Basis Infotainment System (Radio UKL NF) HELP - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F12 / F13 (2012 - 2018)
The all new 3rd generation 6 series coupe (F13) and convertible (F12) forum. The F06 BMW 6 Series Gran Coupe forum is here
Old 01-21-2020, 06:40 AM
Keesimo Keesimo is offline
Mein Auto:
So I'm looking everywhere to fix my problem. I have no audio, no sensor beeps nor chimes.
2013 650i F13
These are the codes from Carly.
Fault code: B7F821 :Speaker output lines front left: line break
Fault code: B7F825 :Speaker output lines front right: line break
Fault code: B7F829 :Speaker output lines rear left: line break
Fault code: B7F82D :Speaker output lines rear right: line break
Fault code: B7F8B4 :Connection head-unit to SDARS antenna foot: line break
Fault code: INFO 93000C Audio Source: Channel can not book in time (allocate)
Fault code: INFO 93000D Audio Source: Channel can not timely release (deallocate)
Fault code: INFO 93000F MOST node: signed out at least one function block
Fault code: INFO 100D01 Error in FZM Embassy
I am not getting any error codes.
Old 01-27-2020, 05:02 AM
645/333's Avatar
645/333 645/333 is online now
Michael
Never had any issues with my car so not easy to help, but looking at all the codes suggest either a simple cable and plug issue, blown fuse or the unit /module has failed. Hope you find it !!
Old 01-27-2020, 06:36 AM
Mein Auto:
Thanks for the reply. I'm going to look for a fuse, I've checked the panel and the back. The panel in the front is a pain to get to.
