Leaking sunroof - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > G32 6 Series Gran Turismo (2018 - Current)
The all new 6 Series Gran Turismo follow in the footsteps of the F07 5 Series GT. Arriving in dealerships this fall the 6 Series GT offers 5 Series sizing with 6 Series styling.
Old 08-19-2019, 01:16 AM
Kwambus Kwambus is offline
Mein Auto: BMW 630GT Sport XDrive
Leaking sunroof
Hi,
I own a 2018 630GT and the sunroof leaks water after spells of rain. When I open the roof the netting (wind break) that pops up at the front is usually wet or damp to the left and right corners and on dry days the smell of tepid water permeates the cabin.
The car has only done 6,000 miles and is under warranty BMW replaced the sunroof but after only two weeks the problem has re-occurred.
Second issue with the mechanism is that more often than not the glass roof fails to close as it hits the spring loaded bar of the wind break and returns back to open. Seems after some testing this happens less when the engine is running, possibly receiving more power?
Just wondered if any of my fellow 6 GT drivers have had anything similar?
Old 08-25-2019, 11:13 AM
Gilgorm Gilgorm is offline
Mein Auto: 2018 640i X-drive GT
Originally Posted by Kwambus View Post
Hi,
It seems that BMW may have replaced your sunroof for nothing. I don't know exactly where they are but all sunroofs have drain holes in the body that allow water to drain away. Yours sound like they are blocked/plugged possibly by leaves or other debris. Hopefully they did get rid of the smell. I haven't experienced your problem. I believe some 5ers had issues with the way the car was parked. Mine sits on a slight slope with the front end low. Leaves are a constant problem.
Regarding your second issue, I had the same problem. As soon as the glass hit the wind deflector the glass would partially reverse. Holding the switch or putting my hand up to partially pull down the deflector did the trick.
I opened the roof and put a tiny amount of thin oil on the runner where the glass slides up onto the deflector. That partially solved the problem then with use it resolved itself. Only one of us uses the roof so it was infrequent (only 7500 km). I suspect the spring is over engineered and needs to be broken in with use. Works perfectly now.
Good luck
p.s. my sunroof was only closed when the car was running.
Did you have the same problem with both the old and new roofs?
2018 640i X-drive GT; Alpine White, Black Nappa, Piano Blk; M-Sport, Premium (Ceramic, Sirius, Soft-close, Ventilated & Massage Comfort Seats, Surround, Sunshades, Parking Ass't), Advanced Driver Ass't (Lane Keep, Evasion Assist, Steering & Lane Control, Cross Traffic, ACC with Stop & Go), Smartphone, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i, 12 535i X-drive
Old 08-25-2019, 12:34 PM
Sophisto Sophisto is offline
Mein Auto: E46 330ci / G32 630d
Do not buy a BMW with a panorama roof.
Far too much trouble with these, you'll find plenty on the divers forums.
Glogged drains are the common problem.
Thousands of dollars on damage are not seldom.
Don't ask me how I know...
Old 08-25-2019, 01:10 PM
Thank you both for taking time out to reply.
Gilgorm -
On this latest occasion my dealer contacted BMW Munich and they advised that the wind break should be replaced, to remove the smell of tepid water/damp. This has cleared the smell for now.
The engineer who performed the work advised me that he had camera inspected the drainage channels and there was a brown deposit blocking the driver side channel. Along with that the rubber outlets for the channels which exit near the forward door hinges had some issue. He has corrected these faults and asked me to see how it goes.
I park my car on a drive also which results in the front of the car being slightly higher than the rear - as I reverse onto the parking area. Interesting you mention leaves as there are none over or above the car but I have noticed leaves in the area at the top of the bonnet, below the windshield. I am wondering if this drainage channel is shared with the sunroof. Would explain the brown residue the engineer found in his inspection. Will try and keep that cleared out from now on.
Sophisto -
I had two 5 series tourings that had panoramic glass previous to the GT and never had an issue with those. I will keep this experience in mind with future purchases though.
Overall I love my 630GT it's a fantastic car and I am enjoying it, even the styling has grown on me! Only other issues I had have been squeaks and rattles. Glovebox persists with annoying rattle now and then. I guess the fact that it's a newly designed car means a lot of the niggles will be ironed out with revisions.
Thanks again for your feedback.
Old 08-25-2019, 02:30 PM
I BELIEVE MUD, SALT DEPOSITS AND EVEN FACTORY RUSTPROOFING CAN CLOG THESE OUTLETS.
I ALSO BACK IN BUT END UP WITH FRONT LOWER THAN BACK. NEVER BEEN IN A GARAGE.
UNSURE IF THEY ARE SHARED BUT THEY EASILY CLOG. I OFTEN USE A VACUUM WITH A "SNOUT" TO EITHER CLEAR THEM OR BLOW THE LEAVES OUT. I TOO DO NOT HAVE ANY TREES ABOVE ME BUT THEY ALWAYS FIND ME.
I LOVE MY 640iX GT. CANADIAN CARS CAME FULLY EQUIPPED BUT COST A LOT. NO PROBLEMS OF ANY KIND SO FAR. JUST HAD A LONG TRIP AND FOUND IT TO BE INCREDIBLY COMFORTABLE. UNFORTUNATELY, SALES ARE LOW SO THEY HAVE BEEN DISCONTINUED IN CANADA AND U.S. NOT SURE ABOUT EUROPE. CAR IS VERY RARE IN TORONTO.
Good luck with your problem.
HTML code is Off
