New here? Read This First! - Page 3 - Bimmerfest - BMW Forums
Old 05-08-2019, 11:09 PM
Mistarealitee Mistarealitee is offline
Mein Auto:
Hi new here. 05 530i. Car is hesitating intermittently at stoplights on idle. Engine malfunction comes on when on the expressway when I speed up. Light goes off before I make it home or if I turn the car off. Any ideas?
Old 05-09-2019, 04:42 AM
fred530xi fred530xi is offline
Mein Auto: 2007 530xi
Recommend that you start a new thread with your issue. Provide more information; do you have a code reader specific for BMWs? Number of miles? Recent work?
Good luck
Fred
Old 05-09-2019, 07:44 AM
Mein Auto:
05 530i 193k Miles
Let's see......On this car I've had for 3 years, I've replaced 2 pcv valves, 2 thermostats, intake manifold gaskets, valve cover gasket, 2 sets of plugs, a set of coil packs plus an extra one, mass air flow sensor, cabin filter. The latest thing I had done was new plugs and 1 coil pack, and the valve cover gasket couple weeks ago. Now it's shaking when idling. Hasn't shut off but feels like it wants to. Hesitation when I accelerate. Sometimes it drives fine. Then engine failure light comes on. But if I turn the car off and back on, light goes off. Very confusing car. ***x1f914;Any suggestions?
Old 05-09-2019, 08:34 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: e39, e83, e60
scan it properly get good
live data,
fuel pressure reading..
vitals
Specializing In Breaking Things Professionally
15486372<-----
Old 05-10-2019, 09:31 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
Mistar, seriously, start a new thread. This one is for training materials only, so folks don't have to wade through long discussions for educational materials. Thanks!!
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 12+ Years
Old 06-19-2019, 08:41 AM
banglenot's Avatar
New "V 4.8 So You Just Bought an E60" released at the google drive URL in post #33.
The URL is where all further releases will be accessible.
Discussion of the three major gasket failures (leaks) on the N52 engine: Valve cover; oil filter assembly; and oil pan. All likely past 100-120Kmi.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 06-19-2019, 06:59 PM
ashlosdad ashlosdad is offline
Mein Auto: looking at 05 325ci
New to BMW
Hi, I'm new to BMW so I have a couple of questions. We bought a 2004 525 for my daughter's first car. I have 2 Pontiac G8s. There are a couple of websites that specialize in aftermarket and replacement parts ie g8only.com and gtog8ta.com. Is there any site like these for BMW? Is there a "go to" site that everyone uses?
Thanks in advance
Old 06-20-2019, 03:51 AM
plus1111 plus1111 is offline
Mein Auto: 2008 535xi
There are quite a few. I use fcpeuro, ecstuning, and pelican parts quite a bit. I also use good old Rock Auto. They have expanded their BMW parts line a lot. There are several others.
Old 06-24-2019, 01:01 PM
banglenot's Avatar
Thanks in advance
what plus1111 said. And, look at the google drive doc in post 33 of this thread. There is a section on how to buy parts for BMW's -- specifically OEM rather than BMW branded parts. Add oembimmerparts to the list. But key issue is only buy from stores that have built a name in the community -- not from Amazon or Ebay. Best way to make sure you get OEM that's really OEM, or BMW that really BMW.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 06-30-2019, 07:26 AM
banglenot's Avatar
Really Useful Doc for your Library
The attached "Advanced Vehicle Diagnostics" doc is rich trove of information on:
ISTA procedures
Bus Structures
Reading the wiring diagrams
Using a DVM to test circuits
Parasitic draw with DVM (on page 216)
O'scope usage (with sample signals and tests on various buses and sensors)
Definitely a keeper.
Thanks to Doug Huffman for it.
File Type: pdf Advanced Vehicle Diagnosis -ISTA Manual 07-2013.pdf (7.14 MB, 30 views)
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 07-15-2019, 05:57 PM
Thanks everyone
Old 08-18-2019, 12:27 PM
cfig cfig is offline
Moderator approval
Hi
Can someone tell me how moderator approval of posts works?
I posted a Reply in a running thread early on a Sunday morning. I got a message that the post was waiting for "moderator approval". It's 15 hours later and I can find no trace of my post.
I don't see any emails from the forum or any private messages.
Should I just be patient? Or try posting again?
Old 08-18-2019, 04:37 PM
banglenot's Avatar
Try again in that thread or another. This one is used for E60 education information. There is another thread used for test purposes and learning how the forum works.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 08-23-2019, 07:29 PM
Dfhii Dfhii is offline
Mein Auto: 2009 535i XDrive
Very informative. Thank You!
Old 08-27-2019, 09:42 AM
Are Forums moderated?
I've tried to post two replies now, one to the E60 forum and one to BMW coding. I could post here and to the Test forum but apparently no where else.
My browser basically says "waiting for moderator approval" - which never comes. No acknowledgement... nothing.
Logged off, logged back in, reposted: No problems.
Old 08-29-2019, 10:51 AM
banglenot's Avatar
cfig, this isn't the thread to get your question answered. Thanks.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
