2018 Alpina B7 spare wheel options - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - G11 / G12 (2016 - current)
The next generation G11/G12 BMW 7 Series flagship forum. Unveiled June 10th, with production starting in August the 6th generation 7 Series comes in a light weight package with extensive use of BMW i carbon fiber technology. The interior quality raises the bar with a touch screen and gesture controlled infotainment system. Exterior styling has been a sticking point with mixed reviews so far.
Old 06-22-2019, 12:20 PM
paul.j.ghosh paul.j.ghosh is offline
Mein Auto: 2016 750ix
The Alpina B7 has larger brakes from what I understand and the 18" space saver spare will not fit. BMW does not appear to provide an option for a spare wheel. So, I started researching wheels for specifications such as ET, width, center bore size, bolt pattern and diameter. I discovered that some Mercedes models have similar ET and identical bolt pattern and hub size. I think the following should work if the calipers can clear a 19" wheel. The numbers match up better than with the 18" space saver spare. What are your thoughts?
OEM tire: 245 45 19" wheel: 8.5" ET 25 bore 66.6 bolt 5x112
spare tire: 155 70 19" wheel: 5.5" ET 13 bore 66.6 bolt 5x112
OEM spare
Diameter 703.1mm 699.6mm
Circumference 2208.9mm 2197.9mm
Poke 83mm 56.9mm
Inset 133mm 82.9mm
Speedo error 0% 0.5%
Reading at 30mph 30mph 30.15mph
Reading at 60mph 60mph 60.3mph
Ride height gain 0mm -1.75mm
Arch gap loss 0mm -1.75mm
calculations from: https://www.willtheyfit.com/index.ph...5-5&offset2=13
Old 06-22-2019, 12:26 PM
AlteBMW's Avatar
AlteBMW AlteBMW is offline
bimmerfest Supporting Member
Mein Auto: 2020 750ix 2019 X3 30
Originally Posted by paul.j.ghosh View Post
The Alpina B7 has larger brakes from what I understand and the 18" space saver spare will not fit. BMW does not appear to provide an option for a spare wheel. So, I started researching wheels for specifications such as ET, width, hub size, bold pattern and diameter. I discovered that some Mercedes models have similar ET and identical bolt pattern and hub size. I think the following should work if the calipers can clear a 19" wheel. The numbers match up better than with the 18" space saver spare. What are your thoughts?
OEM tire: 245 45 19" wheel: 8.5" ET 25 hub 66.6 bolt 5x112
spare tire: 155 70 19" wheel: 5.5" ET 13 hub 66.6 bolt 5x112
OEM spare
Poke 83mm 56.9mm
Inset 133mm 82.9mm
I think it is worth a call to Tire Rack, who are very knowledgeable about what fits what. I can't comment further and I would not rely on anyone's answer here.
BMWCCA since '88
'20 750i xdrive. Azurite, Cognac,
'19 G01 X3 30
Other: '14 MB E350 wagon
Past: 3 (F31, others), 5 (E39, E61 and F10), 7 & 8 series (twice!) BMW, C, E and S MBenzes, Alfa Romeo GTV, MGB, Toyota Celica, Lincoln, Saab, Volvo, Audi A6, A4, and others (even a Nash Rambler)(yes I am old )
Old 07-02-2019, 04:28 PM
jettie1767 jettie1767 is offline
Send a message via AIM to jettie1767 Send a message via Yahoo to jettie1767
Mein Auto: 2012 BMW M6
How are you going to fit that in the trunk? There's no space for it.
Current stable:
'18 BMW Alpina B7 Alpina Blue
'17 Toyota Prius Prime Plus Millenium Silver
Old 07-12-2019, 10:25 AM
Falcon900Easy Falcon900Easy is offline
Mein Auto: M760, GT-R, S63, Mk7 GTI
Our B7 has runflats now but when I replace them I will buy the mobility kit.
Old 07-14-2019, 07:43 PM
Is your B7 on 20s? Thought those weren't runflats. My car is on 21s and they are not runflats.
Current stable:
Old 07-15-2019, 05:42 AM
21's, I think they are runflats because the car did not come with a spare or mobility kit. I will have to check again.
