Fuel Indicator - Bimmerfest - BMW Forums
Old 01-24-2020, 06:20 AM
mohamedrani mohamedrani is offline
Russian Bimmer
Mein Auto: 520i 1998
Fuel Indicator
Hey guys,
i noticed that when the weather is cold, some where below -5 , when i start the car, the fuel indicator always very low , and if i have for example 15L in the tank , the light for the empty take will light , but as the car warms up, it shows the current fuel correctly, when i fill the tank it goes to the max. normally too, but sometimes it's just little slow, like i've to drive couple of KMs or if i just let the car at home for a day,
is that a bad fuel sensor?
Current Garage
98 E39 520i
17 Wrangler Unlimited Sahara lifted
Old 01-24-2020, 11:21 AM
djbecker djbecker is offline
Mein Auto: e30,e34,Z3,e39
Some background that may help you diagnose the problem:
The e39 has a "saddle tank". The tank straddles the driveshaft. Once the level drops below about 1/2, the two sections of the tank are isolated.
To allow this to work with a single electrical fuel pump, there is a "siphon jet pump" that transfers fuel from the left side to the right side. It is a passive device that uses the return flow from the fuel pressure regulator past a venturi to suck fuel using a tube that goes from the bottom of the left side to the right side.
This has no effect when you have more than a half tank of fuel and the fuel level is above the saddle. Once the level drops below the saddle, the behavior depends on if the fuel pump is running. If it is running, the left side is constantly emptied while the fuel pump is running. When the engine is shut off, the fuel levels equalize through the siphon tube.
Old 01-24-2020, 11:36 AM
528iAut 528iAut is offline
Mein Auto: 1996 528i
Quite normal.
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
