2002 325i battery replacement - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 02-11-2019, 05:06 AM
hifi440 hifi440 is offline
Mein Auto:
Greetings,
New to the forum and new to BMW. I have a bmw 2002 that needs a battery replacement. Local mechanic shop (not bmw specific) said that 250 would be the price. Seemed a bit high.
Next door there is a walmart. Gentleman there said 120 but that the battery needed to be registered and they could not do that there... Google and the search function confused me a bit... some saying that, older models do not need registration, some said they do...
1. 250 normal for a battery for this car?
2. Does it need be registered?
I sincerely appreciate your help!
Old 02-11-2019, 05:15 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
Go to Walmart and buy the proper sized battery, and install it yourself:
- disconnect the ground/earth/negative cable
- disconnect the positive (red) cable
- disconnect the vent hose
- remove the battery
- install the new battery
- connect the vent hose making sure that the other end goes to the outside
- connect the positive cable
- connect the ground/earth cable (sparks are ok)
- reset the clock.
The new battery does not need to be registered.
Old 02-11-2019, 05:35 AM
Mein Auto:
great news, I really appreciate your prompt response... thank you much!
Old 02-11-2019, 10:45 AM
jaye944's Avatar
jaye944 jaye944 is offline
where da clutch at ?
Mein Auto: BMW 128i Msport
BMW battery registration was introduced in 2002 and most BMW models after that require that you perform battery registration for best battery life and avoid electrical issues. If your BMW is older than 2002, you generally don't need to perform battery registration.
Here is a list of some BMWs that need battery registration.
E61, E63, E64, E65, E66, E67,
E70, E71, E72, E81, E82, E84,
E87, E88, E89, E90, E91, E92,
E93, F01, F10.
Old 02-11-2019, 10:46 AM
jaye944's Avatar
Here is a list of BMW models that need the battery to be registered.
2006 and up 3-series E90 E91 E92 E93
2004 and up 5-series E60 E61
2003 and up 6-series E63 E54
2002 and up 7-series E65 E66
2007 and up X5 series
2008 and up E70 chassis
X6 series E71 chassis
Old 02-11-2019, 12:38 PM
Mein Auto:
Thank you very much!
Similar Threads
BMW i3 Long Term Battery Capacity Report: Better Than Expected jacksparrow007 BMW i3 I01 (2014 - Current) 6 04-12-2019 07:25 AM
F10 Battery Replacement Recommendations? kuhlag F10 / F11 (2011 - 2016) 14 01-24-2019 06:31 AM
All BMWs Spark Plugs Jtripper Tools and Miscellaneous 0 08-02-2018 04:02 AM
2002 325i SP bumper replacement HELP 3seriesbimmer General BMW Questions 6 06-30-2002 04:30 PM
2002 325i bumper replacement HELP 3seriesbimmer 3 Series & 4 Series 2 06-29-2002 06:35 PM
