Road noise!!! - Page 2 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - G11 / G12 (2016 - current)
The next generation G11/G12 BMW 7 Series flagship forum. Unveiled June 10th, with production starting in August the 6th generation 7 Series comes in a light weight package with extensive use of BMW i carbon fiber technology. The interior quality raises the bar with a touch screen and gesture controlled infotainment system. Exterior styling has been a sticking point with mixed reviews so far.
Old 03-31-2017, 11:59 PM
HRPOWER HRPOWER is offline
Mein Auto: BMW
17 plate!
Someones got some money!
Maybe roads in US are way nicer. Or in 17 they fixed it!
Old 04-02-2017, 11:28 AM
metrathon metrathon is offline
Mein Auto: 328i, 750Li, A4 2.0T
I'm obsessed with NVH. I would have bought a Lexus LS if not for the 90's engine, so I ended up with F01.
The road noise was greatly improved when I swapped the horrendous OEM 20" Continental Excellence RFT for 20" Yokohama Advan Sport non-RFT. Impact and rolling noise are much more subdued now.
The wind & ambient noise is BMW signature. BMW doesn't use double pane / laminated glass like Lexus does, so my F01 is way noisier in that respect than my ex Lexus GS. From what I understand the same is true for G11/12, still no double pane glass.
There are so many reasons why the 7 Series NVH opinions are so diverse:
  • Type of roads you drive. Smooth asphalt vs concrete slabs.
  • Lack of perspective. If you only drove noisier cars, the 7 will seem very quiet.
  • Environment. Wind direction, wet roads, etc.
  • Shoes. Stupid OEM RFT vs quiet non-RFT aftermarket.
  • Driving style. Stereo volume, speed, windows down, etc.
  • Attention. Same car I consider very noisy, my wife is absolutely fine with it.
Current: 2014 BMW 750i | 2015 Lexus RX 350 | 2014 Yamaha FZ-09
Gone: 2015 Lexus GS 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2001 BMW 530i | 2004 BMW 530i | 2004 BMW 520i | 2003 Opel Vectra | 2002 Citroen Xsara
Old 07-26-2019, 05:52 AM
Mein Auto: BMW
A man in the tyre shop told me not to change the run flats on my G11 X Drive because it might ruin the 4WD and or the AIR Suspension
This is surely nonsense right?
Still trying to find someone on the world wide web who has done the G11 Run Flat dump.
Old 07-26-2019, 06:40 AM
AlteBMW's Avatar
AlteBMW AlteBMW is offline
bimmerfest Supporting Member
Mein Auto: 2020 750ix 2019 X3 30
If you search this forum, you will find many people who swapped out RFTs. Most are happy. Obviously need a solution in case of a flat.
BMWCCA since '88
'20 750i xdrive. Azurite, Cognac,
'19 G01 X3 30
Other: '14 MB E350 wagon
Past: 3 (F31, others), 5 (E39, E61 and F10), 7 & 8 series (twice!) BMW, C, E and S MBenzes, Alfa Romeo GTV, MGB, Toyota Celica, Lincoln, Saab, Volvo, Audi A6, A4, and others (even a Nash Rambler)(yes I am old )
Old 07-26-2019, 08:26 AM
LKBimm100 LKBimm100 is offline
Mein Auto: 2017 BMW 7 Series
Yes, it's nonsense. I replace the run flats every time I get a new 7 series. I do this every three years because I lease. It's never a problem and it makes a big difference.
Old 07-31-2019, 08:56 PM
Rockland Rockland is offline
Mein Auto: 2017 BMW 750i
I might have been tempted to swap out my tires but I got two flat tires in past 4 months. The convenience of being able to drive my car around and not have my life stopped wins out.
Old 07-31-2019, 10:08 PM
I have had non run flat tires on my 7 series for the last 9 years. Not a single flat tire. But I also have the mini spare option just in case.
Old 08-01-2019, 11:29 AM
TL2E90 TL2E90 is offline
Mein Auto: 2018 BMW 750Li
Although my car runs on RF tires I have to admit this is the quietest car I have ever driven. The OP should take his car back to the dealer. Sometimes simple things like defective weatherstripping can generate road noise inside the cabin.
Old 08-01-2019, 11:34 AM
The newer run flats are better than they used to be but they are still a lot noisier than non run flats, especially as the tires wear down. When you switch to non fun flats its even quieter and smoother ride. Definitely worth it if you are sensitive to road noise and ride smoothness.
Old 08-02-2019, 04:48 AM
cracker123 cracker123 is offline
Mein Auto: E350
Big difference after switching out my 21" RFT to Mich Sport 4 Non RFT. Also applied Honda Shin Etsu Grease to all the door rubber seals which made a difference as well. Seals are one thing people forget to treat since they loose their performance over time.
Old 08-02-2019, 02:55 PM
shafeeq's Avatar
shafeeq shafeeq is offline
Mein Auto: 2015 X5 35d
This is such a good idea. Thank you! Iíll have to try it as Iím definitely one of the people who think this car is entirely too noisy.
Old 08-02-2019, 04:47 PM
A8540TDI's Avatar
A8540TDI A8540TDI is offline
Mein Auto: M Roadster,740i,Tesla 3SP
I have a 2019 740i and find that it is very quiet most of the time. Road surface is definitely a big factor in road noise as the car will glide along serenely on newer surfaces but sometimes has significant road roar on worn surfaces. Tire type and wear also contribute to the overall noise issue. I'm somewhat surprised how well the car rides on 20" wheels with Pirelli P Zero RFT's only occasionally do I notice shock tremors that I think are a result of the low profile tires. I have access to a set of stock 18" wheels with Michelin RFT's and I may swap them to see if there is significant difference. Note: BMW tire pressure recommendations for the USA are based on full load plus cargo, a condition I almost never have. In Europe, the recommended pressures are significantly lower for light loads, so I run my tires 5 psi below BMW's USA recommendation, that makes a huge difference in ride comfort.
Old 08-05-2019, 09:49 PM
Epiplatys Epiplatys is offline
Mein Auto: BMW 750 2012
I'll give a different perspective: bought a 2019 ram 1500 a few weeks ago to haul my dirtbikes. And I have to admit, the road/tire/wind noise is almost non-existent on the truck. And we are talking about an American truck, where body panels don't line up, fit and finish is a bit of a joke. But it is considerably better suspended and isolated. Going back and forth between my G12 and the RAM feel a bit weird, and you keep thinking "what the ....".
But to contrast the suspension and body isolation qualities, the engine/exhaust noise on the RAM is pretty bad, and in a bad way. The audio system is a joke.
So it clearly demonstrates that the road noise can be effectively dealt with, and the G12 lacks, a lot in this department.
BMW M760Li 2018 | BMW M850i 2019 | RAM 1500 2019 | Mercedes SL500 1998 | Mercedes S500 1996 | Diamond DA40 XLS 2012
Old 08-06-2019, 01:49 AM
Well, the good news is that the 2020 is supposed to add increased insulation to dampen noise in the C pillars. So that would go a long way to increasing the quietness of the car. I agree it could be better for sure.
Old 08-06-2019, 12:29 PM
Mein Auto: E350
I wonder if it is easy to add this insulation in our cars
Old 08-07-2019, 05:38 AM
shafeeq's Avatar
A big reason for the reduced road noise coming from a pickup truck is that youíre quite a bit higher off the ground vs. a 7 Series.
I experienced a similar situation hopping between the X5 and the 750.
Old 08-07-2019, 06:08 AM
AlteBMW's Avatar
You don't hop between an X5 and a 750. You walk gracefully.
BMWCCA since '88
'19 G01 X3 30
Old 08-07-2019, 06:18 AM
Maltesefalcon Maltesefalcon is offline
Mein Auto: 2011 535i xdrive
Sure. Just go to Home depot and get a few cans of expanding foam and spray it in every hole you find.
Old 08-07-2019, 06:40 AM
shafeeq's Avatar
Itís actually more of a pimp strut! Lol
Old 08-08-2019, 05:55 AM
Mein Auto: E350
Automotive foam might be better
Old 08-08-2019, 05:56 AM
Mein Auto: E350
This is such a good idea. Thank you! I'll have to try it as I'm definitely one of the people who think this car is entirely too noisy.
The grease gets all over the body when the doors close, I would wipe it down with alcohol after a week. Don't use alcohol on the rubber seals just areas around it.
