Complete rear and front suspension overhaul and upgrades . - Page 5 - Bimmerfest - BMW Forums
Old 10-07-2018, 08:46 PM
H F H F is offline
Mein Auto: 2005 545i
Originally Posted by oldiegoodie View Post
I have this thread stored as a separate link for my future build! This is great stuff H F !!! Thanks for sharing all the little bits of information along with pictures.
Glad you can utilize the information , have lots more to post . That's what this site is all about .
Old 10-07-2018, 08:58 PM
H F H F is offline
Originally Posted by Burning2nd View Post
Oh yeah... Your gonna be so happy dude, i cant wait for you to come back and put that review down..
I guess we get to find out soon if im really crazy or not..
Think you're right ,,I'm already pretty stoked and not done yet ... Comparing the power flex to the original , there is a difference between the two . I'll elaborate on this more with a new set of pictures of my progress .
Never thought you were crazy man , I just wasn't convinced .. As far as the front,, I'm still really not convinced , compared to the mono ball .
But the front stock control thrust arm bushing ,,I do think the power flex is better .. As long as that bushing doesn't start the dolphin mating calls . Lol
For the rear swing arm and the rear control arm I am convinced it's much better . That bushing is way better than stock ,,now that I have it on hand , and installed on right rear , comparing the two ..
So I will say , you are right about that ...
Old 10-08-2018, 03:31 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
when those mono balls fail.. replace them with powerflex.. and never have to work on your suspension again (its nice going 100k on alignment)
set of tires after set of tires they come off evenly worn.. you put more on and keep rolling
you might get dolphining on the front when you turn the wheel when your at a light or stopped or something *when its wet out
But you cant hear that out side the car, it just travels up the steering coloum
Specializing In Breaking Things Professionally
15486372<-----
Old 10-08-2018, 01:20 PM
H F H F is offline
Control arm and guide arm stock bushings are out . Power flex bushings are pressed in ,ready for installation .
ID:	822447   Click image for larger version
ID:	822449   Click image for larger version
ID:	822451   Click image for larger version
ID:	822453   Click image for larger version
ID:	822457   Click image for larger version
ID:	822459   Click image for larger version
ID:	822461   Click image for larger version
ID:	822463   Click image for larger version
ID:	822467   Click image for larger version
ID:	822469   Click image for larger version
ID:	822471   Click image for larger version
Old 10-08-2018, 01:40 PM
H F H F is offline
Here are the comparisons , swing arm , control and guide arm bushings ,, stock Vs power flex .
First pic , its clear ,, that the stock rubber busing is smaller than power Flex . Thus having more flexibility and less rigidity ... Power flex has more mass on the entire length of the sleeve . Thus increasing rigidity and less flexibility ..
Second pic ,, same thing ,, power flex has a larger mass thru the entire sleeve length , and will have less give ..
4th and 5th the control arm bushing is way way more stout with the sleeve and larger bushing mass .. Its superiority is very clear ..
ID:	822475   Click image for larger version
ID:	822477   Click image for larger version
ID:	822479   Click image for larger version
ID:	822481   Click image for larger version
Old 10-08-2018, 06:07 PM
H F H F is offline
Swing arm is back in . Using a tie down strap to hold the axle shaft up and out of the way , came in really handy .
ID:	822541   Click image for larger version
ID:	822543   Click image for larger version
ID:	822545   Click image for larger version
ID:	822547   Click image for larger version
Old 10-08-2018, 06:24 PM
H F H F is offline
Swing arm ball joint pressed in , integral link and guide arm installed .
ID:	822551   Click image for larger version
ID:	822553   Click image for larger version
ID:	822555   Click image for larger version
ID:	822557   Click image for larger version
ID:	822561   Click image for larger version
ID:	822563   Click image for larger version
ID:	822565   Click image for larger version
ID:	822567   Click image for larger version
ID:	822575   Click image for larger version
Old 10-08-2018, 10:00 PM
H F H F is offline
Removing necessary parts off the old struts and preparing the coil overs for installation.
ID:	822581   Click image for larger version
ID:	822583   Click image for larger version
ID:	822585   Click image for larger version
ID:	822587   Click image for larger version
ID:	822591   Click image for larger version
ID:	822593   Click image for larger version
ID:	822595   Click image for larger version
ID:	822597   Click image for larger version
ID:	822601   Click image for larger version
ID:	822607   Click image for larger version
Old 10-08-2018, 10:33 PM
H F H F is offline
So all new parts are installed , everything is hand snug . Will torque down the coil over , ball joints on the control arm ,guide arm and swing arm ball joint . Will torque down the bushings on the swing arm , control and guide arms once I load the suspension ..
Sorry guys ,, don't understand why some pics are sideways they are vertical on my phone .
Next I'll start disassembly on the driver rear .
ID:	822611   Click image for larger version
ID:	822613   Click image for larger version
Old 10-09-2018, 01:04 AM
Burning2nd's Avatar
Under the lift arms
its race car time
15486372<-----
Old 10-09-2018, 09:25 AM
H F H F is offline
its race car time
Getting close , but I have to pull off for a little . Daughters Santa Fe is not starting ,so I have to sort that out . And FCP sent me two right side control arms . So I have to return and wait for the correct one to arrive . Still waiting for the rebound extensions for the front coil overs . so I pulled off the fronts , and they are half done . So I have delays on three corners ,, And can't get them wrapped up ...
Old 10-09-2018, 02:32 PM
Burning2nd's Avatar
Under the lift arms
that is going to be a very stiff,, very aggressive, LONG lasting suspension
you went crazier then me on this one.. you went total race car : I am impressed
15486372<-----
Old 10-09-2018, 03:11 PM
Kurt_ Kurt_ is offline
Mein Auto: 2008 535xit
This is great and I want it all. I can't believe how much beefier those bushings are.
Life happens. Whatever you post up next will be worth the wait. I'm loving how well documented everything is. I'll be referring to this in the future.
Old 10-09-2018, 03:12 PM
Burning2nd's Avatar
Under the lift arms
all i can do is hope Hf likes it and he lets someone else drive it..
its going to be a completely different animal
15486372<-----
Old 10-13-2018, 07:58 PM
H F H F is offline
Thanks man , your input had a big part in my decision to go for the power flex in the rear . .. That's exactly what I want . Nice and stiff ,, with more rigidity and less give . When I said I'm all in , I meant it . And I expect it to be very aggressive . This thing was a cornering machine bone stock ,,, now it's going to be the Ultimate 4 door cornering machine ...
I'm for sure going to like it .. Not too crazy about letting people drive my baby , not many people have driven my car .
Old 10-13-2018, 08:12 PM
H F H F is offline
Ya , when I compared them side by side , thought , this is a no brainer . I didn't really like the stock rear control arm bushing is what really made it easy to pull the trigger . Plus burnings persistance in convincing me . When I looked at the picture on Powe Flex web site , I was like that is one stout looking set up . I just had to have it to balance out front and rear for hard cornering ,, interms of flexibility and rigidity ..
I'm finally back to it , finished working on three cars , changed the starter and oil pan gaskst on my daughters Hyundai Santa Fe . Installed a alternator on my buddies Chevy van , and changed the spark plugs and fixed the headlights on the Colorado.
So I'm back on the 545 tomorrow, more pics coming soon ..
Old 10-14-2018, 12:50 AM
Burning2nd's Avatar
Under the lift arms
its going to be on rails.. with out any exaggeration
your diffidently going to have to tweak the struts though, its going to be so much stiffer.. that it might under steer or over steer (depending on how you left them)
if you make the struts soft, it should under steer if you make them to stiff it should over steer
Id start with making the both the same in the neutral position (3 of 6 or 5 of 10 how ever your damper rate is ) Then you will probably end up with the rear being slightly higher damper rate then the front Unless you want under steer... personal preference of racing i guess
15486372<-----
Old 10-14-2018, 01:09 PM
H F H F is offline
Definitely going to play with the adjustments. And yes ,, I was thinking the same thing , adjusting them at the happy medium point right in the middle ,and see how she handles .
I have plenty of adjustment settings ,, 16 click compression and 20 clicks on rebound . I want to be able to keep the front end from dropping hitting the breaks into the turns . Same thing on the rear as I accelerate out keeping the car level breaking and gasing out . While Keeping under and over steer in control . Personally I'd rather have a little more over steer than under steer . So it will be fun going thru the settings to find the right combinations....
Old 10-14-2018, 02:37 PM
Burning2nd's Avatar
Under the lift arms
What i did was start 50/50 and then i brought the rear down a little... and then the front up a little.. and then the rear back up..
which would have been just bringing the front up a little At the start..
BUT you have time to feel it out and learn to redrive that unit, shes gonna a different machine
next is gonna be rotors and ss lines lol
15486372<-----
Old 10-14-2018, 08:41 PM
H F H F is offline
Wait ,, are we talking the same thing here ?? Are you talking ride height ?
I'm talking front end compression during hard braking ,, and rear end compression on acceleration ..
Yes , definitely ,, she is going to be like some new strange .
I already have SS lines . Want the M5 calipers and rotors , but that's going to require new wheels and tires . I would rather throw the cash towards a Quaife or M Factory LSD .
Old 10-15-2018, 01:13 AM
Burning2nd's Avatar
Under the lift arms
nope the bound and rebound rate is what your gonna work with.. after you get it set to the height you want
adjusting the height will result in you needing another alignment
get it to what you want, get it aligned and then mess with the bound and rebound rate
15486372<-----
Old 10-15-2018, 09:35 AM
H F H F is offline
Ya , just wanted to make sure we were on the same page compression and rebound adjustment .. I was already thinking passed ride height and alignment... which I'm going to keep it at factory low slung ride height .. Don't want to go any lower than that .
Old 10-16-2018, 01:20 AM
Burning2nd's Avatar
Under the lift arms
the factory height on these cars is already pretty low, back when i use to actually drive lowered cars.. (pulling in to parken lots sideways and ****) I got use to "save the nose" mentality
when i said good bye to lowered honda stance, I had a hard time for a long long time just pulling in normal.. *i was use to it
you shouldn't have to go much lower.. after the alignment is set your damper rate adjustment is just a few clicks.. I found that a little stiffer in the rear gives the ass end a nice hugging feeling when your in the turn underpower,
You will be most impressed.. and im whilling to bet your probably a polyurethane bushing head for life now, youll start to want to replace bushings on other stuff with polyurethane. minus the struts what was the total number on the e60 for the set?
Im working my way thru now, im also acquiring parts for future projects, i have half of the suspension on hand, some of the bushings I already had (but im in the middle of doing a 125g saltwater reef tank that my wife insists i finish now that the new floor is done)
so for the car its pretty much if its not broken im not allowed to fix it lol
15486372<-----
Old 10-17-2018, 09:25 AM
H F H F is offline
That makes a lot of sense to me because the rear end does swing back n forth in the snakes.
So stiffer in the rear is a great suggestion . I will take you up on that and set it up that way .
Those poly bushings are much heavier duty than the stock bushings . And very noticeable when in a side by side comparison. Especially the rear control arm . Pictures of the bushings don't do them justice . You pretty much have to have them in hand to see it ..
Well ,. I'm going ahead and getting the ARS bushings too. So ,,I reckon,, I maybe a poly head now .. lol
Haven't added up the total cost yet , actually I'm afraid to see how much I've spent .
Off the top of my head the poly bushing were around 300+ , front end parts 600+, rear parts 300+. Plus all the misc nuts and bolts . Im around at least $1500.00 .. Plus the V3's and monoballs .
And I really don't care that I've dropped all this cash on my ride . People Will say it's just as much as the blue book value .. ok , but what will you get for 4000 bucks . Not a car in a condition as mine , that is solid and reliable , well taken care of that's going to have Porsche like handling. And I know, for a fact ,that I can give them a run for their money In The twisties ... and that's before all these upgrades .
Handling is a big deal for me and in my opinion it's money well spent on something that makes a huge difference . Compared to spending money on fancy wheels and Mtec bumpers , that do nothing for performance or handling only looks .... But that's just my opinion...
Old 10-17-2018, 09:36 AM
Burning2nd's Avatar
Under the lift arms
well congratulations, you have the best handling e60 in the section lol
chasing corvettes and 911's is a reality now
15486372<-----
