How remove fog lamp? - Bimmerfest - BMW Forums
Old 03-31-2019, 11:32 AM
Rick Lee Rick Lee is offline
Mein Auto: Porsches, BMW's
Mrs. Lee's 2014 X1 has a busted fog light lens on the driver's side. No Youtube video I found shows anything close to how her fog lights are mounted. Some videos say to just insert a flat tip screwdriver above the lens and it pops out. Not at all on this car. What does the screw in the one hole at around 10 o'clock do? Adjust aiming or release fog light housing? I can't see anything or feel much by removing the small plastic cover inside the wheel well. I will probably have to remove the wheel to get better access. Does this job require removing the whole plastic wheel well liner? I can't believe it's this involved.
And I've also seen on some sites that for BMW fog lights, the driver's side is considered the right side. Catalogues list them as left or right, not driver or passenger. This is US-spec, lefthand driver side. Do I order left or right fog light? Thanks.
2014 BMW X1
2015 BMW S1000R
2017 BMW 330ix wagon
Old 03-31-2019, 04:21 PM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
I replaced my fog lamp a few years ago.
Thread here.
Easiest method is to remove the plastic panel underneath the front end and gain access that way.
Yes, the little hole is for adjustment.
I believe left would be drivers side, but maybe double check with part number.
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 03-31-2019, 04:24 PM
Ok, thanks. Ordered part today, will knock it out next weekend.
2014 BMW X1
2015 BMW S1000R
Old 04-02-2019, 12:32 PM
mreric mreric is offline
Mein Auto: 2015 BMW X1 Xdrive E84
i just added vinyl protection to the fog light and headlights, highly suggested.
Similar Threads
E63/64 DIY: CIC Retrofit for BMW E63s - (Long and Pic Heavy) AlexMSFT 6 Series DIY 13 08-22-2019 11:40 AM
Drivers LED Fog Light Lamp - 2014 740Li xdrive drmel 7 Series - F01 / F02 (2009 - 2015) 4 01-29-2019 07:51 PM
Fog lamp change Markdm73 Ask-A-BMW-Dealer 3 12-08-2018 11:53 AM
Where is the relay panel for the K47 fog lamp relay located? 52silverfox E85 / E86 Z4 (2003-2008) 0 06-04-2018 09:12 AM
91 850i Heater Core Removal Instructions Wanted nicko 7 Series & 8 Series 1 10-18-2004 11:56 PM
