04 went down - Bimmerfest - BMW Forums
Old 01-15-2019, 02:57 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
04 went down
Yesturday 04 went down on the wife today while at the grocery store...by time I got home in the evening...she kicked over...wife drove her back home 5min drive.
I suspect the bat. Not being fully charged. Bat. Discharged while at the shop charging the compressor a week ago. With the little driving my wife has done since, it mostly was not enough to fully charge the bat. Instead of changing out the bat. I'll drive her around making runs today
06 X3 199k
05 X3 181k
04 X3 162k
[FONT="Arial Black"]
Old 01-18-2019, 09:51 PM
BeeemerBro
06 X3 199k
05 X3 181k
04 X3 162k
Turns out the problem was the loose positive cable under the hood....tightened that sucker and 04 kicked right over. Click image for larger version
Sent from my SM-J727T using Bimmerfest mobile app
Old 01-19-2019, 03:08 AM
Doug Huffman's Avatar
Nuclear engineer
Turns out the problem was the loose positive cable under the hood...Attachment 836589
The corrosion blistering out of the side of the connector is the same problem as rotten ground straps cause. That will be a problem sooner or later.
Old 01-21-2019, 04:38 AM
BeeemerBro
Went to top off the oil for the "04" there on the dash the airbag light fault code 04. (passenger seat sensor) i was hoping it would go away...they don't! I tried to erase with scanner.
At least it could have waited until I got the same problem fixed at the dealer for 06.
Also the airbag recall was applied to 04 in 2009
(I asked about 04 history last week when at the dealer)
Question: Does the recall coverage apply for only one fix per car?
06 X3 199k
05 X3 181k
04 X3 162k
Old 01-21-2019, 07:48 AM
kind16 kind16 is offline
Mein Auto: X3
06 X3 199k
05 X3 181k
04 X3 162k
Call bmw dealer for answer is better.
2010 X3 28i Black, Engine N52B30 AT
(Millage Sep2019-112K km)
2015 Dodge Caravan, AT
(Millage Sep2019-30K km)
Old 01-24-2019, 02:46 AM
BeeemerBro
Turns out the problem was the loose positive cable under the hood....tightened that sucker and 04 kicked right over. Attachment 836589
errrr....that's not it! the wife informs me that...she had problems yesterday at work where 04 did not start...she turned off all accessories and 04 then started...man I could have sworn that battery is maybe 2 years old... well back to Sams.
Old 01-24-2019, 06:57 AM
540er's Avatar
540er 540er is offline
e30MPG
Mein Auto: E30mpg
check for parasitic draw too
2002 M3 Cic / Topaz Metallic Blue
1998 540iA / Orient Metallic Blue SOLD
1989 635csi/ R.I.P
1986 325es/5 speed R.I.P
1999 328ic/5 speed (New)
BMWCCA Member #366681
Old 01-24-2019, 07:17 AM
BeeemerBro
Yeah...Was hoping that's not the case...maybe Sams will give me a replacement...I'm using another battery and we'll monitor the proformance for the next couple of days.
Sent from my SM-G386T using Bimmerfest mobile app
Old 01-24-2019, 07:29 AM
tsuintx tsuintx is offline
Mein Auto: 2012 K1600GTL Premium
Welcome to the world of parasitic draw on these things. Fun stuff...
Still haven't figured out why it keeps happening on my daughter's 06. Didn't really see much of a draw to begin with when I measured it with my MM, so go figure. I did pull the sunroof fuse, the connector to the sunroof switch as well as the connector to the bluetooth module in the trunk. So far so good, but she hasn't had it sitting unused for much more than a day yet...
Official mechanic of my daughter's 06 X3 (Chronicled here.)
Plus a bunch of others...
Old 01-24-2019, 08:10 AM
540er's Avatar
e30MPG
Mein Auto: E30mpg
https://www.pelicanparts.com/techart...eplacement.htm
I found FSR unit stayed on even after car is shut off and was draining my battery.
1989 635csi/ R.I.P
Old 01-24-2019, 09:09 AM
BeeemerBro
How can I check it?
Old 01-24-2019, 09:35 AM
540er's Avatar
e30MPG
Mein Auto: E30mpg
How can I check it?
https://www.bimmerfest.com/forums/sh...d.php?t=716322
1989 635csi/ R.I.P
Old 01-24-2019, 09:41 AM
Closem Joe Closem Joe is offline
Mein Auto: locally
Thanks for the info. BB! If it ever happens to me that's where I'll check.
Joe
Old 01-24-2019, 11:26 AM
44 Cents's Avatar
44 Cents 44 Cents is offline
Mein Auto: X-3
Last time my battery got "low", it seemed to hit some threshold and all kinds of odd ball electrical things started happening. The oddest event was when the car was completely off, it kept calling the SOS bmw thing...the SOS button stay illuminated and the radio kept saying "calling bmw". The raido itself wouldnt shut off no matter what I did and the key fob wouldnt lock/unlock the doors. I ended up taking the battery out and trickle charging it and when I put it back in I guess I got lucky because nothing has happened since and its been about 4 weeks or so. BTW, that picture of the cable under the hood doesnt look all that bad really...talk about a system being sensitive.
Fixed so far with help from here- plugs, coils, actuator gear, changed transfer case and diff fluid, replaced coolant reservoir/hoses, fixed pano roof, replaced windshield molding, replaced one/cleaned vanos solenoids, aux fan, VC, DISA, upgraded rotors and pads and numerous other little things like changing oil, cabin filter etc. Easily $6,000 savings vs dealer. ... BMWs lack DNA and viruses so I have no clue what Im doing.
Old 01-24-2019, 11:58 AM
BeeemerBro
Right...right!
06 X3 199k
05 X3 181k
04 X3 162k
Old 01-24-2019, 01:17 PM
44 Cents's Avatar
Mein Auto: X-3
Right...right!
06 X3 199k
05 X3 181k
04 X3 162k
My car was actually prank calling BMW. I almost didnt want to stop her. It almost made me think of what happens when people experience "lack of oxygen" and start doing weird shet. Like Herby the love bug got into the neighbors cigar box that had the ganja stashed in it. I went outside and next to the car is 4 empty bags of Cheetos, a half eaten ding dong and broken bottles of Yohoo everywhere.....and the Z-4s bumper bra from down the street is laying in a pile in the lawn.
Old 01-25-2019, 05:18 AM
BeeemerBro
04 Wouldn't start again for the wife last night after work...I had to jump it again. That morning I put in a supercharged bat. Off my car...heck the bat. that was in her car 04 was just off an overnight charge...that's two bats now!
Solution....*new alternator that's got to be it...I'll check the connections today!
Got to take Rescue Red back to the dealer to rework the passenger seat airbag recall. Got to order/ replace alternator for 04. Got to change the oil for 05 and 04...and who's on first...How do you like me now!
06 X3 199k
05 X3 181k
04 X3 162k
Old 01-25-2019, 05:31 AM
BeeemerBro
Duracell tested good needs a charge...got that battery on 8/16
it's now 1/19...
that's like 30mos ago.
Sams wouldn't switch it out...
06 X3 199k
05 X3 181k
04 X3 162k
Old 01-25-2019, 05:37 AM
BeeemerBro
06 X3 199k
05 X3 181k
04 X3 162k
Airbag light did go away with a newly charged battery installed...hoping it was a false alarm.
06 X3 199k
05 X3 181k
04 X3 162k
Old 01-25-2019, 06:22 AM
Mein Auto: locally
it's now 1/19...
06 X3 199k
05 X3 181k
04 X3 162k
BB, sometimes they last 6 years and sometimes not! Have the battery tested and if not so hot, get a new one and stop jerking around! It will be better for your overall health.
Joe
Old 01-25-2019, 03:36 PM
BeeemerBro
Joe
Gotcha...wife says the same thing...but get this car started this morning, then now at the end of the day just sitting all day...it starts with no problems...on the first crank as it always does!
Old 01-26-2019, 07:47 AM
BeeemerBro
So somehow this nut is getting loose. Last night 04 wouldn't start while I'm on a test run...I sit in the car trying to figure what's the problem and again I open the hood and find the this nut is loose. I finger tighten it again and 04 fires right up...(Great I don't have to walk home in 50 degree cold weather) But just before closing the hood I noticed in the night's darkness...SPARKS are shooting from this point underneath the loose nut! I investigate this morning!
Old 01-26-2019, 10:51 AM
44 Cents's Avatar
Mein Auto: X-3
Nut sparks! Classic! Hey Joe....Im up in Wesley Chapel....used to live in Sarasota. Beautiful town, just saying!
Old 01-26-2019, 12:13 PM
Mein Auto: locally
You're right 44. Sarasota has a character all its own. We've been here since 82 and it's the best decision we ever made. When you make a decision that early in life, you never know what's going to happen. Even though they both went to college, they live here in town with my 5 grandchildren! This was our intent when we moved here but you know kids. It was part planning and part luck. We are blessed!
Joe
Old 01-29-2019, 07:14 PM
RBEmerson RBEmerson is offline
Frequently perplexed
Mein Auto: 325xi X3 3.0i FJR 1300ES
A dab of breakable (not RED!!) Loctite thread locker will hold the bolt and nut in place. (please buy Loctite stuff, it pays my wife's pension!) Also, use at least a Harbor Freight torque wrench to tighten everything to the correct torque. Over-tightening is a Bad Thing.
Also, I strongly recommend smearing the battery connections, front and back, hot and ground, with dielectric grease (CRC works for me - got no skin with CRC). Smear the posts and terminals - everything! - with this and then seat everything tightly and tighten everything to spec. The grease is pushed out of the points of physical contact and the rest is sealed against water and dirt intrusion.
