SMG Fault + Unknown Repair - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E63 / E64 M6 (2006 - 2010)
Old 02-12-2020, 10:12 AM
6er_ 6er_ is offline
Mein Auto:
Good afternoon,
My 6er is currently stuck in N and is unable to shift gears. In the mornings however the SMG is able to shift and there are no fault codes. After around five minutes of running, I receive a yellow cog and am unable to shift gears. When I attempt to shift from N to 1, I hear the gears changing non stop. Almost like the gears aren't able to be held.
I scanned for codes and I received:
4EF5 - unable to shift
4E75 - selection angle sensor
I have searched multiple sites and have been unable to find a similar situation. Can anyone reach out, and possibly give me some thoughts on where to go from here?
Old 02-18-2020, 11:52 AM
SunglassesGuy SunglassesGuy is offline
Mein Auto:
selection sensor sounds like a great place to start. id find out where it is located and look for something loose
Jim from Austin
2004 BMW E60, N62, GA6HP26Z, Dynamic Drive, Sport Pak, Logic 7, Bilstein B8's, Ti Silver
1990 Pontiac Firebird Formula, T-Tops, 305 TPI, Maui Blue
Old 02-18-2020, 12:07 PM
Mein Auto:
this section over here may give some clues. look for blown fuse in the loop. https://www.newtis.info/tisv2/a/en/e...x-smg/6qNVPGqd
also search, finding some M3 guys with similar problem
Jim from Austin
Old 02-18-2020, 12:13 PM
Mein Auto:
this may be it. https://www.newtis.info/tisv2/a/en/e...addles/oZB1Ewq
Jim from Austin
4e75, 4ef5, smg
