Valeo voltage regulator - Bimmerfest - BMW Forums
Old 05-18-2019, 06:08 PM
scottalexander scottalexander is offline
Mein Auto: 2010 bmw 528i
We have a 2010 528i with N52k.
I called FCP and they sent me the 180 amp voltage regulator for the Valeo alternator (or what they thought was the correct voltage regulator).
I pulled out the alternator.
I started taking disassembling it and figured out the FCP regulator was the wrong one.
After talking with FCP and competitors, they say they don't have the Valeo voltage regulator, nor can they get it. They told me to buy a new alternator for $400.
There must be a army of BMW owners that have changed the voltage regulator in their Valeo alternator.
Where does everyone buy their Valeo voltage regulators?
Old 05-19-2019, 06:09 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
Google alternator supply houses -- the ones that provide alternators on the general market.
You'll have to get the Valeo part number for the regulator, or the alternator, not the BMW number.
Also, if it's the brushes that are worn, you can replace those with a soldering iron.
Unless the electronics are fried, or the BSD bus is damaged, it's usually just a brush replacement that's needed.
NLA's (No Longer Available) are going to become an increasing problem as the cars age, but brushes will be always available.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
Old 05-19-2019, 06:25 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Originally Posted by scottalexander View Post
We have a 2010 528i with N52k. I called FCP and they sent me the 180 amp voltage regulator for the Valeo alternator (or what they thought was the correct voltage regulator). I pulled out the alternator. I started taking disassembling it and figured out the FCP regulator was the wrong one. After talking with FCP and competitors, they say they don't have the Valeo voltage regulator, nor can they get it. They told me to buy a new alternator for $400. There must be a army of BMW owners that have changed the voltage regulator in their Valeo alternator. Where does everyone buy their Valeo voltage regulators?
It is unlikely that Mr. Scott Alexander has the tools or skills to properly identify a failed BSD alternator. To focus on obsolete technology of "voltage regulator" part of alternator is error. The ECU controls alternator output.
https://www.newtis.info/tisv2/a/en/e...-parts/Or82vy4
Do not ever believe or take advise from a sales clerk that only wants to sell parts!
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 05-19-2019, 07:41 AM
banglenot's Avatar
Doug, Not clear who your comment is directed at, but the regulator is the interface to the ECU, and whatever the ECU wants, the regulator communicates to the alternator electronics.
Please reference https://www.picoauto.com/library/cas...nication-error for an excellent study of the Alternator-regulator- BSD - IBS interfaces, and the specific comment:
Knowing the BSD line is directly responsible for alternator output (subject to command from the PCM) the BSD waveform was decoded using the PicoScope decoding feature in an attempt to identify errors within the coded message carried to and from the alternator during the abrupt shutdown (captured above).
So, saying the ECU is responsible for alternator output is like saying it's responsible for firing the plugs. It is, but there is a clear need for the coils to accomplish the actual event.
Also,it's likely that the primary failure points on 100K Valeo alternators are the brushes-slip rings or BSD interface. Both are contained in the regulator interface. Brushes wear out, usually long before the bearings or diodes. If regulators are not available, brushes are universally available and easily swapped with a soldering iron. Slip rings that can't be polished obviously mean a new alternator.
Best, Bangle
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Similar Threads
Weird question ... Where are ENGINE-specific BMW P1xxx trouble codes anyway? bluebee E39 (1997 - 2003) 49 12-02-2017 06:12 PM
Complete BMW OBD II codes doru E39 (1997 - 2003) 5 10-19-2017 04:44 PM
Bad alternator? Bad voltage regulator? klarkent42 E39 (1997 - 2003) 6 03-23-2016 03:22 PM
Charging issue measuringtape E34 (1989 - 1995) 5 04-01-2012 06:11 PM
multiple voltage regulator failures apro1971 E39 (1997 - 2003) 14 09-06-2009 01:11 PM
