AVS sport tire pressure - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Motorsports, Racing & Track
From Formula One to Auto-X, discuss everything related to going fast here...
Old 08-18-2003, 01:23 PM
TranceLvr TranceLvr is offline
Mein Auto:
Question AVS sport tire pressure
I have had my AVS sports running at factory recommended tire pressure since I got them. They seem to be OK, but I am a complete novice when it comes to figuring out what pressure to use. Any tips or hints would be greatly appreciated.
Old 08-18-2003, 01:28 PM
in_d_haus in_d_haus is offline
Mein Auto:
If you are running on the street use the factory recommended pressures.
Old 08-18-2003, 01:31 PM
Mein Auto:
Sorry, should have clarified. I meant to say when I am at an Auto X.
Old 08-18-2003, 01:32 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
You probably want to up the fronts.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 08-18-2003, 03:35 PM
sshuit sshuit is offline
Mein Auto:
I'm relatively new to the autocross scene but I'm running my car with 42F /42 R at the moment.
I also have full stiff UUC sways mounted front and rear and I'm still getting a bit of understeer at times.....
going to run 42F / 37R at the next event and see if I can't get the rear end a little bit looser
I suggest running higher in the front for sure and then tune the front based on tire roll-over and the rears based on what the car is doing.....
Old 08-18-2003, 04:27 PM
Akakubi Akakubi is offline
Mein Auto:
Start with those pressures, but then drop down as you go run after run. You need only as much pressure that you do not roll the sidewall. If you run 42 cold throughout the whole session, the air will expand and infact will be like 47-50 hot, effectively reducing your contact patch and causing tons of understeer.
Just play with the pressures. Mark the sidewalls with chalk to better see if you roll, and drop doen from there. The same applies to the rears. Sometimes you can have the difference of 7-8psi front to rear if you don't roll and want the car to rotate better.
Old 08-19-2003, 09:00 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Depending on the tires and the camber you may need more tire pressure than just preventing the sidewall from rolling. You are looking to keep as much tread on the ground as possible under load. Under load with lower tire pressures the center of th etread goes concave, which is not good for traction.
For autoX ask the fast people in your area what they are running.
For street I recommend +4 psi front, +2 psi rear for better and more neutral handling.
For autoX, I run higher than that.
But until you are running consistantly enough to run similar times on each run, you will not be able to really tune pressures. But try higher and higher pressures, keeping the same front/rear balance and see what you think. Once you get to a pressure setting that seems fastest, then start playing with front/rear balance. As you go up in pressure, you will get to the point where the tires seem to slide more than they did, then back down a little.
There are guys running as high as 50 psi for Autocross in WRXs,
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 08-19-2003, 09:15 AM
·clyde·'s Avatar
·clyde· ·clyde· is offline
OMGWTFBBQ
Mein Auto:
xiT drivers have done that with the OEM all seasons too.
OH NOES!!!!!1 MY CAR HAS T3H UND3R5T33R5555!!!!!!1oneone!!!!11
Team WTF?!
What are you gonna do?
Old 08-19-2003, 09:17 AM
Mein Auto:
So I am seeing that I should increase my front pressure for sure. I should probably invest in a 12V pump for the track then. Thanks for the ideas all
Old 08-19-2003, 09:23 AM
·clyde·'s Avatar
OMGWTFBBQ
Mein Auto:
Keeping a 12v compressor in your car is just a plain good idea. I see a lot of people use them at autocrosses, but I find it easier to use a free pump at a gas station on the way to an event. The 12v compressors can be very slow when you have to put 5-10 pounds in each tire after you get to the event.
Team WTF?!
Old 08-21-2003, 06:02 AM
Pinecone's Avatar
M Mad
That's nothing, I once ran an event in my Fiat 850 with a pair of snow tires on the rear. Nothing like a rear engined car with even LESS traction in the rear. After finally getting up to about 55 - 57 psi, I managed to come in second.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 08-21-2003, 06:04 AM
Pinecone's Avatar
M Mad
Maybe in your area.
I can't remember the last time I saw a FREE air pump at a station. Normally 50 cents for not enough air to do all 4 tires to normal pressures.
The best is a compressor at home and an air tank. Pump the tires up at home, fill the air tank and away you go.
Of course if you really get crazy about this, you will run autoX pressures on the street.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 08-21-2003, 07:19 AM
·clyde·'s Avatar
OMGWTFBBQ
Mein Auto:
There are plenty of gas stations in suburban MD that have free air, you just have to look a little.
Having a compressor at home would be nice. So would having a garage
What's crazy about running autox pressures on the street?
Team WTF?!
Old 08-21-2003, 07:25 AM
SpaceMonkey SpaceMonkey is offline
Mein Auto:
Old 11-20-2004, 02:49 PM
guzplace guzplace is offline
Mein Auto:
what about the maximum tire pressure printed on each tire ?
if you have 50 PSI then you're gonna exceed that when hot and would the tire blow up ?
