Can't get hood open - Bimmerfest - BMW Forums
Old 11-04-2019, 11:39 AM
zephyrprime zephyrprime is offline
Mein Auto: 2006 750li
Can't get hood open
I have an 06 750li facelift model. The hood cannot open on this due to the driver side latch being stuck. The passenger side latch works and the center latch works.
I have already tried several methods of opening the hood including pulling on the latch cable with pliers, pulling on the latch cable through the wheel well, etc.
I have cut through the front grill and can get my hand directly onto the latch. I have found that the cables are still attached and are actuating the latch lever correctly. However, the latch lever is only plastic and it seems like it no longer is capable of moving the metal part it's attached to. Moving the plastic latch lever by hand has no effect.
Does anyone have any idea of how to deal with this?
You can see the lever the cables attach to on the lower right side of this image:
https://i.ebayimg.com/images/g/u9gAA...JC/s-l1600.jpg
Old 11-11-2019, 04:50 PM
robmal1 robmal1 is offline
Mein Auto:
I feel you. I am having the same problem in my E83. Call the Steeler and they want $450 for just popping the hood. Indie shop does not even want to give me an estimate, but says it can get into the four figures. I am thinking into going to a junk yard and pick another hood and just drill this one. Anyways good luck!
Old 11-11-2019, 05:44 PM
745D 745D is offline
Mein Auto: 745Li
Have you tried this
https://www.bimmerfest.com/forums/sh...d.php?t=403879
Old 11-19-2019, 02:07 PM
Originally Posted by 745D View Post
First link - I can't open the hood to access that area. Also, that's not the problem anyway since the hand lever is capable of actuating the latch lever.
Second link - that is the pre-facelift model and the instructions are not applicable.
Third link - I have already taken apart the hand lever as I stated in my first post.
Old 11-19-2019, 02:09 PM
I can see it getting expensive because in the worst case scenario they would have to cut the hood off.
Old 11-19-2019, 02:10 PM
Update: upon further examination, it seems the plastic lever is moving the linked metal part fine except it cannot move it all the way. I have bought a replacement part and examining it has been most educational. It's as though there was a rock lodged behind the metal latch that prevents movement past as a certain point.
