How to Retrofit a OEM Bluetooth TCU to your car - Page 29 - Bimmerfest - BMW Forums
Old 08-15-2019, 09:11 PM
PIFOUBMW PIFOUBMW is offline
Mein Auto: E65 745I 01/2004
You can use BMWScanner to modify the VIN of a ECU. Or you can flash it with the CAR VIN when you update the firmware.
Old 08-15-2019, 11:42 PM
simkard simkard is offline
Mein Auto: BMW 740d (e65)
Hello & Thanks for your answer,
I never flashed any module so I'm kind of noob on this side.
Can you please help me on that one ?
Thanks.
Old 08-26-2019, 06:24 AM
Can anyone help me out with that bluetooth TCU ?
I had one which I telecoded but couldn't answer from steering wheel ... and couldn't pair devices without using Tool32 to initiate the pairing.
The new TCU I received which is from a different part number has exactly the same behavior.
Any idea ?
Old 08-26-2019, 06:27 AM
jeepo23 jeepo23 is online now
Mein Auto: 2008 X3, 6 Speed
My TCU i have intermittent sound through my speakers. Some days it works, others it doesnt. The other person can hear me fine talking back etc. but I can't hear them..
Old 09-02-2019, 05:15 AM
Any idea ?
Can anyone help me please ?
I'm pretty sure I have to flash this module with the E65 bluetooth TCU firmware ... but I just don't know the steps to perform this task.
Old 09-03-2019, 09:56 AM
cimdahers cimdahers is offline
Mein Auto: BMW e65 730d
Use WinKFP.
Search how to flash. Even Youtube has a lot of videos.
The newer TCUs from other than e65 shall not support keypad. I had that issue and was wondering why, until I swirched TCU to older with the number matching e65
If You don't bother about keypad, just flash the module.
Caution, it can hang and brick your module, then Your audio will be inoperative until you close MOST loop break because of inoperative TCU.
Otherwise it takes about 40 to 45 minutes. Rather long...
Sent from my LYA-L29 using Tapatalk
Old 09-03-2019, 12:41 PM
Use WinKFP.
Thanks for your answer.
So actually the keypad will never work with that TCU module if I understand correctly.
Even if I manage to flash it with the E65 firmware ?
By any chance do you know what would be the fine I should flash into it ?
Thanks !
Old 09-22-2019, 04:45 AM
For information, the VOICE Module SVS can work with retrofit TCU but you have to disable the Voice Recognition with NCSEXPERT in the TCU module or it doesn't work. I accidentaly found this working solution and now my SVS is perfectly working !
Old 09-22-2019, 09:04 AM
B11NOV B11NOV is offline
Mein Auto: E65 730D
Thank you for the information, I have just checked my car, and VR in TCU is not ative, SVS is still not working properly.
I think that's because we have different TCUs.
