Broken Valve Cover Bolt! - Page 2 - Bimmerfest - BMW Forums
Old 09-10-2019, 07:31 PM
away_one away_one is offline
Mein Auto: 2008 BMW 550i M-Sport
I noticed the top with the Dremel disc, but the bolt did not budge using the screwdriver in the notch. I then tried the Vice Grips and they broke off the exposed part of the bolt without moving the bolt. Did I misunderstand what you were referring to with the Dremel?
2008 550i Sport w/ Dinan Stage 3
Old 09-10-2019, 07:38 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Not sure. You had more bolt to work with then I did. I Dremeled a steady hand groove down to close to the block level. Let it cool and the flathead turned it without and issue. I was at the point of taking to a shop but realized how easy it was.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 09-11-2019, 09:32 AM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
There are broken bolts and there are broken and seized bolts. Yours was the former, away_one's is the latter.
Lucky you were able to get the broken drill out of the hole OP. I would be inclined to try again with another LH bit, and go slow again but even slower and use less pressure on the drill.
