Sound coming right rear area of trunk area, Suspension probably? - Bimmerfest - BMW Forums
Old 05-17-2019, 05:38 PM
blazingdon blazingdon is offline
Mein Auto: BMW F10 535i XDrive
Car is a 535 Xi 2013 model with 76k miles now
Hi, Do you guys know if the sound from the rear is suspension problem, and what specific part could be making the sound.
I found this video on youtube from another driver, and that's exactly the noise I get when I climb over bumps or potholes . The crazy thing is, I haven't driven the car in 3 days until today, and the sound disappeared, though I have a feeling it will come back soon. I would love it if I can pin point the problem so I don't have to pay mechanic for troubleshooting process
Old 05-17-2019, 06:48 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
Looks like something up front.
Old 05-17-2019, 06:53 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 M-sport
Loose battery? Bad struts?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 05-17-2019, 07:44 PM
yogi799 yogi799 is offline
Mein Auto: '11 535i, '99 328i retd
Very similar to what i've had for weeks and finally repaired it. See the link to my new vid below.
First, though, be sure it is your front or rear strut (my video is for the rear). Couple ways to do it. Go at low speed 10-15mph and make a few VERY sharp turns left and right (quick left, quick right, immediately one after the other). If you have a noise when turning left (like me) it is your rear strut, and vice versa.
You can also lift up the car and listen - my shock was making the same noise when i lifted the rear wheel up (although NOT always so take that with the grain of salt). Test above is more reliable.
https://www.bimmerfest.com/forums/sh....php?t=1330787
BUT I sorta agree with the first poster, it sorta sounds like this could be your front strut/shock, not rear.... But perform the same tests to verify.
Old 05-18-2019, 06:27 AM
surly surly is offline
Mein Auto: '11 F10 535xi
The rear strut/shock tops are under the rear parcel shelf speakers. Check out yogi's rear strut DIY video to see exactly where. There could be movement here, or sound conducted to that location. I'm not commenting on whether it's front or rear - that should be easy to figure out though some assistant listeners may be required.
Old 05-18-2019, 06:41 AM
Ziggy328xi Ziggy328xi is offline
Ziggy.
Mein Auto: 11 328xi N51
Check rear coil springs could be broken causing excessive movement and your noises
Old 05-19-2019, 06:24 AM
Thanks for the replies, I had this issue for like 5 days straight, but for some reasons I haven't been able to replicate the issues my last 3 days of driving. Kind of weird.
Anyways I took the car to the dealership, and they said the Thrust Arm bushings are torn and leaking. Maybe that's the problem or maybe its an additional issue I have.
Similar Threads
:: ECS Tuning:: Bilstein Shocks & Struts | B4 B6 B8 and more! ECSTuning Site Sponsors & Bimmerfest Group Buys 11 08-16-2017 10:43 AM
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
The all new 2016 G12 7 Series - BMW's 6th generation flagship tim330i 7 Series - F01 / F02 (2009 - 2015) 51 07-30-2015 07:23 AM
The All-New BMW 4 Series Convertible tim330i F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 11 10-18-2013 10:35 AM
Bought 540i on tuesday, joined bimmerfest today. houseOFounces E39 (1997 - 2003) 55 09-13-2013 02:17 PM
