No beep - Bimmerfest - BMW Forums
Old 01-29-2020, 11:30 AM
dmaisenh dmaisenh is offline
Mein Auto: 99 528iAT
No beep
Suddenly the car no longer chirps when I lock and unlock it.
Any ideas?
Old 01-29-2020, 12:44 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Does the siren work? Lock the car and open the bonnet.
Old 01-29-2020, 03:09 PM
Nfs021's Avatar
Nfs021 Nfs021 is offline
What Speed Limit?
Mein Auto: 2003 M5, 2002 540i RIP :(
I'm in the same boat. My GM module on my M5 crapped out few weeks back. Replaced it with the exact same part from another car. And since then my alarm won't chirp either. Lights just blink when lock/unlock and nothing else. When I open the trunk with the doors locked the lights flash as if the alarm has gone off but there's no sound. Also I noticed the clown nose light on the the rearview mirror doesn't blink at all when I lock the car.
Of course I have loads of other electrical issues that could be affecting it. But let me know what you find.
Sent from Uranus with Love
Old 01-30-2020, 12:48 AM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
BMW forever
Mein Auto: 1996 528i 1999 MB C240
The sieren could have gone bad,or even the GM module could have forgotten the code,you could program it ON Off.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Working on my car is a pastime
Old 02-07-2020, 05:36 PM
scottjoh scottjoh is offline
Mein Auto: 1999 323i
No beep
Any ideas?
It is probably a bad sensor. Itís like when you arm the alarm with the trunk open. The car locks, but, doesnít chirp until you close the trunk. One of the sensor is not set. Most likely itís the hood/bonnet sensor.
Nfs021 has a different problem since he has a big unknown with that used general module thatís coded to a different car.
Old 02-07-2020, 06:58 PM
The hood switch has been unplugged for awhile and it worked with it disconnected.
Old 02-07-2020, 07:14 PM
Nfs021's Avatar
What Speed Limit?
I think that maybe the alarm could've been coded off with the used module. I also still have issues with the central locking fuse blowing. But that's all been put on the back burner for now while I get caught up on maintenance stuff with the car. I exhausted too much time on that issue with no luck and will deal with it later on.
Old 02-08-2020, 03:53 AM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: e39, e83, e60
make sure all your doors and trunk and hood are closed (one of the switches is open)
that open makes it so it doesn't beeb to let you know that you have a door that is not closed
iD start with disconnecting the hood switch if you are one of the legend's that still has that connected
you can view the live data on the central locking system also to let you know what circuit is reporting open
Specializing In Breaking Things Professionally
15486372<-----
Old 02-08-2020, 11:09 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
The clown nose (below the interior rear view mirror) can give some info as to what "some" of the problems are. It is the status LED for the DWA (anti-theft alarm siren system). It should illuminate and flash continuously (slowly, too) when the vehicle is locked using the remote fob or manually locking the car using the driver's exterior door lock cylinder. If the light isn't coming on, then the DWA system hasn't been initiated.
If the clown nose does illuminate and flash...then the way that it flashes indicates what is going on with the system:
If the alarm siren isn't making an audible sound when locking/unlocking the car (which can be coded off/on with software/hardware)....then you can also double check that the alarm siren still works by activating the PANIC button on the remote fob. I turned off the audible alert on my 97 e38 because I hated the sound of the "wolf whistle"...and if a GM was installed from another BMW...this could be the reason no audible lock/unlock alerts are heard. See instructions from the owners manual below on how to initiate the PANIC alarm to see if the siren can actually make noise. Do note that the system needs to be ARMED for the alarm to sound off:
If you can't get the alarm siren to make an audible sound...then perhaps its internal battery is dead...which could create many of the situations mentioned above:
ID:	881237   Click image for larger version
ID:	881243   Click image for larger version
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 02-08-2020, 01:16 PM
Nfs021's Avatar
What Speed Limit?
I've got no flashing light from the clown nose at all, no audible sound when lock/unlocking. And I can't test the panic alarm because my fob buttons don't work when I press them and I can't rsync them to the used module. The fob and it's battery work. I had the BMW dealer test it awhile back when I had them check the airbag light. They couldn't get it to program either, but that was when the old gm was still working.
The gm from the other car, could've been programmed so the alarm doesn't chirp like you have stated. And like I said I have so much other electrical crap to sort out and just don't want to deal with it anymore at this time. My brain is fried from looking at all the damn wiring diagrams online and reading countless threads on the issue. I'll get back to it when I feel like it lol.
Old 02-09-2020, 04:16 PM
Here's what I have so far.
When the alarm is set the clown nose flashes fast for about 10 sec then slow.
When I press the panic button the light flash like the alarm is going off but there is no sound.
This looks to me like siren failure but the question is why would that cause the 10 second fast flash?
Update, I just checked the 5A fuse number 48 and it is good.
Old 02-09-2020, 05:29 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
the initial "fast flash" when enabling the alarm system is normal for a system that has open sensors at the time its set...hood switch, headliner sensor removed etc.
99 528i 5sp sport
be alert...the world needs more lerts
Old 02-09-2020, 06:13 PM
Ok so it has been doing the fast blink and I just didn't notice it and it is unrelated to the siren crapping out.
Old 02-09-2020, 07:22 PM
Does anyone know the difference between the sedan siren and the touring siren? They have different part numbers.
The sedan one is shared with E46s X3s and X5s as well as E38s. Meaning that there are multiple sources for ones out of newer cars.
The touring one is shared with the E36 and E36 Z3 as well as the 8 series.
My local automotive recycling center doesn't have any tourings.
Old 02-10-2020, 08:41 AM
528iAut 528iAut is offline
Just search on the part number and try a used one.
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
