Complete rear and front suspension overhaul and upgrades . - Page 14 - Bimmerfest - BMW Forums
Old 03-07-2019, 08:18 PM
yellaboyla yellaboyla is offline
Mein Auto: 2005 545i
Originally Posted by H F View Post
Ok ,, here you go .. The bolts and lock nuts that need to be replaced are in the charts . I went ahead and posted all the torque specs you'll need ,, along with my written cheat sheet . I went to the dealer and got all the nuts and bolts ..
Just curious...Are these bolts 1 time use or were you just concerned with the stresses they have taken?
Old 03-07-2019, 08:52 PM
H F H F is offline
If I remember correctly they are one time use . Those charts are from my Bentley manual which states to replace them and some lock nuts . Also keep in mind that new nuts come with the control arms . And those bolts need to be replaced according to the Bentley manual .
Old 03-08-2019, 06:50 AM
thanks sir!
Old 03-08-2019, 10:20 PM
Markst Markst is offline
Mein Auto: BMW 5
Why is your cheat sheet different from the bentley manual?
The ball joint nuts in the front steering knuckle should all be 165NM, your sheet says 80/80/165.
Old 03-08-2019, 11:33 PM
oldiegoodie oldiegoodie is offline
Mein Auto: 2007 550i 6MT
+1
Tie rod end to knuckle should be 165 Nm
Wishbone swivel to knuckle should be 165 Nm
Tension strut to knuckle should be 165 Nm
2007 E60 550i Sport 6MT
Old 03-09-2019, 04:37 PM
H F H F is offline
Actually they are not the same ,,, the wish bone and ball joint torque is 80Nm . See attached information which supports the torque specs on my cheat sheet ..
Originally Posted by oldiegoodie View Post
+1
Sorry MR goodie but your incorrect here bud , they are not all the same torque .. 165Nm for the ball joint and wishbones is way way too much torque for the size of bolts . which could lead to stripped nuts or bolts ,or even a cracked bolt from too much torque ..
https://www.newtis.info/tisv2/a/en/e...mounts/5jtS88K
6AZ Wishbone to swivel bearing/steering knuckle
E39, E53, E52, E83, E60 / 4WD, E61 /
4WD, E67 Replace nut 80Nm
https://www.newtis.info/tisv2/a/en/e...damper/5VUOqKc
3AZ Tie rod end to steering knuckle / swivel bearing
E53, E60 / Four Wheel Drive, E61 /
Four Wheel Drive, E67, E83 Replace nut . 80 Nm
Old 03-09-2019, 08:17 PM
Mein Auto: BMW 5
H F you are looking at the wrong line.
80Nm is the spec for xdrive models, which actually have different wishbones and tie rod ends. I have highlighted in green the correct spec.
I am assuming "Rear end" is an inaccurate translation for Rear wheel drive models.
Also, all the nuts and ball joints are identical, why would one be ok at 165Nm and not the other two?
Old 03-09-2019, 09:07 PM
H F H F is offline
You know what , I should have caught that !! .. YOU guys are totally right ..
Thanks Markst and oldie ,, for pointing that out ,, appreciate the correction ..
Ill torque them up to 165 . Think that was my only mistake out of this whole project , That's not bad at all ..
Old 03-09-2019, 11:43 PM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: e39, e83, e60
lol i guess now is a good time to say, I wouldn't have used the torque wrench here anyway
only did this "improperly" dozens if not hundreds of times.. never had anything fall apart or wear out or anything like that
Specializing In Breaking Things Professionally
15486372<-----
Old 03-10-2019, 09:19 AM
You could get together with Joel Osteen and help him work on his car. He doesn't use torque wrenches either. (just kidding)
Old 03-10-2019, 10:49 AM
H F H F is offline
There are somethings that are not that critical not to torque . But ,, when it comes to steering and suspension components , I'd say it's good practice to torque them down to specs ..
Old 03-10-2019, 10:53 AM
H F H F is offline
Ha ! That made me laugh . Good one
Old 03-10-2019, 01:59 PM
Burning2nd's Avatar
Under the lift arms
check this out.. i was 10 and a half, like 36" tall lol
i had a yz125 *i couldn't stop with it i had to dismount it like a horse or find a tree to lean up on, anyway.. i did a top end on it..
didnt torque the head, found out all that jazz about what you can get away with, and what you cant get away with when it comes to using torque, well i was in the woods of bangor maine some 500 miles away on vacation with my parents
bike ran for a good hour b4 it lost compression...
point is im experienced, so things like suspension toruqe'n is for people who dont want there **** to fall apart, Me heads, bottem ends, flywheels and clutches.. rear end dif's, internals... By the numbers.... water pumps naw lol
this other guy has spread so much rice on his bmw Idk what to say.. but im calling it.. 20 months he will be no more Ill buy a round for anyone who wants that bet
15486372<-----
Old 07-04-2019, 02:12 PM
Pouch4455 Pouch4455 is offline
Mein Auto:
Wow a lot of great reading!!! I have done the entire suspension, but keep driving the sachs front struts beyond their abilities. They always leak. Second set in 20,000 miles. Final thoughts on KW,V3???
Old 09-11-2019, 09:21 PM
BickUW89's Avatar
BickUW89 BickUW89 is offline
Go Dawgs!
Mein Auto: 2010 E60 550i ZSP 6MT
Verdict?
HF: it's been a few months since you completed this upgrade. Can you give a summary of how the car feels now, and your level of satisfaction with the results?
I ask because Winter is Coming, and I'm planning to put my 2010 E60 on blocks soon to clean up the slop in my front suspension, and plan to use the winter months here in Seattle to dink away at it while I have no pressure to get the girl back on the road. I'm pretty much thinking at this point that I'll follow your well-worn path, but...
If you have any second thoughts on the parts or choices you made, after getting some miles on the wheels and windshield time, I'd appreciate the input.
My "newish"-to-me 2010 E60 550i has ~72K miles on it, only 2K of which I am responsible for. It feels a little sloppy to me, and has quite a bit of understeer that I want to clean up. I know from prior experience that this thing can corner and behave better than this.
Right now, from what I can see, you're kind of THE MAN, so I'd really appreciate your feedback. Is your setup gonna rattle my fillings? Does it still need "something," or is it just right. Go!
BMW Ergo Zoom
IMHO: E39 < E60 > F10
In the Stable:
2010 E60 550i ZSP 6MT IAS
2019 G30 M550xi (ED July 8, 2019)
Retired:
2016 F82 ///M4 ZCP (ED July 6, 2016)
2011 F10 535xi ZSP (ED July 15, 2011)
2008 E60 550i ZSP (ED July 22, 2008)
2000 E39 540i ZSP 6MT
Member BMWCCA #402733
Old 09-18-2019, 05:02 AM
J F J F is online now
A gear in the machine
Mein Auto: 2005 545i, 2008 X3 3.0si
Hey BickUW89
My Dad H F said that it handles comparably to his stock Porsche 997. Different feel and different driving styles obviously but as far as it hit, hugged, and exited them turns I would have to agree that it is a similar experience.
I am also sad to let everyone here know that my Dad passed away last week from cancer, I talked about it in my introduction post.
https://www.bimmerfest.com/forums/sh....php?t=1347051
Old 09-18-2019, 07:43 AM
bimmer7410 bimmer7410 is offline
Mein Auto: 2003 540i
Originally Posted by J F View Post
Hey BickUW89
Again, RIP HF...
Old 09-18-2019, 02:05 PM
Burning2nd's Avatar
Under the lift arms
HF passed away?
15486372<-----
Old 09-18-2019, 02:06 PM
HF passed away?
Saddening!
Sent from my SM-G950W using Tapatalk
Old 09-18-2019, 06:38 PM
BickUW89's Avatar
Go Dawgs!
Hey BickUW89
Oh my, so sorry to hear, but thank you so much for responding and carrying the torch.
You know, his thread on the suspension build is legendary on this forum. One of my all-time favorites, and I'm going to be doing these mods to my own E60 this winter. Now it will be a tribute to his work, as well as a welcome upgrade. I learned a ton just from seeing the meticulousness of his workspace in all the pictures he included, and have tried to emulate it now whenever I work on my own car.
I hope to continue seeing you on this forum! May your family be blessed.
BMW Ergo Zoom
In the Stable:
Retired:
Old 09-19-2019, 02:19 AM
bimmerfan52 bimmerfan52 is offline
Mein Auto: 545i
JF-
I look forward to you carrying the family mantle on the BMW 545i (or your own model of choice) if that is your love!
I had many enjoyable conversations with your father on the forum regarding the 545i.
You could tell he truly appreciated the German engineering of BMW, while at the same time lamenting with the rest of us the ability of BMW engineers to over-complicate almost anything on the car.
And it was obvious he truly enjoyed people, as he was considerate and patient with newbies, while always being well researched and prepared to hold his own with the more knowledgeable members of the forum that we all count on for answers.
My condolences to your family.
Best regards
BimmerFan52
