Style 172 wheel spacers - Bimmerfest - BMW Forums
Old 08-19-2019, 10:28 PM
itscoo2pyopants itscoo2pyopants is offline
Mein Auto: E38, E46, E53, E92
Looking to put some spacers on my car. What sizes are you guys running?
2010 550i stock suspension (for now)
ID:	861665Click image for larger version
Old 08-20-2019, 01:06 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
none,
Specializing In Breaking Things Professionally
15486372<-----
Old 08-20-2019, 09:12 AM
ABCarr ABCarr is offline
Mein Auto: 2009 550i
I use 15mm spacers on the back, none on the front. I think it looks great.
Old 08-20-2019, 01:51 PM
Any pics?
Old 08-20-2019, 03:19 PM
Ripper61's Avatar
Ripper61 Ripper61 is offline
Mein Auto: 2010 535i M-sport AT
Same here. 15mm in back, nothing up front. I'll dig up a pic later
2010 535i M-sport, ER CP & FMIC, VRSF ***, Forge DV, BMS DCI, BMS OCC, RB PCV, RB Inlets, COBB Stg 2+ 93, 19" M6 Type 167's
Old 08-20-2019, 04:01 PM
FatBoy613 FatBoy613 is offline
Mein Auto: 2004 745i
what brand spacers do you guys use?
Old 08-20-2019, 04:51 PM
Burning2nd's Avatar
Under the lift arms
Id like to see this 15mm spacer on the staggered suspension (*gotta look pretty thick)
15486372<-----
Old 08-21-2019, 02:37 PM
Ripper61's Avatar
Old 08-21-2019, 02:59 PM
Ripper61's Avatar
https://photos.app.goo.gl/Dny7owRF2VzQsNAM9
Old 08-21-2019, 04:08 PM
^ looks pretty sweet. Are those the same offset as stock 172 wheels?
Anyone else have pics with spacers and style 172 wheels?
Old 08-21-2019, 11:31 PM
BickUW89's Avatar
BickUW89 BickUW89 is offline
Go Dawgs!
Mein Auto: 2010 E60 550i ZSP 6MT
this isn't the best angle, but here's a pic of my retired 2008 E60 ZSP with stock 172s and 15mm spacers.
FWIW, I put 15mm spacers on my recently-new (to me) 2010 E60 with stock 172s, and I think it looks great. Sorry, no pics of this one.
15mm is not a dramatic change, but it makes the stock wheels fill up the wheel well much better than the factory configuration. Heck, I think you could go 20mm and it would look great, but I don't know what the physics are of hanging the wheels out that far.
BMW Ergo Zoom
IMHO: E39 < E60 > F10
In the Stable:
2010 E60 550i ZSP 6MT IAS
2019 G30 M550xi (ED July 8, 2019)
Retired:
2016 F82 ///M4 ZCP (ED July 6, 2016)
2011 F10 535xi ZSP (ED July 15, 2011)
2008 E60 550i ZSP (ED July 22, 2008)
2000 E39 540i ZSP 6MT
Member BMWCCA #402733
Old 08-21-2019, 11:53 PM
15mm in the rear? Nothing up front?
Old 08-21-2019, 11:56 PM
BickUW89's Avatar
Go Dawgs!
Correct
BMW Ergo Zoom
In the Stable:
Retired:
Old 08-22-2019, 03:56 AM
Burning2nd's Avatar
Under the lift arms
looks like what i already have
15486372<-----
Old 08-22-2019, 06:59 AM
Correct
Thanks for the info. Thatís the look Iím going for
Old 08-22-2019, 07:38 AM
BickUW89's Avatar
Go Dawgs!
It's definitely different looking than stock, without being loud or obnoxious.
I found a pic of my 2010 E60 from about the same angle as the 2008, before I put the 15mm spacers on it. Gives a half-decent before and after comparison. The first picture is the "before" on the 2010 E60, the second picture is the "after" on the 2008:
ID:	861941   Click image for larger version
BMW Ergo Zoom
In the Stable:
Retired:
Old 08-22-2019, 08:39 AM
Burning2nd's Avatar
Under the lift arms
and its bolt on.. and doesnt cause any weird ware?
do you have alink?
this is to widden the oem style staggered 172's? correct?
bolt on spacers that make your rear end just a little more wide? (30mm overall)?
can some get a picture of the spacers on the hub? and or a square on picture from the rear?
15486372<-----
Old 08-22-2019, 09:47 AM
BickUW89's Avatar
Go Dawgs!
It's a CNC-machined piece that fits right over the lip on the brake rotor, between the wheel and the rotor. The tolerances are really dialed in, too, so there's no slop in it. It comes with replacement studs that are a bit longer to make up for the extra space.
do you have alink?
I bought mine from Turner Motorsport. Here's the link: https://www.turnermotorsport.com/p-3...bolt-kit-15mm/
Exactly. I think 15mm on each side in the back is perfect. It actually looks more "factory" than how it looks without them. Visually the rear wheels just sit too far inside the wheel well for my liking.
BMW Ergo Zoom
In the Stable:
Retired:
Old 08-22-2019, 02:40 PM
nice. thanks for the pics. thats what i was looking for.
weird, i was unable to find and definitive info on spacers for these wheels. i tried to do my own measurements but still wanted to hear from someone that has done it. i want a little poke with no rub. i will eventually be doing some coilovers, but thats prob not for a while as i only have 55k miles on my car. going to wait until the stock suspension gets worn.
thanks again for the pics, ill be pulling the trigger on some spacers soon
Old 08-22-2019, 04:21 PM
Burning2nd's Avatar
Under the lift arms
and the 275 30's fit in the back?
15486372<-----
Old 08-22-2019, 06:37 PM
BickUW89's Avatar
Go Dawgs!
Oh yeah, perfectly. There's plenty of room back there still. There are absolutely no clearance problems at all. I've never rubbed the top of the fender on the tire when the shocks are fully compressed, which wouldn't be any different with or without the spacers anyway - if the tire would strike the bumper with the spacer, it would strike without it.
Honestly, the spacers are just completely plug-and-play. Remove the wheel, slide the spacer on, remount the wheel using the longer lug screws that come with the spacer, torque those bad boys to 88 and you're off to the races.
BMW Ergo Zoom
In the Stable:
Retired:
Old 08-23-2019, 07:01 AM
BickUW89's Avatar
Go Dawgs!
One last look
I took a few pictures of the back of my car when I got back to the airport last night. This is what it looks like with 15mm spacers from the rear.
ID:	862027   Click image for larger version
ID:	862029   Click image for larger version
ID:	862031   Click image for larger version
BMW Ergo Zoom
In the Stable:
Retired:
Old 08-23-2019, 10:53 AM
Ripper61's Avatar
My 167's are offset 28 in the rear. Less 15 brings them to 13.
Old 08-26-2019, 01:54 PM
oldiegoodie oldiegoodie is offline
Mein Auto: 2007 550i 6MT
I run et12 on my rear setup and still have few millimeters to work with. I'm actually running higher profile 19in tires like the F10. Looks much meatier and better than those low profile E60 tires, IMO.
Sent from my SM-G950W using Tapatalk
2007 E60 550i Sport 6MT
Old 08-26-2019, 04:20 PM
Burning2nd's Avatar
Under the lift arms
so whats the better tire configuration.. from the 275/35/19's?
your saying your running 45/19's?
15486372<-----
