Fxx-/Ixx-/Gxx-series Coding: Getting Started Guides, Tips, & Cheat Sheets - Page 20 - Bimmerfest - BMW Forums
Old 11-10-2019, 08:04 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by hideada View Post
I am using the latest psdz data because [C012] error occurred.
I read various modules with the latest psdz datav.4.20.20, but there is one error.
A short VIN is displayed next to each module. Is this a [0000000] hardware error?
Can anyone get advice?
Try to write VIN to it:
E-Sys => Expert Mode => FSC Extended=> WriteDataByIdentifierVIN = xxxxxCARxVINxxxxx
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 11-10-2019, 08:21 PM
hideada hideada is offline
Mein Auto: X5
Thank you for reply.
I will try again.
However, the authentication server seems to be down and Launcher can no longer be activated.
I will wake up and challenge.
I'll report again.
thanks.
https://www.fxxtokenmaster.com/
Old 11-10-2019, 08:27 PM
I will try again.
I'll report again.
thanks.
Launcher needed ONLY for FDL Coding, and nothing more.
Old 11-12-2019, 09:01 PM
gt1 gt1 is offline
Mein Auto: R1200GS
How to undo the coding done with the cheat sheet?
The rear view cam at any speed doesn't work the way I expected and I want to undo the coding. Also need to check the rear view mirror tilt- I didn't code it, but the wife says the mirrors deep too far now. I have I001 and the code lists don't have the parameters for the cam and mirrors. What should I change?
Old 11-13-2019, 01:52 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
https://docs.google.com/spreadsheets...9s4/edit#gid=0
ASP_BORDSTEINAUTOMATIK_DELTA for mirror.
Old 11-13-2019, 03:08 AM
Mein Auto: X5
I challenged because I was able to re-authenticate the launcher.
However, this is the first operation to write VIN and the operation method is unknown.
"Please enter a Diagnostic Address and a Base Variant first. [G098]"
What do I need to enter for Diagnostic Address and a Base Variant?(My car is G05)
I have found a similar situation here, but the Diagnostic Address and a Base Variant is unknown.
Use 0x63 as well?
I also want to inject a CAFD file into FLM2 [44].
What should Base Variant input because FLM2 [43] also exists? Is FLM2 good?
https://www.bimmerfest.com/forums/sh...d.php?t=924246
Or is it just an action part? Is it a combination of READ? SAVE? EDIT? START?
I need advice.
thanks.
Name:	***12473;***12463;***12522;***12540;***12531;***12471;***12519;***12483;***12488;_111319_065824_PM.jpg
Old 11-13-2019, 11:32 PM
ssb-la ssb-la is offline
Mein Auto: 2016 535i
Help Coding G30
Dear Bimmerfest Coding Enthusiasts,
I’m hoping some of you can help me with my coding efforts. I used to be able to code my previous F10s using E-Sys with tokens generated using TokenMaster’s launchers. However, I recently leased a 2019 530i (G30) and haven't been able to successfully code my new car.
I’ve searched this and other sites extensively without success, so I’m hoping some of you can help.
I obtained a new license to TokenMaster’s Launcher Pro by making a donation to charity and downloaded the software needed.
This is the configuration that I’m using to try to code my car:
- Macbook Pro with a Bootcamp partition
- Windows 10 Pro, Version 1903, OS build 18362.356
- E-Sys 3.34.0 (64 bit)
- TokenMaster’s Launcher PRO V3.6.0288 (static activation code)
- KIS Knowledge Base S15A
- “Cheat Codes” – I’ve tried Almaretto’s and a several other combinations
I’ve been able to do the following:
- Download, install and activate the software
- Successfully connect to the vehicle to my laptop getting message: “Connection Established [G168]”
- Read and Activate FA
- Read ECU
- Read CAFDs using “Read Coding Data”
- Save a back-up of my default CAFDs
- On a few occasions, I’ve been able to use “Edit NCDs” and get to the FDL editor, but not consistently
Challenges that I’m facing:
- More often than not, when trying to “Edit NCDs” I get the following error message: “Runtime error occurred. See “Details >>” or log file for more information. [C027]. I’ve tried using different memory settings with the launcher without success.
- The few times that I’m able to see the NCDs, I either don’t see any “Cheat Codes” associated with the NCDs or see very short list. I’ve tried using all FDL Cheat Codes from the launcher or subsets, without success.
Questions to the group:
- Can you think of anything that I’m doing wrong that is preventing me from consistently being able to Edit the NCDs?
- Is there anything that I can do to see a full list of available Cheat Codes?
- How can I open the Cheat Code Files that Launcher Pro downloaded so I can try to code “manually”?
- Is there an old style “Cheat Sheet” for coding the G30 rather than having to use “Cheat Codes” within launcher?
Thanks in advance for your help!
Cheers,
SSB-LA
Old 11-13-2019, 11:55 PM
Almaretto's Avatar
Super Moderator
Cheers,
SSB-LA
Make sure you are excluding KISwb that you do not need in Launcher settings.
Try loading ncd directly in FDL-Editor.
Have you updated latest xml files on github?
You can always open files with text editor.
No Cheat Sheets exist.
Old Yesterday, 06:40 AM
Use 0x63 as well?
I need advice.
thanks.
The address of whatever ECU you want is shown in Brackets Next to it, so in this case it is either 0x44 or 0x43.
After you have Diag Address entered, simply press "Identify", and the Base Variant will populate itself.
Old Yesterday, 08:42 AM
peshety peshety is offline
Mein Auto:
Hello. How to code: when I turn on high beam lights to turn on automatically fog lights and cornering lights? All to light together.
