/help will be highly appreciated.
Old 11-25-2017, 05:21 PM
DTKT DTKT is offline
Mein Auto: BMW E90 325
Hi, im having this same issue, did you resolve it now ?
Old 11-25-2017, 05:28 PM
32106865433
AT-steering box, electr.
5' F10 ***8195; (01/2009 06/2013)
5' F10 LCI ***8195; (08/2012 10/2016)
http://www.realoem.com/bmw/enUS/part...&q=32106865433
Old 11-25-2017, 08:02 PM
32106865433
Hi,
Can advise please,
My current steering rack original parts number is 32106864965, but checking with the new parts number base on my car vin, its has replaced with new parts number all with 2VL, and i have purchased and installed the one with 2VL to my car and its still dont work,
Old 11-25-2017, 11:54 PM
Is there power to the EPS?try turning the steering from right to left, if it turns freely fine, If not, check the B+ distribution box for broken fuse ? its on the passenger side of the engine compartment. The fuse to the EPS might be broken but there is a spare one in the same box. You will need to remove the cable supplying power to the EPS from the broken one to the spare. Also, ensure that all your power cables are well terminated. Finally you can get repair FSC code from user "acolt" for coding your new EPS with ISTA/P though you can still make use of the EPS without coding but you will always "drive rain malfunction" active while driving.
Old 11-25-2017, 11:58 PM
Check the link below to show you how the B+ distribution box looks like
https://www.ebay.com/itm/BMW-X3-F25-...item466b5a4b3a
Old 11-26-2017, 12:52 AM
Originally Posted by DTKT View Post
Hi,
Can advise please,
Have you tried coding the replacement rack in with ISTA-P or eSys ?
Old 11-26-2017, 01:49 AM
Yes, but no luck
Old 11-26-2017, 02:55 AM
I see ISTA-D ... but have you tried it with ISTA-P ? ... which offers you prompts to recode the ECU you choose.
eSys is a bit more hit and miss.
Old 11-26-2017, 03:09 AM
Thanks, i dont have ISTA-P, so cannot try it ,
Thanks again, will try to source for it
eps, f10
