Coolant Leak - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - G11 / G12 (2016 - current)
The next generation G11/G12 BMW 7 Series flagship forum. Unveiled June 10th, with production starting in August the 6th generation 7 Series comes in a light weight package with extensive use of BMW i carbon fiber technology. The interior quality raises the bar with a touch screen and gesture controlled infotainment system. Exterior styling has been a sticking point with mixed reviews so far.
Old 07-04-2019, 05:51 AM
DavidR DavidR is offline
Mein Auto: Z4
Coolant Leak
Experienced a coolant leak in my 2016 750i xdrive at 37,000 miles. Still under factory warranty. Dealer did a system pressure check. Found coolant leaking lines for turbocharger leaking. Fix: Replaced all turbocharger coolant lines with both brackets. Refill and bleed system. Just a heads up that you may want to get a system pressure check.
