Remove WiFi option? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > G30 (2017 - Current)
The next generation 5 Series, chassis code G30, arrives at dealers in February 2017. Looking like a scaled down 7 Series and riding on the CLAR platform, the new 5 Series will have a focus on lightweight and sporty performance. Engines options will come from BMW's new B family for the 530 and 540 and a turbocharged V8 for the M550i. Read more about the 2017 5 Series
Old 02-10-2020, 08:48 PM
rcliff1 rcliff1 is offline
Mein Auto: 2017 540
Remove WiFi option?
Is it possible for dealer to remove the WiFi option from a custom 2020 build order. Can't seem to do with online configurator
Current: 2017 BMW 540xi
Prior: 2014 BMW 528xi
Prior: 2011 BMW 535xi
Prior: 2004 BMW 745i
Prior: 2003 BMW Z4 6MT
Prior: 1997 BMW 528i 5MT
Old 02-10-2020, 09:31 PM
Why? You donít have to use it if you donít want it.
Same goes for eco mode.
Sent from my iPad using Bimmerfest
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
Old 02-10-2020, 10:03 PM
Mein Auto: 2017 540
Originally Posted by FredoinSF View Post
Why? You don't have to use it if you don't want it.
Don't want to have a hotspot in car transmitting all the time. Apparently there's no way to completely turn off the WiFi radio if it's present
Old 02-11-2020, 03:51 AM
Pierre Louis Pierre Louis is online now
Mein Auto: 2016 535d
Yes, a wifi hotspot is probably never used and may invite hackers/government surveillance. Good thought.
Old 02-11-2020, 05:57 AM
LogicalApex LogicalApex is offline
Mein Auto: 2020 530xe
WiFi is included in MY2020 so I am going to go out on a limb and say no.
But you can turn off WiFi in iDrive.
Old 02-11-2020, 06:19 AM
runbuh runbuh is offline
Mein Auto: 2020 M550i
I do not believe that you will be able to use Apple CarPlay without it, in case that matters.
Old 02-16-2020, 12:56 AM
Not sure where you got this, but according to Apple, its wireless Bluetooth or wired connection for CarPlay.
https://support.apple.com/en-us/HT205634
Old 02-16-2020, 02:53 AM
stevelup stevelup is offline
Mein Auto: G30 530e M-Sport
The WiFi hotspot is not active unless you enable it. So nothing to worry about there, just leave it deselected.
Wireless Apple CarPlay uses bluetooth for the initial connection (first time pairing), then switches to WiFi. You cannot have wireless CarPlay without WiFi.
Old 02-16-2020, 04:37 AM
BMW documentation indicates otherwise (read your owner's manual), and you can verify that by disabling WiFi on your phone and trying to connect.
https://www.bmwusa.com/owners-manuals.html
Name:	Annotation 2020-02-16 072920.jpg
Even the YouTube videos indicate this (note the closed caption text):
Name:	Annotation 2020-02-16 062718.jpg
That screen capture came from this video (go to the 1:18 mark):
Old 02-16-2020, 07:07 AM
Honda does not require wifi to be on. But is also requires a wired connection. So no, wifi is not necessary even if BMW does it that way.
Old 02-16-2020, 08:25 AM
BlueTooth is used for the initial paring process, but Wireless is needed for Wireless CarPlay as BlueTooth lacks the bandwidth needed for CarPlay. This isn't a BMW limitation, but an Apple one.
https://connectedcarlife.com/tech/ho...-carplay-work/
BMW didn't implement wired CarPlay only wireless. So, yes, they need WiFi.
Old 02-16-2020, 08:49 AM
Sorry to sound like a butthead, here, but why did you bring this up to try and confuse people? BMW G30's clearly require WiFi for CarPlay. All cars require WiFi for wireless CarPlay. Bringing up wired CarPlay in this thread seems to serve no purpose other than to say "I'm smart". Yeah - my post comes across as an "I'm smart, too" post.
I just don't want to confuse people about what's required for a BMW G30.
Old 02-16-2020, 08:52 AM
"Originally Posted by runbuh View Post
I do not believe that you will be able to use Apple CarPlay without it, in case that matters."
No mention of wired or wireless.
Old 02-16-2020, 09:11 AM
Originally Posted by pierre louis View Post
"originally posted by runbuh view post
i do not believe that you will be able to use apple carplay without it, in case that matters."
no mention of wired or wireless.
what is the title of this thread??????
Old 02-16-2020, 09:25 AM
You tell me. And mention how it says Apple Car Play so invisibly...
Old 02-16-2020, 09:41 AM
When the OP said
"Is it possible for dealer to remove the WiFi option from a custom 2020 build order. Can't seem to do with online configurator"
and I replied with:
"I do not believe that you will be able to use Apple CarPlay without it, in case that matters."
What do you think "it" meant, in this case? A grilled-cheese sandwich?
Thanks for posting!
Old 02-16-2020, 09:46 AM
and I replied with:
Thanks for posting!
Yeah, and I asked where you got that, not specifying anything else. I only asked. That must be rude in your culture to ask.
So, please explain why you need Wifi for Apple Car Play, even though its not necessary from the Apple web site...
Old 02-16-2020, 10:18 AM
Ok - English may not be your primary language. I apologize for the confusion. Please be aware that the link you provided to Apple is not a full and complete list of requirements for CarPlay. For example, I only see mention of iOS 13 on that page, but there are earlier versions of iOS that support CarPlay.
Go to slide 41 here: https://devstreaming-cdn.apple.com/v...stems.pdf?dl=1
Old 02-16-2020, 11:23 AM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 540i; 428 GC; 340i 6MT
runbuh, Bimmerfest allows you to "Ignore" certain users. Click on their user name in this thread, and select "Ignore". Some folks have a habit of repeating irrelevant stuff and then getting combative when they are called out on it. I ignored this particular user over a year ago, and have no regrets.
Current BMW's:
2017 540i MSport
2017 330i Sport
Prior BMW's
2018 340i RWD 6MT MSport
2016 428 GC MSport
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 02-16-2020, 12:55 PM
Ah - a loyal member of the "Royal Order of Those Who Argue With Stop Signs". Thanks for the tip.
Old 02-16-2020, 02:00 PM
Bebespapa Bebespapa is offline
Mein Auto: 2014 428 GC
You have to pay to use Wi-Fi. Just don't pay or never authorize it. Has nothing to do with Apple car play. The cars do not come with it active, capable but not activated. My car play and connected app work fine without it.
In the Great North...
2018 530e Xdrive
2015 428I Xdrive - sold
2011 X3 35I - sold
2017 Honda Ridgeline. Gotta have a truck.
Old 02-16-2020, 02:54 PM
JDSX JDSX is offline
Mein Auto: 2020 BMW M550i xDrive
The BMW will need wifi in order to use wireless CarPlay but it doesn't need the paid hotspot subscription. There's really no reason to not have it anyway since you don't need to activate that subscription unless you really want to.
2020 M550i xDrive
driving assistance plus, dynamic handling, luxury seating
parking assistance, executive, heated steering wheel
front and rear heated seats, night vision, remote control parking
Previous: 2017 540i xDrive, 2014 535i xDrive, 2012 X5 xDrive35i Premium
jjsC6 jjsC6 is offline
Mein Auto: See Sig
Can I disable my camshafts? I heard the car can't run without them. Is that true?
2017 BMW 540 M-Sport Carbon Black/Ivory
2016 Lexus GX 460---Wife's car
Bikes...2017 Yamaha FJR1300---2017 KTM 1290 Superduke GT---2012 Ducati Panigale
Previous BMW: 2012 550 M-Sport
Old 02-16-2020, 02:55 PM
Mein Auto: See Sig
duplicate. Sorry
Old 02-16-2020, 04:20 PM
Just to clarify - you absolutely MUST have WiFi installed and enabled to use CarPlay in a G30. A wireless hotspot subscription is another story. This CarPlay/WiFi requirement is documented in your owner's manual, and something that you can confirm in your own car's settings (this is from my car).
