P2096 Error Code at 52k miles (2012 F02( - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 01-22-2017, 06:22 AM
bpddaddy bpddaddy is offline
Mein Auto: 2001 740i, 2012 740li
Has anyone had success in clearing this code? Is it a bad gas cap? Has the Oxygen Sensor actually gone bad so soon?
P2096
Post Catalyst Fuel Trim System Too Lean Bank 1
Thanks...Brently
Old 01-22-2017, 12:37 PM
juice80 juice80 is offline
Mein Auto: 750i
Could be a bad 02 sending a bad signal, gas cap would be the cheapest fix but might be worth getting it properly diagnosed, you can swap 02 sensors and see if it follows.
Old 01-23-2017, 09:30 AM
Thank you for the advice. Filled up the tank and code went away. I'm guessing it's the gas cap. I'll start there and let you all know what happens.
Old 04-24-2017, 02:39 AM
Code continues come back after clearing. New plugs and coils installed (needed at 56k) and still throwing code. Investigation continues but now looking at 02 sensors, MAF and Fuel Injecetors. I may end up taking it to the dealer since I don't have time to diagnose.
Old 08-23-2019, 01:07 PM
rafiqi rafiqi is offline
Mein Auto: 2006 e65
Hi...Just had the same code ...Hard missfire...Did you ever figure it out?
Thanks,
Raf
Old 08-23-2019, 07:24 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
It is most likely a vacuum leak, somewhere on the engine. A smoke test is the easiest way to find the problem.
