2008 535i for cheap- NO START - Page 5 - Bimmerfest - BMW Forums
Old 11-28-2019, 06:22 AM
dharmabmw dharmabmw is offline
Mein Auto: 2006 530Xi
Based on what that filter looks like, I would say your car has been pretty neglected, so the $1100 you paid for this can of worms is more than a fair deal.
Keep track of your time and multiply it by $120. It will be interesting to see what the figure will be.
2006 E61 MT
2010 E91 MT
Old 11-28-2019, 06:48 AM
yellaboyla yellaboyla is offline
Mein Auto: 2005 545i
From what the guy said and it makes sense, he bought it 09/18 in Utah, had a ton of stuff done to prepare to drive down here to Louisiana..He had all the bushings changed (look new), rebuilt a turbo (cant tell), had the ports cleaned (will see Saturday), oil, etc. Bot out here beginning of year, drove til about April. It locked up, he towed it home...It has been sitting for about 6 months. He tried to say 2 months, but I could easily tell it was longer.
When I buy a car, I go through it. BMW' love maintenance, so That is what I am doing. It is just a project car. I always wanted to play with a N54 engine based car. Got my chance for cheap. My time is FREE, so I am only calculating parts. Still waiting on title, so just giving it the once over...lol
Old 11-28-2019, 06:36 PM
Originally Posted by yellaboyla View Post
....... . .. Still waiting on title, so just giving it the once over...lol
O-kay.
2006 E61 MT
2010 E91 MT
Old 11-28-2019, 11:21 PM
Starter rotates the engine. Added 5 quarts after oil removal. Going get compressor in morning.
Old 11-29-2019, 07:16 AM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
w00t!
Old 11-30-2019, 04:52 AM
BeemerGuy's Avatar
BeemerGuy BeemerGuy is offline
former motorcycle rider
Mein Auto: F87 & F01
V8 takes more than 5 quarts. At least 7 I think.
F87 (mine)
E90 (hers)
F01 (ours)
Old 11-30-2019, 06:34 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
6 cylinder in the 535
Specializing In Breaking Things Professionally
15486372<-----
Old 11-30-2019, 02:34 PM
BMWs since '87
N54 takes 7L.
Old 11-30-2019, 02:44 PM
Burning2nd's Avatar
Under the lift arms
E53
..M54 8.0 qt. 7.5 L.
M62/62TU 8.5 qt.//// 8.0 L.
N62/62TU 8.5 qt.//// 8.0 L.
E70
..N51/52/52K 7.0 qt.//// 6.5 L.
15486372<-----
Old 11-30-2019, 04:43 PM
Originally Posted by Burning2nd View Post
E53
E70
I will give it 2 more quarts. i left the drain plug out for 2 days..bone dry. computer said good at 5 quarts...ill give it 2 more
Old 12-01-2019, 12:30 PM
Well went to get compressor and salvage yard had wrong one. The main import lot was closed, but it will be open Monday.
Sent from my SM-G965U using Tapatalk
Old 12-01-2019, 02:21 PM
mjchecko mjchecko is offline
Mein Auto: 535i
E53
E70
I give mine 6.5 qts at oil changes and that seems to put the computer at the top of the monitor range. Think there is some variation in total crankcase volume motor to motor- ymmv
mjchecko
Old 12-01-2019, 03:12 PM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '15 435i '10 535i '08 X5
Forget the compressor, remove the belt and see if it cranks/starts.
Old 12-01-2019, 05:13 PM
ok, lemme torque down the plugs, and ill let yall know.
Old 12-01-2019, 08:01 PM
ok, so after turning over, now the key seems to be screwing up. i put key in slot, push start, dashboard lights up, then push, nothing. i keep getting a pic of a key on dash. the starter is not engaging anymore. thoughts??
Old 12-01-2019, 08:39 PM
Mein Auto: 535i
Is your foot on the brake when you push starter button? That is required to crank engine...
mjchecko
Old 12-02-2019, 01:46 AM
Yea, i knew that...imma try and jump it. maybe new battery is low. i been trying to avoid pulling the starter, but it may be bad
Old 12-02-2019, 03:41 AM
Given that you're in Louisiana, you probably want AC but you could do a bypass with a shorter belt. I'm not sure of the exact length for an N54 but a Delco 6K434 works on an N52. Something of similar length in a 7 rib (7K434) would possibly work.
2006 E61 MT
2010 E91 MT
Old 12-02-2019, 05:06 AM
BMW CCA 69606
Put charger on battery. You may have a parasitic load discharging the battery your new when ignition is off. If battery state-of-charge is below the startability limit, 30-40% depending on temperature, the DME will not engage the starter.
Read the codes if you can. Attempting to start with a weak battery can cause problems with the DME-CAS synchronization, requiring reset.
Old 12-08-2019, 08:57 AM
MileHighZee MileHighZee is offline
Mein Auto: 2007 BMW Z4 3.0Si
Updates?
-J
'07 Z4 3.0si
Old 12-09-2019, 03:11 PM
karolh karolh is offline
Mein Auto: 08 525i E60
I'm here with bathed breath waiting to hear the good news.....it started !!
Old 12-09-2019, 07:20 PM
Well the ac compressor is specific to the 08-10 models. The junk yard lied and said they had it, but I verified it was wrong. Found a guy in Houston with a compressor and starter, so imma grab them this week. Almost 3 hour drive, he won't ship, no cashapp, no Zelle....smh
Old 12-15-2019, 05:11 AM
Finally got the parts. 6 hours of driving last night. Assembly today.
Old 12-15-2019, 11:32 AM
Missing a tool to pull the starter. Intake, radiator removed. Off to Harbor Freight
Old 12-15-2019, 01:54 PM
Burning2nd's Avatar
Under the lift arms
Lot of money in to a car that doesnt run...
correct me if im wrong.. but didnt you get the starter to turn the engine over already?
Are you sure you need a starter?
are you sure the starter is being commanded to run?
15486372<-----
