Complete rear and front suspension overhaul and upgrades . - Page 4 - Bimmerfest - BMW Forums
Old 09-26-2018, 12:03 PM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
bmws drift great, start in the snow first, where its easy to break loose.. Then dirt and rain,
bend a few control arms
I dont have the balls for dry drifting
Specializing In Breaking Things Professionally
15486372<-----
Old 09-27-2018, 12:22 PM
Kurt_ Kurt_ is offline
Mein Auto: 2008 535xit
The awd drifts great too... When you can break it loose.
The nannies really make a difference when cornering. When I'm drifting, I like to press DTC for limited nannies. I find it corners better than turning them all off but without the throttle limiting aspect of full nanny mode.
But when traction isn't a concern, full nannies give me a higher slip threshold than without. It's not just a perceived difference.
Old 09-27-2018, 12:34 PM
Burning2nd's Avatar
Under the lift arms
i find the allwheel drift to be closer to riding a quad
15486372<-----
Old 09-28-2018, 07:52 PM
H F H F is offline
Mein Auto: 2005 545i
Originally Posted by oldiegoodie View Post
I am, literally, afraid to turn off all systems completely due to lack of proper LSD system. Trying to drift the car out of corners without LSD, talking about the 1 tire spinner here, could be costly.
While I'm waiting on parts ,, Since we're on the subject of drifting and to remain on topic ,, pause at 6:55 and check out the bitchen suspension for a second , lol .. AWD Mustang drift . Enjoy ..
And this is what I call ,, carving drifting the canyons ..
Old 09-28-2018, 11:46 PM
oldiegoodie oldiegoodie is offline
Mein Auto: 2007 550i 6MT
I've seen Ken Block's previous videos with the rally cars but never anything like this, especially the hill run! He's got INSANE skills! I was grinning the whole time watching this!
Old 10-02-2018, 11:57 PM
H F H F is offline
Mee too . I want to be just like him when I grow up , lol .
Old 10-03-2018, 12:17 AM
H F H F is offline
So the stock bushings came in I ordered from Fcp ..
So in order to confirm that these bushings part number # 3493401 and #3493301 that are missing part numbers on real oem will fit in the swing arm .
Here is my findings, I have come to a conclusion now that I have them on hand ..
Bushing #3493401 is no sweat , fits inside the beveled inside edge and don't see any issues pressing that one into the swing arm . Which is the one for the camber adjustment essentric bolt ..
Ok ,, the other one # 3493301 has to be compressed (closed )first .. In order to fit inside the beveled inside edge of the bore .
The original actually expanded after pulling it out .. The bore is 50.93 mm using my cheap harbor freight calipers . After removal the original bushing,,it expanded to 52.87 mm , a 1.94 mm expansion .. Given its been on there 13 years , it stayed compressed some .
After checking the circumference of the bushing sleeves with a zip tie . Both new and old were exactly identical .. Meaning once compressed the new one will press into the bore of the swing arm ..
The new bushing with three hose clamps , i got it to close to 52.26 mm the bore measured 50.93mm that = 1.33 mm difference .
Ok ,,the outer beveled edge on the swing arm measured 52.02 and I closed the new one to 52.26 .. Difference = 0.24 mm . Man ,, that's not very much 1/4 of a mm . So I'm calling that the difference in my measuring tolerance ..
So given the evidence ,, got it sorted out .. I'm going to say ,,,that these bushings will fit the swing arm .. ..
ID:	821475   Click image for larger version
ID:	821477   Click image for larger version
ID:	821479   Click image for larger version
ID:	821481   Click image for larger version
ID:	821485   Click image for larger version
ID:	821487   Click image for larger version
ID:	821489   Click image for larger version
ID:	821491   Click image for larger version
ID:	821495   Click image for larger version
Old 10-03-2018, 12:22 AM
Same here, although I must say that I'm pushing close to the 50 mark and still haven't grown up, especially when it comes to cars. With that said, I don't think it's ever going to happen. I think I've got Octane booster running in my veins.
Old 10-03-2018, 03:15 AM
Burning2nd's Avatar
Under the lift arms
so what are we waiting on arrival of the powerflex bushings?
15486372<-----
Old 10-03-2018, 07:50 AM
H F H F is offline
Yes ,, waiting on power flex . Also think I over looked something . Think I'm also going to change the ARS sway bar bushings too . I don't want to exclude them , gotta give my ARS Some love too ...
Also the extensions for the rebound adjustment that set on the top of the rods . On the rears I can install them after the coil overs are installed . But the fronts have to be on first because there is not enough space in the strut tower hole after the coil overs are in . So I have to pull the fronts off install the 3 inch extension, then put them back in .
Old 10-03-2018, 08:01 AM
H F H F is offline
So you're a half century old , born in the mid 1900's ? Lol .
Old 10-03-2018, 09:58 AM
Old 10-03-2018, 12:30 PM
H F H F is offline
Ha ! that's funny ,, grandpa's getting serious ..
Old 10-03-2018, 01:10 PM
Burning2nd's Avatar
Under the lift arms
lol thats gonna be me for sure
thats how the last generation did it..
15486372<-----
Old 10-03-2018, 01:52 PM
Git some, b1tches!
Ken Block uses a special hand brake in his drift cars. I'm fuzzy on the specifics, but that's a big part of how he can pull off such pinpoint drifts.
Old 10-03-2018, 02:30 PM
The key phrase is "drift car hand brake". These lock the wheels without much force. I think he has ability to switch from 4 to 2 wheel drive on the fly and that's the magic sweet spot of what he can do the more better.
Git some, b1tches!
Sent from my SM-G950W using Tapatalk
2007 E60 550i Sport 6MT
Old 10-03-2018, 02:34 PM
I think you guys will appreciate this suspension upgrade:
Old 10-03-2018, 02:51 PM
motohunter4's Avatar
motohunter4 motohunter4 is offline
Gearhead
Mein Auto: 85 735i Euro, 08 550i/6
I need that on my golf cart.
Sent from my LGLS755 using Tapatalk
Old 10-03-2018, 03:39 PM
H F H F is offline
Ha !! thought that was you ..
Old 10-03-2018, 03:40 PM
H F H F is offline
Ya ,, that truck is pretty rad .
Old 10-03-2018, 03:45 PM
H F H F is offline
ya ,, and do a nice lawn job on the course ..
Old 10-03-2018, 05:51 PM
H F H F is offline
Bushings just came in , and all the parts are ready to go in .. Only waiting on the rebound extensions . But now I have plenty to do ...
ID:	821599   Click image for larger version
Old 10-03-2018, 11:23 PM
H F H F is offline
Managed to get the bushings in the swing arm . Don't know how I would have done it with out my universal bushing tool . It just paid for its self putting in the front one piece bushing alone . It gave me a little bit of a fight , but I got it in ..
ID:	821619   Click image for larger version
ID:	821621   Click image for larger version
ID:	821623   Click image for larger version
ID:	821625   Click image for larger version
ID:	821629   Click image for larger version
ID:	821631   Click image for larger version
ID:	821633   Click image for larger version
ID:	821635   Click image for larger version
ID:	821639   Click image for larger version
Old 10-03-2018, 11:34 PM
I have this thread stored as a separate link for my future build! This is great stuff H F !!! Thanks for sharing all the little bits of information along with pictures.
Old 10-04-2018, 03:24 AM
Burning2nd's Avatar
Under the lift arms
Oh yeah... Your gonna be so happy dude, i cant wait for you to come back and put that review down..
I guess we get to find out soon if im really crazy or not..
15486372<-----
