Low Coolant Alarm - Bimmerfest - BMW Forums
Old 01-30-2019, 07:55 AM
rpickoff rpickoff is offline
Mein Auto: 2018 F33
Low Coolant Alarm
Got a message that the coolant level is low. Went away on restart. Level slightly low. Don’t see any evidence of leak. Anything to worry about?
Old 01-30-2019, 08:01 AM
Doug Huffman's Avatar
Nuclear engineer
Something to pay attention, trust and verify. Water coefficient of thermal expansion is quite small, IIRC 4%.
Old 01-30-2019, 08:33 AM
Autoputzer Autoputzer is online now
Mein Auto: 2014 535i + 2018 X3 30i
I keep a maintenance logbook on an Excel spreadsheet. I note the date, mileage, and volume of coolant added. When the consumption (ml/mile) starts to go up, I start worrying. My 535i with 56k miles was using about 200ml every 10k miles. But, the last top off was 200ml after only 3.5k miles. So, I'm checking it more often and starting to think something bad might happen soon. The usual prime suspect is the expansion tank, followed by the water pump.
Old 01-30-2019, 08:35 AM
Mein Auto: 2018 F33
It took about a quart. Last checked 10,000 miles ago.
Old 01-30-2019, 08:39 AM
That's high. But, don't expect them to do anything about it until you see a puddle.
When the low coolant message came up on the X3, it took 700ml to get it back to MAX.
Don't fill the tank up all the way to the top. It's an expansion tank, and you want room for the coolant to... well... expand.
Old 01-30-2019, 08:42 AM
Mein Auto: 2018 F33
Definitely no puddle in the garage. I don’t know that it was full 10,000 miles ago. Had the dealer service.
Old 01-30-2019, 08:44 AM
Mein Auto: 2018 F33
Bringing it in next Wed for 30,000 service. I’ll see what they say.
Old 01-30-2019, 08:55 AM
Nuclear engineer
Where does the gas air go when the coolant expands into the expansion tank?
Why doesn’t that hypothetical vent valve (and there is one) work for liquid as well as gas?
Old 01-30-2019, 09:04 AM
Nuclear engineer
Old 01-30-2019, 09:49 AM
ctorrey ctorrey is offline
Porleau
Mein Auto: 2017 BMW 340xi M-Sport
I've gotten a couple of warnings in my '17 340xi (8,500 miles) when it is very cold out (under 20 degrees). It's not due for routine service until June, so will just keep an eye on it.
ChuckieT
2017 340i xDrive | Mineral Gray | Coral Red Dakota | M-Sport | M Performance Power & Sound | ZCW | ZDA | ZLP | 2PE | 2VF| ZTP | 5DL | 5DP | 6CP
2017 X3 2.8 xDrive | Deep Sea Blue | Saddle Brown Dakota | ZXD | ZW2 | ZDA | ZLP | ZP3 | ZTP | 5DL
Gone, but not forgotten:
14 BMW 335xi F30
11 BMW 335xi E90
08 BMW 335i E90
05 Audi A4 3.0q USP
01 Audi A6 4.2q
98 Audi A4 2.8q
91 BMW 535i
87 BMW 325e
85 VW Rabbit GTI
Old 01-30-2019, 09:56 AM
ebs0712 ebs0712 is offline
Mein Auto: 2014 3 Series Wagon (F31)
[QUOTE=rpickoff;12892759]Got a message that the coolant level is low. Went away on restart. Level slightly low. Don’t see any evidence of leak. Anything to worry about?
Which motor do you have? 4 to 6 cylinder?
2014 328xi Wagon (F31)
2017 430xi Grand Coupe (F36) European Delivery
BMW CCA #257
Old 01-30-2019, 02:26 PM
Mein Auto: 2018 F33
[QUOTE=ebs0712;12892935]
4
Old 01-30-2019, 04:07 PM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
Expansion tanks can develop several micro cracks that slowly seep fluid. In my experience no puddle or stain developed but the fluid slowly disappeared. Replaced the tank and problem disappeared.
Old 01-30-2019, 04:11 PM
Mein Auto: 2018 F33
Even in the first 30,000 miles??
Old 01-30-2019, 06:04 PM
laser's Avatar
laser laser is offline
Mein Auto: 2007 S2000
Got the same low coolant warning on my 2017 330i ...... less than 20,000 miles ......
which led me to discover that I have two coolant fill points / two cooling systems.
Brought them both up to spec ....... doesn’t seem to be recurring.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2017 330i M- Sport Black Sapphire Metallic
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
Old 01-30-2019, 07:23 PM
Shon528's Avatar
Shon528 Shon528 is offline
Send a message via AIM to Shon528 Send a message via Yahoo to Shon528
Mein Auto: '16 GLE350
That last cold snap we had 2 weeks ago I got the low coolant msg several times, even once it said refill coolant. I took it into South Shore BMW and had them take care of it. They also refilled my washer fluid at the same time. I know adding coolant is easy enough you can do yourself but why not let them take care of it while under warranty. Create the paper trail so if something does develop later down the line, there's a history to it.
Boston CCA 383036
'17 340i 6MT, AW, LCL8, ZDA, ZCW, nav, adaptive suspension, MPPSK PCD 2/17
'19 MB GLS450 P1, 3-zone climate, lighting pkg, illuminated star & running boards, pano roof
Gone: '16 GLE350, '06 LR3 HSE, '14 320i 6MT ZSP ZPP ZLP ZCW PCD 5/14, '12 ML350 diesel, '11 Accord 5mt, '10 MDX, '08 Accord 5mt, '06 Xterra 6mt, '98 528i, '95 Mazda Millenia
Old 01-30-2019, 07:32 PM
TheAirman TheAirman is offline
Dave
Mein Auto: '18 330e
The "gas air" doesn't go anywhere. It stays in the tank. And automotive coolant doesn't "expand."
Plus the vent valve will work for both liquid and gas. Reach the pressure limit on that relief valve and anything sitting there will come out. That's why they tell you don't open the cap on a hot engine with your ugly mug in the way.
Dave
BMW CCA #67486
Old 02-01-2019, 07:48 AM
ams3141 ams3141 is offline
Mein Auto: '17 330e
I've been getting the same message, its only happened recently during the days where temps have been significantly below average. I'm thinking that might have something to do with it?
2017 330e- Mineral White, Coral Red, 18" 397 Wheels, Sunroof, Nav, Harmon Kardon
Old 02-01-2019, 09:54 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
Then what’s the purpose of the “coolant expansion tank”?
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
Old 02-01-2019, 10:40 AM
jummo's Avatar
jummo jummo is offline
False Enthusiast
Mein Auto: 2018 440xi. 2017 X128xi
This is interesting. My 440 has 20,000 miles and has been trouble free. It normally lives in a garage at home and at work. It camped out overnight last week ( temps below zero) and in the morning when started, the add coolant light came on. Since there was no puddle or evidence of leakage, I drove to work and parked inside. At the end of the day, when started, the light did not come on and the warning was gone.
When I got home, after allowing the car to cool, I checked the coolant and added a small amount. I did not measure how much was added, but it was only a little.
Everything has been fine since. The car goes in for service soon so I will ask and pass on anything I learn.
jummo
Sent from my iPad using Bimmerfest mobile app
"I know you were offended, but jummo's advice was sound."
Old 02-02-2019, 02:47 PM
Mike Pratl Mike Pratl is offline
Mein Auto: 2017 330i Sport Wagon
I had the same light going on when below freezing in the morning but was reset when leaving work from a heated parking garage. Then the temps went down to zero 2 weeks ago and an "enhanced" warning light go on so I filled a half quart. Everything's been fine since then and will have it checked in 5k when I hit 25K.
Old 02-04-2019, 04:52 PM
Jimfocus Jimfocus is offline
Mein Auto: 328ix/335ix
Last week I had to bring my wife to the airport. It was bitter cold (2 degrees). As we got to the airport the low coolant warning came on. At first I assumed it might be due to the extreme cold (heat expands/cold contracts, although water expands when it turns to ice, I don't know). When I came back out it took awhile but the warning came back on. It turned out to be a plastic fitting that connects the upper radiator hose to the top hose that goes to the expansion tank cracked and broke (again maybe brittle from the cold). I thought it would need a new upper radiator hose that includes the plastic connector with the fitting on it but it appears they fixed it with the smaller hose to the expansion tank. $268 for the hose, BMW coolant and purging the system at my corner garage. I think the sensors are very sensitive because I have used a pint of distilled water to make the light go away on past BMWs with no recurrence.
Old 02-04-2019, 10:43 PM
328DxVancouver 328DxVancouver is offline
Mein Auto: 2014 328dx
If the pressure is lower than the rating of the cap, it goes nowhere. It compresses as the coolant level in the bottle raises.
It does. If you fill your bottle to the brim and exceed the pressure it will come out of the bottle.
Even if the car said to fill it to the brim, i'm sure there is a built in air "cushion" somewhere in the system that you can't see
Old 02-08-2019, 02:05 PM
Mein Auto: 2018 F33
Just got the car back frm the dealer. Coolant level was LOW!! Found coolant leaking from clamp on hose to oil filter housing, coolant pipe not ‘snapped in’! WTF does that mean?
Old 02-08-2019, 02:16 PM
Mein Auto: 2018 F33
Similar Threads
Mystery Coolant Problem goldylox E85 / E86 Z4 (2003-2008) 13 10-29-2018 05:36 AM
Engine coolant low Premb F10 / F11 (2011 - 2016) 4 08-24-2018 05:26 PM
F36 - Low Coolant Warning Orleanth F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 2 05-01-2018 10:59 PM
Bleeding Coolant 2001E46 Do-It-Yourself H.Q. 2 08-04-2003 10:46 AM
