E70 self leveling suspension coding issues. - Bimmerfest - BMW Forums
Old 12-22-2019, 12:39 PM
Dgeorge1617 Dgeorge1617 is offline
Mein Auto:
I recently purchased my 2008 BMW X5 3.0Si an i love it. However, i purchased it with the air suspension deleted and a set of coilovers installed on all four corners. The coilovers ride nice and are adjustable but as expected the "Self leveling suspension Malfunction" code is on the dash. I was looking at how to remove the code and purchased a k+DCAN cable as well as downloaded INPA/NCS EXPERT and all the BMW tools software.
Here is my problem: When i try to delete the $220 code in the VO/FA and hit "back" it gives me the COAPI-1000/Fehler message. In reading some threads I see that I am supposed to also remove $2VA along with the 220 but I do not have this code in my VO.
As a workaround I used NCS Expert/NCS Dummy to read the KOMBI and disable the EHC app module and disconnected the EHC module. This workaround failed as well because when I execute SG-CODIEREN to code KOMBI the car automatically sets the EHC App Module back to "aktiv". Any ideas why the coding is not staying or as to why I cannot delete the 220 from the VO?
Any help would be greatly appreciated. Also if you need more info I would be glad to provide.
Old 12-22-2019, 03:47 PM
ard ard is offline
Resident Curmudgeon
there is a coding sub-forum, post there as well....
GL
OEM is not what BMW sells
Old 12-22-2019, 04:22 PM
Mein Auto:
GL
Thanks Ill post in there.
coapi, coding, e70, ehc, inpa, kombi, self leveling suspension, sls, x5
