End All Battery Replacement Thread - Page 12 - Bimmerfest - BMW Forums
Old 06-02-2018, 07:09 PM
ciacuzzo's Avatar
ciacuzzo ciacuzzo is offline
Mein Auto: 2008 550i
Originally Posted by Jtbgonesailing View Post
Look at your Carly. Under battery registration, it will show you mileage of last battery change. Explore the Carly app for options available...
I did. However I get to the screen that says
"Register same Battery"
"Register new type battery"
"Registration Information" - just takes my to Carly FAQ page.
I don't want to click on either of the "Register" options without knowing what it will do.
Will one of these give me my current battery information without registering the battery?
2008 550i V8 N62 M-Sport (76k mi)
6 sp auto GA6HP26ZTU
Staggered 245/35 & 275/30 19" Conti Extreme Contact
Style 172 rims, 12mm spacer front, 15mm spacer rear (17's would look better)
Charcoal Filter Delete - K&N Air Filter
Cadeez Grill mod, Ceramic Window Tint
2/3 90 Octane Ethanol Free - 1/3 Shell 93 Octane; Liqui Moly 5W-40
Old 06-02-2018, 07:38 PM
Jtbgonesailing Jtbgonesailing is offline
Mein Auto: 05 530i & 81 320i
Yes, Register new battery type will show what you have installed (AGM/FLA, AH) with mileage. You can then back out of that section without modifying anything. It also shows hrs of charging at various battery states of charge. Remember, Carly won't let you blindly make changes, across the board, without the challenges.
Old 06-02-2018, 09:38 PM
ciacuzzo's Avatar
Awesome thanks. Yeah they are pretty good about warning you before doing anything.
Old 01-20-2019, 05:50 PM
CTE61 CTE61 is offline
Mein Auto: E61
I was having battery issues and replaced the battery.
I installed the H9 AGM From AutoZone:
- CCA 950
- CA 1000
- Amp Hours 100
- Reserve Capacity 190
I removed this one:
- BMW / FLA
- CCA 850
- Amp Hours 110
Carly will only let me register 105 AGM or 90 AGM. I chose 90 AGM.
My question is do I get a 90 AGM or stick with the 100 AGM registered as 90 AGM?
Old 01-20-2019, 07:47 PM
cmyachtie cmyachtie is offline
Mein Auto: E60545i
My suggestion reg. at 100.
My current daily driver:
2004 545i.... Aux+SB Chime+Dig speedo+iDrive discl. Coded+BT streaming MOD.Added. And the "mschumpert Trunk lid hack". Replaced TCU with a 2007 version that works!
1998 528i, 5 spd manual, black on black non DSP. SOLD @348Kkms.
My previous rides worth mentioning:1970 GTO "The Judge",1985 325e M3lite, Euro BMW +
1998 mTech 323Ti, in Munich, Germany on the autobahn for 1 yr
Old 01-20-2019, 07:53 PM
Mein Auto: E61
Carly only gives me an option of 105AGM or 90 AGM
Old 01-21-2019, 01:48 AM
Mein Auto: E60545i
Sorry my mistype last night was a bit late I guess....meant 105
Old 01-21-2019, 09:10 AM
Mein Auto: E61
From what I've read if the exact AH is not available on Carly it's best to choose the next number down
TY
Old 01-21-2019, 09:50 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
TY
I agree. An AGM battery is fragile to the slightest overcharge.
One ampere-hour of overcharge electrolyzes 0.335 grams of electrolyte water to 400 cubic centimeters of oxygen and hydrogen gas that is vented and lost from a starved plate battery that is build with the minimum possible amount of electrolyte to achieve rated capacity.
Chronic overcharge will ruin an AMG battery in short order, hypothetically within a month.
On respect that 'CTE' stands for Chief Test Engineer and from Connecticut, that discussion is on about page 59 of
https://www.amazon.com/Lead-Acid-Bat.../dp/1466592222
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 01-21-2019, 06:21 PM
Mein Auto: E61
I'm not going to argue with a nuclear engineer :-)
I'll keep an eye on it at 90 AGM and see how it goes.
Thanks again
Old 01-24-2019, 09:21 PM
dmandash dmandash is offline
Mein Auto: 2007 BMW 525xi
Can an AGM Battery be Recharged at Autozone? or should I just buy a new battery. Car not starting doesn't crank anymore don't have a tester is it a good idea to pull the battery and have them test or charge it
Sent from my SM-G965U1 using Bimmerfest mobile app
Old 05-23-2019, 09:41 AM
gohornedfrogs gohornedfrogs is offline
Mein Auto: 2008 535xi & 2011 328ixdr
I installed the Autocraft Gold model in January of 2016. It lasted 3 1/2 years, and I just ordered another one today for about $150 all in. I have Carly, so I'll do the registration when I install it this weekend.
I never had any issues with this battery, and for $150, you can't beat it. I'll probably sell the car before I need another one.
  • 2008 535xi -- Platinum Grey Metallic, Cobb AP3, RB Turbos, M5Tech Front Bumper, Navigation/Traffic, Ipod Integration, Voice Control, SAT, Bluetooth, Cold Weather Pkg., Fold Down Rear Seats, Through Loading System, Conti ExtremeContact DWS 06s.
  • 2011 328i xDrive with MSport Package -- Alpine White
  • 2004 530i -- retired w/130k miles, May 2014
  • 1983 735i Grey Market
  • 1980 525 Grey Market
Old 09-11-2019, 07:31 AM
Sasha Kanter Sasha Kanter is offline
Mein Auto:
Originally Posted by Geaff500 View Post
Yes, thank you! I forgot to add this.
Let's make this thread the mega battery thread to answer all battery replacement questions once and for all.
6 years laters.. im new and wondering how much it would cost for a battery replacement?
Old 09-11-2019, 12:12 PM
daka daka is offline
BMWCCA 12660
Mein Auto: 07 530xiT 18 C300 Cab
When my battery died, I called AAA, they came with a a 3 year unlimited, + 3 year prorated battery, tested the system and installed it for abut $175....no lifting no problem, my indie registered it when I had an oil change
PS, my 07 touring with the "new" battery is for sale....54,000 miles MINT condition
