N20 Castrol Black / Gold 5W-30 ? - Bimmerfest - BMW Forums
Old 07-08-2019, 09:22 AM
y2k_o__o y2k_o__o is offline
Mein Auto: z4
I am a Canadian owner from Vancouver, B.C and I recently got myself a 2015 x28i w/ N20 Engine.
I read castrol oil is the equivalent oil for Twinpower Turbo oil, but when I shop canadian tire / walmart online, there seems to be two different bottle (Black and Gold) oil.
Which one do you E84 folks use?
ID:	857435   Click image for larger version
Old 07-08-2019, 09:43 AM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
At Canadian Tire, they sell 0W-40 MotoMaster Formula 1 European 5L for under $30 on sale.
It's LLO1 spec.
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 07-08-2019, 09:55 AM
Yukoner Yukoner is offline
bimmerfest Supporting Member
Mein Auto: 2011 328i x-drive
Yes, you NEED to purchase oil that has the LL01 spec. Most formulas that are compliant will say "European Formula" or something to that effect on the bottle, but you need to double check that it meets the LL01 spec.
Also, most are putting in a 0w vs a 5w.
Not even sure if -40 degrees is cold anymore ?
Old 07-08-2019, 10:13 AM
Mein Auto: z4
And looking through walmart US online retail, there's a castrol edge that is formulated for Turbo GDI (gasoline direct injection)
none of them said ll01 or ll04 on all website
Old 07-08-2019, 10:38 AM
Unless you can confirm LL01 spec, don't buy it.
Old 07-08-2019, 04:13 PM
dooferorg dooferorg is offline
Mein Auto: 2013 BMW X1
I know on mine it talks of Dexos, which is a synthetic oil specification originally by GM. I would assume that certification would be something you'd see within the Canadian market too?
Old 07-08-2019, 04:56 PM
GM also had something called DexCool back in the 90s as well for their vehicles. That was their coolant.
Yes, LL01 shows on oils sold in Canada that conform to BMW's requirements. You MUST purchase LL01 oil. I don't care what's on sale at C-Tire this week.
Old 07-09-2019, 03:09 PM
Mein Auto: z4
I change oil between 6,000-8,000km (same thing for my 370z), does LL01 matter if I change this very frequent?
Old 07-09-2019, 04:11 PM
I'm sorry, but I don't understand why you keep going around in circles. The spec is LL01. Buy LL01. Why are you so bent on using oil that isn't made for your vehicle ? This is like saying "well, the car specs part #6776 for an air filter, but part #9845 physically fits, so it should work, right ?".
If you want to play around with non-spec oil in your $60,000.00 vehicle, go ahead Let us know all know how it turns out (hint: it isn't going to turn out well).
Old 07-09-2019, 04:21 PM
Mein Auto: z4
Thanks for your comment. I am not trying to save money or cut corners, but Castrol / Pennzoil LL01 oil are very rare in Canadian market here. I've already gone to a few in store CT or Walmart, non of them have them on the shelves.
I guess I'll better off with OEM oil
Old 07-09-2019, 06:15 PM
stonex1's Avatar
Did you not see the MotoMaster formula 1 oil I mentioned earlier?
It's stocked in my local CT store.
It says right on the back label, meets BMW LL01 spec.
2013 X1
Old 07-09-2019, 11:52 PM
Mein Auto: z4
I picked up two jugs of these on my way home today @ marine drive CT.
my first time using motomaster oil, will keep you all posted on this
Old 07-10-2019, 07:47 AM
From what I understand, the specifics of a synthetic formulation are very important for turboed vehicles (re: our X1s) because of the heat and wear requirements. While frequent oil changes are good, it is important to understand that while the oil is in use it's subjected to higher heat than conventional oils can handle. So, in short as has been beaten to death.. just follow the recommended specs
People aren't trying to get you to spend more for the fun of it.. it really does matter.
Old 07-10-2019, 08:43 AM
Ummmmmmm, it's not rare. CTire's website shows 3 different Castrol options when you search.
That being said, don't go to CTire or Walmart then. Go to Lordco. Or NAPA. Or, failing all that, go to a BMW dealership and buy it right from the parts department. You're on the lower mainland..... Trust me, it's widely available oil.
There's plenty of places to find LL-01 oil. I live in the Yukon. I have multiple places where it can be found. Sorry, but "LL01 oil are very rare in Canadian market here" is complete nonsense and incredibly untrue.
Old 07-10-2019, 01:35 PM
I saw this too: https://www.fcpeuro.com/products/bmw...3196kt1-lm-awd .. in case it helps anyone finding this thread.
Old 07-10-2019, 04:15 PM
mcdanielvzw mcdanielvzw is offline
Mein Auto: BMW X1 xDrive35i
Not that you can't do this with LiquiMoly from FCPEuro, but you can also get the BMW brand oil and after the first oil change you can send your used oil back for a full refund minus shipping. Might not be worth it for Canada, but from FL to where they are it's about $23.
