Intermittant Coolant leak - N52, ZF 6HP - Bimmerfest - BMW Forums
Old 08-20-2019, 11:57 AM
Underwurlde Underwurlde is offline
Mein Auto: BMW E63 630i
Hi all,
I seem to have an intermittent coolant leak from the bottom right of the radiator where the transmission oil heat exchanger sits.
I found that the leak only happens when I'm on a slightly longer journey than normal. When I use sport mode it will start leaking sooner. This would suggest that it happens when the transmission oil heats up and the thermostat opens.
Any idea what triggers this thermostat - is it transmission oil temp or coolant temp? What is the activation temp? I'd like to drive it to the point where it starts leaking then get it on a ramp to check.
I presume that the leak is with the one of the three key parts here - the mounting plate, thermostat, or heat exchanger but would like to try to pinpoint the problem before throwing parts at it.
All input appreciated.
UW
Old 08-22-2019, 07:14 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
First, clean the area thoroughly. Brake cleaner spray works well. See if you can spot a leak after exercising the car.
If that's not enough, get some UV dye at the parts store and put some in your coolant. A little goes a very long way, so unless you want green-looking coolant, go easy.
Drive a while, then use a UV light to check for glowing residue in the area you're concerned about. If none, check for leaks elsewhere.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 12+ Years
Old 08-22-2019, 07:20 AM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
Auto parts stores like autozone, advance auto, etc have loaner pressure test kits that work well. You pay for the kit and receive a full refund when you bring it back to the store. Just pressure test it yourself and it should be obvious. Very easy to do and in my opinion the most effective.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 09-08-2019, 02:47 PM
Finally got time to get my car up on stands to investigate further.
Plenty of coolant dripping down but could not see any coming from the trans cooler, thermostat or mounting plate.
Removed the fan shroud and lifted the radiator up a little from the carrier.
Seems the new radiator has two leaks, one each side. Should have listened to my inner self... buy cheap, buy twice....
ID:	863861   Click image for larger version
Old 09-09-2019, 06:09 AM
audiophool audiophool is online now
BMWs since '87
Mein Auto: 2008 535xi (LCI)
My OE radiator developed a pinhole leak at about 200,000km. Replaced it with a BEHR 85151B - same manufacturer as the OE part for half the price of dealer.
Old 09-09-2019, 06:18 AM
Yeah, I just ordered a Behr this morning. Should have just gone with Behr to begin with.
I was trying to rationalise the amount I'm spending on a 13 year old car which is of very limited value, and in this case failed miserably.
Old 09-09-2019, 06:24 AM
twh twh is online now
Mein Auto: '06 530xi 6sp, '09 X5 3.0
Out of curiosity, what brand did you buy first?
Old 09-09-2019, 06:35 AM
He he...
Van Wezel. I assumed that "100 years of experience" was enough to ensure they could supply a radiator that didn't leak from the get go.....obviously not..
Old 09-09-2019, 12:03 PM
banglenot's Avatar
There's an industry based on buying older or retired business names and pasting them on new products, often sold cheap.
RCA is an example, as is Zenith. Both have "100 years of experience", but haven't existed except as orphan brand names in 20 years....
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old Yesterday, 01:36 PM
So my replacement Behr radiator arrived today. Unfortunately, this is what I received. I presume this will leak just as much as my leaky van wezel...
ID:	864933   Click image for larger version
ID:	864935   Click image for larger version
Old Yesterday, 07:52 PM
Damn...I hate when parts come mangled.
Old Yesterday, 08:33 PM
BMWs since '87
They've taken minimalist packing to a new extreme, such that the sacrificial item is the part you're buying. Hope the replacement part arrives in proper condition.
Old Today, 01:05 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
no the minimalist packing for expensive things.. and maximum packing for cheap plastic garbage
Specializing In Breaking Things Professionally
15486372<-----
