Power output under different temperature for N55 335i - Bimmerfest - BMW Forums
Old 03-09-2018, 11:06 AM
Skyliner32 Skyliner32 is offline
Mein Auto: 335xi Gran Turismo
I'm curious to know if you guys are getting different behavior under cold(like around or below 32F or warm day). After I floored it at 200 water temperature and 40F outside temperature, I find the torque reading (sport mode display) little hesitated to go to the full 300 from 200, eventually it was there, but the last time I floored it the way it builds up torque was quicker and smoother.
Thoughts?
Old 03-09-2018, 11:47 AM
N52 Moistenor N52 Moistenor is offline
Banned
Mein Auto: 2011 528i RWD
First off, that little chart is not an accurate way of determining how much power your car is making. Yes, different temps affect performance (below 100c or above 110c and you lose some power) but it could’ve been something simple like how you apply the throttle. Easing into the pedal gradually in manual mode will help the turbo respond better than just flooring it right away. Try it.
Old 03-09-2018, 03:33 PM
Matthew424 Matthew424 is offline
Mein Auto: 2015 328 X-Drive
I agree. I think the OP may also be describing turbo lag, where the RPMs need to be build (so the turbo spools up) and you feel the surge in the power.
2015 BMW 328 X-drive : Dinan Stage 1: Dinan Exhaust: Dinan Springs: Dinan Supplemental Ride: Dinan Intercooler: Dinan Pedals: BMW Performance Headlight Bulbs : Bimmertech Front/Rear Cameras: Bimmertech MirrorCast : BMWCCA Member #516886 (Feel free to use my BMWCCA # for a referral).
Old 03-27-2018, 11:52 AM
Thanks, I'm not used to not having a boost gauge in the car. I tried it and felt the difference, weird setup. My Skyline would fly after I just floor it.
Old 03-27-2018, 11:53 AM
I don't think it's the lag, it felt like the car was not determined to go.
Old 03-27-2018, 11:56 AM
Old 03-27-2018, 12:07 PM
acoste's Avatar
acoste acoste is offline
Mein Auto: 2010 550i MT
Thoughts?
It should be the other way around. (warm) engine performs better in cold weather versus in hot because it can pump more air into the engine.
either the DSC asked for power reduction or the transmission (does not allow more torque than a specific limit)
2010 BMW 550i MT
2003 BMW 325i @216k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 03-29-2018, 05:29 PM
ClevelandBeemer ClevelandBeemer is offline
Mein Auto: 2013 335i M Sport
Keep in mind that the temperature gauge in the cluster is not coolant temp. It's actually oil temp.
What rpm are you flooring it at?
What gear were you in?
Were you using 93 octane fuel or something less? Also possibility of bad fuel.
Comparing a GT-R to your 335 GT is a terrible comparison. It's like comparing a 335i to a Corolla.....
Current garage; 13' 335i, 13' X5 xDrive3.5i Premium, 15’ S1000R
R.I.P.; 99’ Lincoln Navigator, 00' Lincoln LS V8 Sport, 05' VW Jetta 2.5L, 06’ Z4si, 06’ X5, 09' 328xi, 12' VW Passat 2.5L MT, 13' 328i xDrive, 09' Suzuki SFV650
13' 335i -- ZCW ZDH ZMM ZTP ZMT ZPT 688 JB4
Old 03-29-2018, 05:56 PM
satx satx is offline
Mein Auto: 435i
Sounds to me like traction control working it's magic, if it was that cold outside likely the roads and tires were not at optimal temp
