TCU drainage and bypass - Bimmerfest - BMW Forums
Old 06-27-2020, 10:48 AM
Dalplex's Avatar
Dalplex Dalplex is offline
Mein Auto: 08 Smart Fortwo
Hello.
My battery drained many times and finally I measured the current today.
It was 0.6A. No wonder.
It became 0.2A after pulling fuse 79 for Telephone control unit.
Both of above readings are under the battery OFF position.
I think it is still high compare to 0.06A of SPEC.
What I am losing and what else I need do other than bypass the MOST bus?
06 750 Li, Clattering noise, suspect piston 2 hits head due to spun bearing.
03 760 Li,
coolant leak from back plate.
Random misfire codes.
Old 06-27-2020, 10:55 AM
Doug Huffman's Avatar
Nuclear engineer
I have posted BMW Advanced Vehicle Diagnosis many times here at BF. Find a copy and learn. Here's a copy not at BF
https://www.scribd.com/document/4065...-Diagnosis-pdf
Old 06-27-2020, 04:58 PM
Dalplex's Avatar
Thanks.
This car drained but not killing the battery.
I have 2 batteries no longer taking charge by another car.
03 760 Li,
