HELP!!!! BMW Dropped bolt into engine!!! - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > Everything Else > General Automotive Forum
All non-BMW car talk goes here...
Old 02-10-2019, 09:34 AM
Onesikda9 Onesikda9 is offline
Mein Auto:
Is there any way of taking out a bolt from inside oil pan without removing the oil pan? What happen was, I was replacing the CPS ( crankshaft position sensor )and my dumbass accidentally dropped the bolt into the CPS hole. I heard it hit metal and went under the car and pounded on the oil pan and heard the bolt rattle .. I know it's a b$#@% to remove the oil pan , so that why I'm trying to work around that.. I already drained the oil hoping it would miraculously come out but No Luck !
So is there anyone who can help me out with some good ideas . TIA
Sent from my SAMSUNG-SM-G920AZ using Bimmerfest mobile app
Old 02-10-2019, 09:44 AM
karzrus karzrus is offline
Mein Auto: 2014 335xi GT Msport
The bolt is carbon steel and magnetic, so one of those tools that is a magnet on a flex cable might get it?
Old 02-10-2019, 12:00 PM
Mein Auto:
Oh ok.. I'll give it a try . Isn't there a magnet on the oil pan?
Old 02-10-2019, 12:02 PM
Doug Huffman's Avatar
Nuclear engineer
Sometimes the drainplug, but it is not factory standard that I know.
Old 02-10-2019, 12:07 PM
Mein Auto:
Oh ok .. thnks man
Old 02-10-2019, 04:40 PM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
what model & engine?
BMW CCA #132981 Tarheel Chapter,
Old 02-10-2019, 06:04 PM
Mein Auto:
My bad it's a 2006 325i
Old 02-10-2019, 08:16 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: 944 Turbo M235 Z4 335Mcar
For an experienced wrencher, dropping the oil pan is no big deal. I can tell you this, the oil pick up tube into the engine has a mesh screen on it. It wont get sucked up from there rest assured.
From Napa, they have magnets on long wire springs. Insert into the oil drain hole and fish around and you might get lucky.
Old 02-10-2019, 08:37 PM
Onesikda9.....here's what your oil pan looks like in the pics below. You can try removing the VC & try to fish out down the front of the engine with magnet. If it is fact all the way to bottom of oil pan, and not on the timing chain, you might be ok. It could possibly move toward the engine & deep part of the pan & you might be able to fish it out. You could also try to remove the oil level sensor & try to fish out from there with magnet. I'm just not sure what baffles or other stuff might be in the way.
ID:	839679   Click image for larger version
Old 02-10-2019, 09:35 PM
Mein Auto:
Good lookin out brotha! I thought It would get sucked up if starting the car.. I haven't tried starting it for that same reason.
Old 06-12-2019, 05:06 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
Drain the oil, remove the oil condition sensor, large hole to fish a magnet into. Buy a gasket to reinstall the OCS.
People forget that the OCS is a pretty large hole. Look at the oil pan pic above.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
Old 06-12-2019, 08:05 PM
Ziggy328xi Ziggy328xi is online now
Ziggy.
Mein Auto: 11 328xi N51
Remove the oil level sensor, and drainplug, spray a ton of brake clean into pan area and drain it all out, then try fishing around with a magnet around where you hear the bolt.
Old 06-12-2019, 09:34 PM
namelessman namelessman is offline
Mein Auto: bimmer
To OP, if it is 100% confirmed that it ends up at bottom of oil pan and not stuck between any moving parts, then it may work to just leave the bolt at the bottom of oil pan(until next oil pan job), provided there is filter/screen that prevents the bolt from sucking up by oil pump.
Similar Threads
BMW Leasing 101 - Learn about leasing, get the best deal tim330i Ask-A-BMW-Dealer 32 06-02-2019 10:11 AM
All BMWs Spark Plugs Jtripper Tools and Miscellaneous 0 08-02-2018 05:02 AM
Damaged Engine - Faulty Oil Change - Engine Oil Cap insert removed. justinz X5 E70 (2007 - 2013) 7 07-04-2018 09:36 AM
E65 V12 debuts nate General BMW Questions 22 06-09-2016 01:44 AM
The History of the BMW 5 Series WAM 5 Series 5 08-17-2006 09:46 PM
