Clunking noise over bumps and down ramps - Bimmerfest - BMW Forums
Old 01-21-2020, 09:08 PM
Rslocombe Rslocombe is offline
Mein Auto:
My 2010 convertible 650i E64 is making some noises as I turn and go up and down slopes at low speed. Highway driving is fine. Tire wear looks normal and I can't see any play in the suspension. I had a look and there are a LOT of bushings back there! Any suggestions where to start? I also read something about retorquing - what does that mean?
Old 01-22-2020, 07:34 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
I would inspect the bar that runs across the engine, that is V shaped, the bolts get loose over time. I would also inspect the lower control arm bushings for any missing rubber at the joints. The rubber will crack & allow the arm to move, leaving missing chunks of rubber gone. You can also push & pull on the arms while doing this for movement. Re-torquing a bolt is simply checking it for the proper amount of torque. If you do not have a torque wrench, Harbor freight sells them for around 15.00 each. I have a 1/4", 3/8", & a 1/2" torque wrench depending on which works best for the job I am working on. A 3/8" torque wrench will do most small to medium jobs.
