Idrive software update fixed error codes? - Bimmerfest - BMW Forums
Old 07-02-2019, 11:22 AM
germans germans is offline
Mein Auto:
My GF just got a 2012 BMW 335I with 45000 miles on it.
I got out my code reader and started checking for codes and saw some of the following:
801206 Blower output stage: Undervoltage or overvoltage detected
801A55 DWA: The alarm has been activated
CD0487 ZGM: Sycronisation process for FlexRay failed
She hasn't added anything aftermarket to the car like stereos or anything and all I did was clear the codes and update the BMW iDrive software to the latest. Now I get no error codes. Is it possible that the BMW iDrive software fixed the issues? I thought the update was only for the interface software for the screen.
Old 07-02-2019, 12:41 PM
dzlbimmer dzlbimmer is offline
Mein Auto: Diesel
Software did not fix any of that. They are just Intermittent failures.
Just keep scanning it every couple weeks and see what comes back and at what frequency.
Old 07-02-2019, 09:52 PM
CoolShirtDude CoolShirtDude is offline
Mein Auto: 2011 BMW X3 2.8i F25 N52
How old is the battery? Since you have a 2012, that would be one of the first things I would check.
Also ground cables, are another area the is troublesome on BMWs, these cars tend to have random codes when voltage is out of spec.
You can use realoem.com and newtis.info to locate the grounds as well as part numbers.
2011 BMW X3 F25 N52
2015 BMW 328i F30 N20
2011 BMW X3 2.8i (F25) N52
2015 BMW 328i (F30) N20
Old 07-03-2019, 08:40 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
... all I did was clear the codes and update the BMW iDrive software to the latest. Now I get no error codes.
Sooo...you cleared the fault memory and now you are puzzled as to why there are no faults?
(Sorry, I could not resist.)
As already stated, it just means they were intermittent or non-recurring events. The fault memory includes the latest mileage at which each fault code was logged. When reviewing the memory, if the current mileage (actually it's logged in kilometers) does not approximately equal the current odometer reading, you're unlikely to see the fault again immediately after clearing the memory. Keep an eye out for future occurrences and act accordingly.
Side question: When you say you "updated iDrive software" do you mean the in-system update via the USB port that you initiate from the iDrive menus? Or did you actually upgrade the integration level (i.e., load new firmware) using ISTA/P?
The former is only a driver update for the Bluetooth interface stack. It changes neither the user interface nor fault memory.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
Old 12-30-2019, 11:52 AM
Mein Auto:
I got these codes again when I checked today minus the alarm code so I guess its been six months.
"When you say you "updated iDrive software" do you mean the in-system update via the USB port that you initiate from the iDrive menus?"
I went to the BMW website put in VIN, downloaded the software that BMW provided and updated it.
The battery seems strong judging from the starting but I'll check with multimeter. 12.2V which isn't the highest voltage but was about 33F last night so still cold.
Old 12-30-2019, 01:06 PM
Zeichen311's Avatar
Thanks...as noted, that only applies fixes and improvements (such as support for newer phones) to the car's communication with Bluetooth devices. It does not alter the user interface and will not clear or correct any fault conditions, so you still have some problems to diagnose.
You said 2012 335i but did not mention the body style: Coupe or sedan? If the former, that would be an E92, not an F30. You have fault codes for the blower motor voltage; there was a recall for the blower-motor wiring that affected many E90s. I forget whether that extended to the E92 but if this is an E92, it's worth a check.
BMW recalls web site: https://www.bmwusa.com/safety-and-emission-recalls.html
BMW CCA
Old 12-30-2019, 03:23 PM
Mein Auto:
Its the sedan, so its the newer F30 style. All of the recalls have been done. BMW shows zero recalls now.
