Cooling system - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X3 M, X5 M, X6 M, Z3 M & Z4 M > X3 M
X3 M
Old 02-18-2020, 07:04 AM
Kati2020 Kati2020 is offline
Mein Auto:
Cooling system
My x3 Fan wont come on when i plug CTS sensor. I see 9v wire voltage at ecm ground wire....other wire reads ok . Strangely i have 10v at thermostat signal white wire.....if i cut the wire i get 5v from ecm end.. And 10v from thermostat end ??? Any clues??
Old 02-18-2020, 07:15 AM
Doug Huffman's Avatar
Nuclear engineer
Engine cooling schematic wiring diagram
newTIS.infobeta
Home / BMW F97 X3 M SAV / Wiring Diagrams and Functional Description / Power train / Engine electronics / Engine cooling /
https://www.newtis.info/tisv2/a/en/f...ing/1Vndg8Yr9a
Old 02-18-2020, 01:24 PM
Mein Auto:
[QUOTE=Doug Huffman;13254649]newTIS.infobeta
https://www.newtis.info/tisv2/a/en/f...ing/1Vndg8Yr9a[/QUOTE
] Hi Doug , Im kinda new here so Thx 4 all the help... Just Curious do you know this fan acually works. I mean i know theyre DMe energized and vary by Rpm, temp etc.. But when are they supposed to kick in normally and or what speed. . besides full??
Old 02-18-2020, 02:11 PM
Nuclear engineer
See your PM
