Panoramic sunroof Motor works won't move - Bimmerfest - BMW Forums
Old 07-12-2019, 01:48 PM
8eth 8eth is offline
Mein Auto:
I have a 2014 X1 S-Drive. The sunroof won't budge! I have tried every single things reset, battery disconnect and reconnected then reset, pulled motor to try to be able to manually move the sunshade and glass, tried to manually close the sunroof with the hex... nothing works because I can't make it budge. The glass is closed with the exception that the front is at a tilt. The sunshade is not moving, it is shut with the exception that it is open about 6 inches towards the rear. I am unable to move those as well. I'm assuming that it's stuck in the track? Please any help!
ID:	857893   Click image for larger version
ID:	857895   Click image for larger version
Old 07-12-2019, 02:49 PM
Doug Huffman's Avatar
Nuclear engineer
https://www.newtis.info/tisv2/a/en/e...unroof/XKRI1q8
https://www.newtis.info/tisv2/a/en/e...arch?q=SunRoof
Old 07-12-2019, 06:14 PM
Mein Auto:
Doug Huffman... I appreciate your time so much! Thank you for the links! I think I will now be able to work on it this weekend with the help you gave me! I'm so eternally grateful!
Old 07-15-2019, 10:07 AM
mreric mreric is offline
Mein Auto: 2015 BMW X1 Xdrive E84
remember to post back of the result and hopefully it will help others
