LCM II internal error, no check engine light - Bimmerfest - BMW Forums
Old 10-08-2018, 06:10 AM
528iAut 528iAut is offline
Mein Auto: 1996 528i
Had this old wreck for a couple of years, it works fine, starts up first time every time.
When I got the car the previous owner had drilled into the wood paneling, installed a switch to turn the high beams on as they must have been on all the time. I searched and found out how to change the responsible transistor in the LCM and the high beams are working normally again. 2 wires were cut by the lcm harness and I reconnected these.
I do not have any BMW programming software, NCS Expert or PASoft, I only have a Creator C110 reader.
The reader show no errors, except for the LCM where there is a lot but most everything works on the car.
When I got the car the errors in the cluster menu was:
1 BE C8 105
2 C7 81 000
3 D7 81 000
4 8C 84 000
5 92 84 000
A bit later they were:
1 BE C8 110
2 cd 88 014
3 d7 81 000
4 8c 84 000
5 92 84 000
I then looked at the fuel level senders and the are working again now.
Now its only one error:
BE 48 040
Some codes and their meaning:
1 Fuel consuming signal from engine control unit faulty
2 Fuel consuming signal (ti-II) from engine control unit faulty
3 Road signal from ABS/ASC/DSC control unit faulty
4 RPM (tD) from engine control unit faulty
5 Coolant temperature sensor faulty
6 Temperature sensor
7 Outside temperature sensor
8 Fuel level sensor 1 (Fuel pump side)
9 Fuel level sensor 2 (without fuel pump)
10 Tension to high at the power supply
11 EGS signal disturbed
12 Power supply Pin 15
13 Power supply Pin R
14 Service Interval Display (SAI) Reset
15 Pressure Switch
16 Gong Sound (T1)
17 Gong Sound (T2)
18 Gong Sound (T3)
19 Current to high in the instrument cluster
20 Internal error in the LCM module
21 Internal error (IKE)
22 Vehicle speed signal (Tacho-A)
23 Instrument cluster -Bus (I-Bus)
24 Body-Bus (K-Bus)
25 Error during activation of the instrument in the instrument cluster
26 Undefined error
27 Internal Error
28 I-BUS error
29 Power Supply
30 Power Supply
31 Power Supply
32 Power Supply
33 K-BUS
34 Oil Pressure Control Light
35 Reverse gear recognition
3E Error by activation display
3F Instrument cluster current to high
44 Oil pressure switch
87 Body-Bus (K-Bus)
88 (I-Bus)
8B Gong Ton (T3)
8C Power supply Term. R
8D EGS Data lead disturbed
8F Power supply
90 Power supply Term. 15
91 Gong Ton (T2)
92 Gong Ton (T1)
BC Break fluid level
BD Electronic break power
BE LCM internal error
BF Instrument Cluster Internal Error
C1 ABS/ASC/DSC Signal(Tacho)
C3 RPM signal from DME control unit
C6 Output PIN 6 (Code EWS)
C7 Fuel tank sensor 1 (fuel pump side)
CD Fuel consumption signal DME 1
CE Outside temperature sensor
CF Service Interval Display (SIA) Reset
D3 Coolant temperature sensor
D5 Oil temperature sensor
D7 Fuel tank sensor 2 (without fuel pump)
DA Fuel consumption signal DME 2
F0 CAN-Bus off
F4 CAN Identification missing
F5 CAN Identification missing (ASC)
F6 CAN Identification missing (DME)
F7 CAN Identification missing (DME)
F8 CAN Identification missing (DME)
F9 CAN Identification missing (DME)
FA CAN Identification missing (EML)
FB CAN Identification missing (EGS)
FC CAN Identification missing
FD CAN Identification missing
LCM II pinout:
Before 09/98.
Not M62.
A3 Light module
Plug connector overview
Number X-pin, colour Description
X12 15-pin, black Plug connector Light module
X38 15-pin, white Plug connector Light module
X10117 54-pin, black Plug connector Light module
Pin assignments at plug connector X12
Pin Type Description / Signal type Connection /
Measuring notes
1 A Right rear fog light Rear right light I
2 A Left tail light Rear left light I
3 A Right front turn signal indicator Right front turn signal indicator
4 A Right fog light Right fog light
5 A Left licence plate light Left licence plate light
6 A Right front turn signal indicator Right front turn signal indicator
7 M Control unit ground Ground point
8 A Rear left turn signal indicator Rear left light I
9 A Left brake light Rear left light I
10 A Centre brake light Raised brake light
11 A Left low beam light Low beam light, left
12 A Right licence plate light Right licence plate light
13 A Right high beam light Right high beam
14 A Right front turn signal indicator Front right auxiliary flasher unit
15 E Voltage supply terminal 30 Fuse F112
Pin assignments at plug connector X38
Measuring notes
1 A Signal line, night lights Connector terminal 58
2 M Control unit ground Ground connector
3 A Right low beam light Low beam light, right
4 A Left front turn signal indicator Front left auxiliary flasher unit
5 A Inner left tail light Rear left light I
6 A Left high beam light Left high beam
7 A Left fog light Left fog light
8 E Voltage supply terminal 30 Fuse F113
9 A Left reversing light Rear left light I
10 A Right reversing light Rear right light I
11 A Left front turn signal indicator Left front turn signal indicator
12 A Rear left turn signal indicator Rear right light I
13 A Inner right tail light Rear right light I
14 A Right brake light Rear right light I
15 A Left rear fog light Rear left light I
Pin assignments at plug connector X10117
Measuring notes
1 A Lighting, light switch Light switch
2 Not used
3 Not used
4 Not used
5 Not used
6 E Belt signal Driver's airbag
7 E Signal, hazard warning lights ON Hazard warning flasher switch
8 E Signal, rear fog light ON Fog light switch
9 Not used
10 E Wash water level Wash water level switch
11 Not used
12 Not used
13 E Voltage supply terminal R Fuse F41
14 E Signal, right turn signal indicator Turn indicator/low beam selector
15 E Oil level - thermal DME control unit
16 E Signal, night light dimmer Dimmer
17 A Right tail light Rear right light I
18 A Front left parking light Left front turn signal indicator
19 A Lights, hazard warning switch Hazard warning flasher switch
20 Not used
21 Not used
22 Not used
23 Not used
24 E Coolant level Coolant level switch
25 E Brake light signal Brake light switch
26 Not used
27 A Supply for beam throw control unit (LWR) Beam throw adjustment control unit (LWR)
28 A Reversing signal Intermittent wipe/wash control unit, rear
29 Not used
30 Not used
31 E Terminal 15 Fuse F16
32 E Signal, left turn signal indicator Turn indicator/low beam selector
33 E Headlights ON signal Light switch
34 E Signal Beam throw adjustment Headlight beam angle adjust potentiometer
35 Not used
36 E/A I/K-bus signal link Connector, I/K-bus
37 Not used
38 E Reversing signal Navigation control unit
39 Not used
40 Not used
41 E Brake fluid level Brake fluid level switch
42 Not used
43 E Headlamp flasher signal Turn indicator/low beam selector
44 E Signal, high beam ON Turn indicator/low beam selector
45 E Signal, rear fog light ON Fog light switch
46 Not used
47 Not used
48 Not used
49 Not used
50 Not used
51 E Signal, parking light ON Light switch
52 Not used
53 E Signal Beam throw adjustment Headlight beam angle adjust potentiometer
54 A Lights, terminal 58 EDC control unit
I had the cluster shipped away to pixel repair and its good now. Using test 1 in the cluster the VIN corresponds with the sticker and manufacturing date is accurate. I have no tamper dot.
Still, my airbag light has never been on (dont have any codes for it either), the check engine light has never been on along with a few other lights. I cant recall seeing the fasten seatbelt light either. The oil level sensor is working as I have been told by the cluster the oil level was low.
I admit I havent checked the cluster again since the pixel repair but I believe all lights are led? They shouldnt burn out and even if they did I would have some persisting codes from the Creator C110 then and I have none. The 110 doesnt read everything I know that.
Just hoping for maybe a miraculously simple solution, not sure what that can be, I didnt see any broken wires anywhere.
Had decided to just leave it but now I posted anyway...
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 10-08-2018, 01:28 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
The lower lights (5 in all) are incandescent, and have a funky base. Get 'em offline, or at a dealer. Rep[lace all, whilst your at it.
What is your overnight battery voltage?
Old 10-08-2018, 11:16 PM
Battery is always fully charged, 12,4-12,6.
Old 10-09-2018, 07:35 AM
Well, fiddled with the instrument, couldnt remember how to disassemble it so I had to find a youtube video, hope I didnt screw up anything but cluster 2 test is fully functional for the gauges so....
Airbag light comes on when ignition is on, goes away after a few seconds, the other lights come on when key is turned to second position but not the check engine light.
Anyway, couldnt find anything obviously wrong so we will see, not so important though, just would be nice to get a red engine light in case of total disaster....
The lights are led, forgot we talked about this in another thread so yeah, sorry, two threads about the same thing, I am getting old:
https://www.bimmerfest.com/forums/sh...=154653&page=2
Old 10-09-2018, 09:16 AM
Those are the "trouble" lights. The LCD panels on my car are lit by bulbs.
