Part-time rough idle - Bimmerfest - BMW Forums
Old 01-27-2020, 06:27 AM
MartMX MartMX is offline
Mein Auto: 2003 530i
Got a 2003 530i 3.0L that has the proverbial rough idle problem. I used a smoke machine to fix a couple of vacuum leaks and can't find anymore. I changed the spark plugs and coil packs with no change in the rough idle which happens about half the time. No check engine codes active.
Any ideas?
Old 01-27-2020, 09:42 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Monitor the short term fuel trim numbers to see if there is a correlation with the rough idle. Report back.
Look at this one: https://www.harborfreight.com/zr11-o...abs-63807.html
It could also be a failing fuel pump. Monitor the fuel pressure via the Schrader valve on the fuel rail. Tape the fuel pressure gauge to the w/s or wiper arm.
Old 01-27-2020, 03:20 PM
528iAut 528iAut is offline
Mein Auto: 1996 528i
Just throw in my own little observation. I only have a Creator C110 reader and the only codes I have are o2 sensors, those codes have been there for a while.
Lately the car idles a bit rough on start-up, rpm is where its always been though. Moving the gear selector to P normalizes the idle, maybe this is normal, not really sure but yesterday it happened twice that the car just died while I was putting the seatbelt on, think the gear was in D with the foot on the brake.
Otherwise car drives just fine.
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 01-28-2020, 05:24 AM
Watched the fuel trim on the drive on to work this morning. Short term fuel trim migrates between about 3% and 9%. Can't really see a big difference when it idles rough or runs smooth. Haven't checked the fuel pressure, yet.
