Long Story - Don't Play with Tire tread and patterns - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X6 F16 (2015 - Current)
The all new 2015 BMW X6 is the second generation luxury cross over. BMW referes to the X6 as a Sports Activity Coupe (SAC) as it combines the attributes of an SUV (high ground clearance, xDrive and all-weather ability) with the stance, styling and roof line shape of a coupe. The F16 BMW X6 is build side by side with the F15 X5 at BMW's BMW's Spartanburg, SC plant. Read all about the second generation BMW X6 here!
Old 07-18-2019, 11:21 AM
uwhusky's Avatar
uwhusky uwhusky is offline
Mein Auto: 2008 e60 535xi
About 14 months or so ago I put new tires on my X6, staggered set, etc. They're continentals but same tires all the way around, just different sizes on front vs back.
About 2 months one of the back tires blew out. The tire shop told me I could just replace the back two tires and leave the fronts alone. Or at least they said we could give it a try.
So problem #1 - new tires on back but fronts had about 10k miles worn off on them.
Problem #2 - different continentals on the front than the back, so tread patterns were different as well.
A couple days ago the car gives a warning sign of "Chassis Stabilization" and is making a horrible squeaking noise.
I take it to BMW and they tell me I need a software update and a new rear differential. It's going to cost me an arm and a leg.
Long story short - I should've put four new tires all the way around rather than testing it out with different fronts vs backs. Don't let this happen to you.
2008 e60 535xi : Alpine White / Natural Brown / Poplar : Auto : Sport : Prem : Nav : Cold Wx : Comfort Access : PDC : Sirius
Aftermarket: K&N Air Filter : Clearbra : Tint : 12mm H&R rear spacers : Michelin Pilot Sport Tires: Debadged : Matte Black Kidney Grille : OEM M5Tech Front Spoiler
Old 07-18-2019, 11:25 AM
Doug Huffman's Avatar
Nuclear engineer
Trust and verify. Get a second opinion.
Old 07-18-2019, 11:29 AM
uwhusky's Avatar
Doug, you mean you're not convinced I need a new rear diff?
Old 08-31-2019, 12:27 AM
Autoputzer Autoputzer is offline
Tire Rack likely would have had the exact replacement tire for the one you blew. Also, they shave new tires down to match you existing tire(s) for about $35. So, you only needed to buy one tire. You likely don't have a limited slip differential. So, having a slight difference in tire diameters should not cause damage to the differential. Since you replaced both rear tires, there shouldn't be any issue with the rear differential (caused by tires). Tread pattern wouldn't affect the differential.
You might have a bad differential. But if so, it wasn't caused by the new tires. If the dealership is saying you need a new differential and that it is due to the tires, you should seriously question the need for a new differential.
