09 E60 550i 6Spd For Sale - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Cars - Private Party
Do you have a car for sale? Are you looking for a new BMW? Check here daily as well as searching on craigslist and eBay Motors
Old 06-30-2020, 08:53 AM
N62.e60.sixspd N62.e60.sixspd is offline
Mein Auto:
I'm looking to sell my car because it'll open many opportunities for me, just to be clear I'm in NO NEED OR RUSH to sell this car so you can miss me with any 'market value low balls'. If you're an enthusiast then you know why the asking price is $27,500. I have an extensive service history from its first mile to its current mileage at 95,224 which you will receive in a binder if you decide to purchase the car. I will illustrate all the services that have been done for the 550i during the previous ownerships and my ownership. The car currently has a renewed warranty with GWC for 3 years, there's still more than 2 years of coverage. Below will be everything the car is included with. There won't be any test driving until you prove you're a serious buyer.
Text before calling me at (925) 628-8126
Note: If you buy this car, you will receive a license plate frame that reads 'ID RATHER BE DRIVING MY 6SPD BMW 550i' so you can proudly rock on whatever car you daily drive!
ALL SERVICE RECORDS FROM MY OWNERSHIP
I am the 5th owner of this car.
2009 BMW E60 550i M Sport w/ the 6 Speed Manual Transmission
Purchased from TSF Auto Sales - 4/10/2017
2 Year GWC Warranty - 4/10/2017
-Odometer: [72,990]
Service Inspection $182 @ German Autotech Inc. - 6/6/2017
-Odometer: [73,345]
Findings:
- Front brakes @ 6mm ok.
- Rear brakes @ 3.5mm, needs full rear brake service. ($636.20)
- Front active sway bar slightly wetting around hydraulic element.
- Water pump bearing is going bad, audible noise present. ($440.29)
- Valve stems seals are bad/worn, prolonged idle test with throttle blip shows a lot of blue smoke from tailpipe. ($3920.00)
- Full 60k service needed. ($1106.00)
- Quote On Paper: ($9273.26)
Service Repairs Completed @ EU Tech. 4/12/2018.
-Odometer: [73,345]
Total Repair Bill + Brake Job (7,439.70)
Oil Filter w/ O ring
Cylinder Head Gasket Set
Coolant
5W30 Synthetic Oil
Spark Plugs
Oil Cooler Seal
Oring
Oil Cooler Seal
Oil Thermostat Oring
Oil Cooler Seal
Head Bolt Set
Intake Valve
Dowe
Air Filter
Cabin Air Filter
Water Pump
Water Pump O-Ring
Water Pump O-ring
Water Pipe
Expansion Tank Hose
Synthetic brake fluid
Drive Belt
Ac Belt
I purchased the following brake parts bellowed and paid them to install during the same job out of convenience since my wife and I had plans that day after picking up the car.
Stop Tech Cross Drilled & Slotted FRONT & REAR rotors. (567.00)
Stop Tech Sport Brake Pads FRONT & REAR. ($178.08)
REAR & FRONT brake sensors. (30.03)
20 Black Lug Nuts. (126.40)
BMW Anti-Squeal Brake Paste (5.20)
Second Key Fob Purchase & Comfort Access Programming. - ($341.76)
Radial Tire Service. - 4/19/2018
- Odometer: [74,353]
- 4 New Michelin Pilot Sport 4S Tires. ($1,156.65.)
Muffler Tech - 4/21/2018
-Odometer: [74,367]
-Muffler Delete. ($232.75)
(PS. I still have the original muffler if you'd like to take it along with the purchase.)
Maintenance Service @ EU Tech. 7/10/2018. - ($295.20)
-Odometer: [78,866]
Manual Transmission Fluid Change. (MTF LT3) 83 22 2 339 221
Differential Fluid Change. 07 51 2 283 972
Service Repairs Completed @ EU Tech. 7/21/2018. - ($679.54)
-Odometer: [79,038]
- Alternator Bracket Seal 12 31 7 507 808
- Oring 11 42 1 702 917
- Oil Cooler Seal 17 22 2 245 358
Oil change performed by yours truly on 8/14/2018.
-Changed on Odometer: [80,107]
-Total Quartz 5W-30 Engine Oil. 10 Quarts
(This is top shelf oil, EU-Tech uses this for all their cars. It's extremely difficult to find this oil and from a source where the price DOESN'T change. If interested, go to Foreign Parts Specialties Inc. in Sacramento )
-Oil Filter Kit 257540
ECS Tuning . 7/20/2018
Front rotors felt warped since braking hard at high speeds caused the steering wheel to shake vigorously. (I was extremely upset >.<) I had to purchase new front rotors and return the other ones to get the money back but they assured me they will test the second set of rotors before sending them out.
Stop Tech Cross Drilled & Slotted BRake Rotors. ($283.49)
I removed the warped front brake rotors and installed the new unwarped rotors on 8/5/2020.
Tested the braking in various ways and there is absolutely no vibrations when braking hard. Job successful. (I have many years of working on cars.)
Attempt: Wheel Alignment @ Seever & Sons Tire. 10/15/2018. - ($679.54)
- Odometer: [84,800]
-Advised that both my tie rods on the driver & passenger side are 'Frozen'.
-Also advised wear marks on tie rods, previously tried to break loose by another shop.
-Advised this car can't be aligned.
-Verbally offered a quote including cutting off the tie rods. Respectfully declined.
Service Repairs Completed @ EU Tech. 10/26/2018. - ($2,405.81)
- Odometer: [84,929]
-Water Pump
-Water Pipe
-Coolant/Antifreeze
-Water Pump Oring
-Oil Return TUbe Seal O Ring 17 x 3
-Tie Rod Assembly
-Door Lock w/ Motor Actuator
-Window Motor-Rear left
-Steering Rack Boot
On 11/05/2018 when I returned from work in Dublin, I noticed a leak from under the car. I inspected the area and confirmed the expansion tank is leaking from the top due to a crack. (It was a 9 year old expansion tank with a new water pump, it wasn't meant to last a lifetime.)
When I turned on the car, I had a low coolant warning. I carefully drove it to the nearest BMW dealership which was around the block.
Purchased 1 gallon of antifreeze and topped off the expansion tank.
Turned the car on, low coolant warning did not appear at any point in my drive home.
Drove home 31 miles home carefully.
Service Repairs + Maintenance Completed @
EU Tech. 11/10/2018. - ($869.76)
- Expansion Tank
-Coolant
-Total Quartz Oil 5W-40
-Oil Filter 11 42 7 542 021
-Battery - ($180) For the record, the full battery replacement + programming is a $700 but this shop is completely genuine and amazing, the guy only charged me for the battery. Installed and programmed it on the weekend when he's NOT EVEN on the clock. Only amazing people at this shop. (Its certified dealership for the GWC warranty this car has.)
-Cal Battery
Radial Tire Service. - 4/19/2018. - ($271.95)
- Michelin Pilot 4S Tire x 1
Nail went straight in, apparently there's no warranty on these expensive tires >.<
Foreign Parts Specialties Inc. - 1/17/2020
Odometer: [94,027][After Oil/Filter Changed]
-Even after specifically asking for my exact filter, they gave me the wrong filter. It was meant for the F10 550i.
- I found out as I was doing the oil change on 2/25/20. I purchased an Oil Filter from BMW concord. The clerk was obviously an idiot because the invoice date was 6/18/19???? Doesn't make sense. I clearly bought the filter
and changed the oil on 2/25/20.
MOST RECENT OIL CHANGE
2/25/20 @ 94,027 miles. Next oil change is scheduled for 99,027 miles.
***DISCLAIMER***
THE EMERGENCY BRAKE DOES NOT WORK AND THE WARRANTY DOESN'T COVER THE JOB. I'VE JUST LACKED MOTIVATION TO DO IT.
I will provide two wheel chocks that I always carry in the car with me if you purchase the car.
OWNER HISTORY OF THIS BMW 550i
Owner #1
Leased in 2009
1/20/09 - 2/20/12 (3 yrs, 1 mo)
Indiana, US
Mileage Ended: [30,789]
Owner #2
Purchased in 2012
3/29/12 - 4/16/13 (1 yr)
Indiana, Pennsylvania
Mileage Ended: [45,176]
Owner #3
Purchased in 2012
5/10/14 - 4/3/15 (1 yr)
Indiana, Illinois
Mileage Ended: [62,601]
Owner #4
Purchased in 2015
4/29/15 - 3/14/16 (1 yr)
Indiana, Illinois
Mileage Ended: [72,420]
Owner #5 - Me. Records are all the way up top!
ALL SERVICE HISTORY I RECEIVED FROM PREVIOUS OWNERS.
CARFAX IS INCLUDED
SAFE-GAURD CONTRACT/SERVICE PROGRAM PROVIDED AS A COURTESY OF BMW NORTH AMERICA.
HISTORY BELOW:
REPAIR ORDER: 128964
REPAIR ORDER DATE: 11/12/08
REPAIR ENTRY DATE: 11/13/08
MILEAGE: [1]
DEFECT CODE/DESCRIPTION: 11999977BVQCI SPOT DELIVERY
REPAIR ORDER: 340861
REPAIR ORDER DATE: 4/2/09
REPAIR ENTRY DATE: 4/6/09
MILEAGE: [1,670]
DEFECT CODE/DESCRIPTION: 2300033900 manual transmission In 3rd gear unpleasant noises.
REPAIR ORDER: 342080
REPAIR ORDER DATE: 4/23/209
REPAIR ENTRY DATE: 4/27/09
MILEAGE: [2,494]
DEFECT CODE/DESCRIPTION: 2300033400 manual transmission In 3rd gear stiff to move.
REPAIR ORDER DATE: 4/23/09
MILEAGE: [2,494]
DEFECT CODE/DESCRIPTION: 99999977CLCORE CREDITS - AUTOMATIC VIA IWS-MINOOKA PDC
REPAIR ORDER: 360467
REPAIR ORDER DATE: 12/17/09
REPAIR ENTRY DATE: 12/21/09
MILEAGE: [9,026]
DEFECT CODE/DESCRIPTION: 8411511200Play, USB, centre console permanent failure.
REPAIR ORDER: 363772
REPAIR ORDER DATE: 02/03/10
REPAIR ENTRY DATE: 02/05/10
MILEAGE: [10,298]
DEFECT CODE/DESCRIPTION: 3620061200 Trigger transmitter RDC permanent failure.
61610077MPFT WIPER RUBBER INSERT-MP.
85990087MPMP-LOW MILEAGE ANNUAL OIL SERVICE.
REPAIR ORDER: 369513
REPAIR ORDER DATE: 04/27/10
REPAIR ENTRY DATE: 04/28/10
MILEAGE: [11,980]
DEFECT CODE/DESCRIPTION: 3531013900 Clutch pedal unpleasant noises.
85990089MPIST ENG OIL SERVICE-FULL MAINTENANCE.
85990501MPSTANDARD OPERATION MP.
REPAIR ORDER: 376830
REPAIR ORDER DATE: 07/27/10
REPAIR ENTRY DATE: 08/02/10
MILEAGE: [15,747]
DEFECT CODE/DESCRIPTION: 34000077MPBRAKE FLUID CHANGE-FULL MAINTENANCE PROGRAM.
64310237MPMICROFILTER REPLACEMENT.
REPAIR ORDER: 387249
REPAIR ORDER DATE: 12/10/10
REPAIR ENTRY DATE: 12/14/10
MILEAGE: [19,683]
DEFECT CODE/DESCRIPTION: 6610151200 Keybattery, remote control permanent failure.
MILEAGE: [19,683]
DEFECT CODE/DESCRIPTION: 0034910100Ck Brake Booster line N62, B34 04 10.
REPAIR ORDER: 389082
REPAIR ORDER DATE: 01/05/11
REPAIR ENTRY DATE: 01/06/11
MILEAGE: [20,798]
DEFECT CODE/DESCRIPTION: 6525027900FM (VHF) reception through aerial amplifier/ diversity incorrect connection/contact.
REPAIR ORDER: 391727
REPAIR ORDER DATE: 02/15/11
REPAIR ENTRY DATE: 02/21/11
MILEAGE: [21,613]
DEFECT CODE/DESCRIPTION: 6525107900FM (VHF) reception through aerial incorrect connection/contact.
6610151200 Key battery, remote control permanent failure.
REPAIR ORDER: 406563
REPAIR ORDER DATE: 08/18/11
REPAIR ENTRY DATE: 08/19/11
MILEAGE: [25,983]
DEFECT CODE/DESCRIPTION: 61610077MPFT WIPER RUBBER INSERT-MP
85990091 MPOIL SERVICE(MP) AFTER THE 1ST.
REPAIR ORDER: 420249
REPAIR ORDER DATE: 02/29/12
REPAIR ENTRY DATE: 2/29/12
MILEAGE: [30,598]
DEFECT CODE/DESCRIPTION: 5412104800 Frame seal slide/tilt sunroof (SHD) panoramic sunroof leaking.
85990101MPVEHICLE CHECK
85990101MPSTANDARD OPERATION MP
REPAIR ORDER: 427115
REPAIR ORDER DATE: 05/17/12
REPAIR ENTRY DATE: 05/17/12
MILEAGE: [31,841]
MILEAGE: [31,841]
DEFECT CODE/DESCRIPTION: 0061560300B61 14 12, Battery Cable Connection
REPAIR ORDER: 431280
REPAIR ORDER DATE: 07/10/12
REPAIR ENTRY DATE: 07/11/2012
MILEAGE: [33,434]
DEFECT CODE/DESCRIPTION: 1042036100 Throttle response under all operation conditions too rough.
REPAIR ORDER: 55361
REPAIR ORDER DATE: 02/07/13
REPAIR ENTRY DATE: 02/20/13
MILEAGE: [40,378]
DEFECT CODE/DESCRIPTION: 16110048UWFUEL TANK LEAKING.
61610077MP FT WIPER RUBBER INSERT-MP.
85990091 MP OIL SERVICE (MP) AFTER THE FIRST
REPAIR ORDER: 55361
REPAIR ORDER DATE: : 02/07/13
MILEAGE: [40,378]
DEFECT CODE/DESCRIPTION: 99999977UWHANDLING CHARGE UCPP $50.00 PER REPAIR VISIT.
REPAIR ORDER: 467903
REPAIR ORDER DATE: 11/20/13
REPAIR ENTRY DATE: 11/21/13
MILEAGE: [50,995]
DEFECT CODE/DESCRIPTION: 12610115UWOIL PRESSURE SWITCH PERMANENT MALFUNCTION.
32310539U STEERINGSPINDLE BOTTOM UNPLEASANT NOISES.
MILEAGE: [50,995]
REPAIR ORDER: 473891
REPAIR ORDER DATE: 02/24/14
REPAIR ENTRY DATE: 03/03/14
MILEAGE: [54,539]
DEFECT CODE/DESCRIPTION: 11720376MPENG AIR FILTER-DIRTY-MP
85990091 MPOIL SERVICE (MP) AFTER THE 1ST.
85990501 MPSTANDARD OPERATION MP
MILEAGE: [54,539]
DEFECT CODE/DESCRIPTION: 0063280100B63 06 13 E60 TAIL LIGHT
FEATURES:
NET VALUE: $70,895.00
Color: Titanium Silver Metallic
Upholstery: Black Dakota Leather
Cold Weather Package
Heated Steering Wheel (WHICH IVE NEVER KNOWN ABOUT LOL).
Heated front & rear seats.
Retractable headlight washer.
M Sport Package.
Adaptive Drive w/ ARS
Sport leather steering wheel
19" Wheels w/ Performance Tires
Shadowline Exterior Trim
Multi-Contour Seats
M Sport Suspension
Aerodynamic Kit
Tire Pressure Monitor
Space-Saver Spare
Universal garage-door opener
Comfort Access Keyless entry
Moonroof
Auto-dimming mirrors
Auto-dimming rearview mirror
Smokers Package
Bamboo Anthracite Wood Trim
Park Distance Control
Xenon Headlights
Adaptive Light Control
Navigation System
Voice-command
BMW Assist with Bluetooth
Satellite radio w/ 1 Year Sub.
Premium Hi-fi system
DVD Area coding, North America
BMW TeleServices
TeleService Control
iPod & USB adapter
Real Time Traffic Information
CCC Contribution
Variable Light Decoding
TeleService Activation
CO2 Control
Shipping package.
ID:	898765   Click image for larger version
ID:	898767   Click image for larger version
ID:	898771   Click image for larger version
ID:	898773   Click image for larger version
ID:	898777   Click image for larger version
Old 06-30-2020, 10:18 AM
Jay Arras's Avatar
Jay Arras Jay Arras is offline
Casual Fanatic
Mein Auto: 2007 530xi 6 speed manual
Wrong forum.
2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
