Drivetrain Malfunction: drive moderately maximum drivetrain output not available. - Bimmerfest - BMW Forums
Old 10-09-2017, 02:17 PM
diego777dlc diego777dlc is offline
Mein Auto: 2013 328i xDrive Sport
Just got this message. I'm not quite not familiar with these vehicles but I hear that this could be a numerous amount of things that could be going on. My car is a 2013 BMW 328i xdrive sport sedan with 34,500 miles. Before this happened the car was sitting in the garage with maybe less than half tank full of gas for about 5 days without turning it on. I took it out to install the following. Radiator fan, rear brake pads and rotors. Now right after this happened we took it for a test drive on the freeway and then bam! The throttle felt a little weird and we got the message. Now it keeps popping up.
What do you guys suggest I tackle on first. The radiator fan I bought is a aftermarket but it's designed to replace the most current radiator fan BMW suggested to replace.
Old 10-11-2017, 07:38 PM
ksuderman ksuderman is offline
Mein Auto: M340i
Yes, a "drivetrain malfunction" can mean almost anything; so I would suggest that the first thing to do is to take the car to someone that can read the error codes. I had this warning pop up on my 2013 335i and the dealer simply reset the code and updated the firmware. Never had a problem again. Your mileage may vary.
[Edit] P.S. it doesn't sound like anything you did could have caused this as you did nothing to the drivetrain. You may have "tripped" some sensor, but I suspect it's just coincidence.
Old 10-11-2017, 08:27 PM
True. Thanks for the response. My friend scanned it for codes and nothing pops up. Filled the tank with new gas and it hasn't popped up just yet.
Old 10-12-2017, 06:04 AM
Damn it. I jinxed it... it popped up again while the car was idle..
Old 10-12-2017, 06:31 PM
jcf27 jcf27 is offline
Mein Auto: 325-i
You are not alone. It happened to me too over the past weekend, in CPO 2015 328xi with 29K miles. I was going at high speed in the highway when I started to feel the car shaking when I pressed on the gas and not being able to accelerate. The issue cleared overnight, however, I took it to the dealership as it is still under warranty. I attached a copy of the work done. So far, no problems.
--J
Old 10-12-2017, 08:48 PM
Oh **** no... I don't have any warranty what so ever to cover that. But I did drop it off at the dealership.
Old 10-17-2017, 11:51 AM
Welp.. the dealership gave me a call. "Updated your firmware and the messages still pops up". "We can replace your fan for about $900". I said no thanks just give me my car back and I'll fix it myself. I guess what I'm going to do now is Put the old DNA motor in the the new fan shroud.
The reason I replaced it lastime was because the old fan had broken fins and the shroud was broken to.
Old 10-18-2017, 07:50 AM
2015msport 2015msport is offline
Mein Auto: 2015 328xi Msport
Had this happen a few months back, dealership replaced my spark plugs at 24K under warranty.
No problems since.
Old 10-18-2017, 08:10 AM
JagerPgh JagerPgh is offline
Send a message via ICQ to JagerPgh
Mein Auto: 2013 328i M Sport
I had this happen to my 2013 328i shortly after I bought it CPO at the end of 2015. Dealership updated the firmware and the condition hasn't repeated itself (knock-wooed) since. Sorry that yours doesn't look like it will be as easy a fix. Strange though, I don't see how a fan could be causing the issue or how the dealer isn't finding any fault codes. Good luck!!
Old 11-04-2017, 04:05 AM
Update. So turns out it definitely was the aftermarket radiator fan. I replaced it with a original fan and no problems. I've been driving it for over a week now.
Old 05-02-2019, 02:38 AM
McFaded328i McFaded328i is offline
Mein Auto:
2012 328i SPORT MANUAL TWIN POWER TURBO
Alright so I always drive in sport mode even in town because it's the bomb and I've only owned the car for 4 months bought it at a private car dealership paid for the extended warranty 90,000km or 1year . The other day I had the drivetrain malfunction light come on and right before that i noticed that around 2500 , 3000rpms the car would hesitate on accelerating for a second or two then get going on. It's hasn't Happened in 1st or 2nd gear yet ....it's 3rd ,4th , 5th , and 6th that it occurs and it's always around 2500rpms . So I decided to bring it in for a diagnosis at my local BMW dealership. I waited a week just got it back today he is saying that the engine light is due to a worn out clutch ..? First off I bought the car at 126,000km and now it's at 136,000 . But this still makes no sense to me how could my clutch be the reasoning behind my acceleration loss .Ive always used atleast 91 octane every gas up I treat it better then I do myself .. It's happening when I'm giving it gas not shifting .yes I do like to drive quick and take off quick but I don't beat it.and my clutch feels fine to me .. they quoted me at 3200$ to 3700$ and also told me my warranty doesn't cover the clutch . But my paperwork states otherwise but they will only pay for 2500$ for a part to be fixed with a 250$ deductible.. I'm just lost and am hoping they are completely wrong and it's something else wrong with it.. I love the car too much to lose it but I cannot afford to fix that . Also did I mention my truck is now out of commision due to water in the engine ..anyways someone give me something to work with please !?
Old 05-02-2019, 08:11 AM
PK2348 PK2348 is online now
Mein Auto: 2018 340 xdrive
The symptoms do make it sound like the clutch is slipping. Generally clutch is considered consumable / maintenance item that might not be covered under warranty depending on terms and conditions you signed up for. How is your timing chain holding up?
Old 05-02-2019, 08:53 AM
namelessman namelessman is offline
Mein Auto: bimmer
Prior 4-yr/50k-year free maintenance(that OP's 2012 had, and already expired) did include free brakes and clutches, but free maintenance has since been demoted to 3-yr/36k-mile without brake and clutch.
BTW, my MY13 TC seems to be OK, it has its shiny patches but no whining yet, but 7-yr/70k-mile coverage will expire this Oct, so ....
Is your TC holding up OK?
Old 05-02-2019, 08:59 AM
Don't know, don't care. It's a leased 340
Old 05-02-2019, 09:51 AM
Mein Auto: bimmer
340i B58 TC job will be tough, it is back of engine, so any work is engine out! Same with B46/B48 I4. It probably is wise to just lease cars with those engines.
Old 05-08-2019, 02:08 PM
jwalz1 jwalz1 is offline
Mein Auto: 2014 328xi
How many miles?
I have no shiny patches on a 2014, but only 45k.
2014 328ix
2014 Porsche Cayman S
Old 05-14-2019, 09:40 AM
oe1891 oe1891 is offline
Mein Auto:
In 2016, I purchased my certified vehicle from Hendrick BMW, Charlotte, NC. I currently have 102,000 miles!!! I received the current error. I have had my vehicle serviced with BMW since purchasing it. Since I live in Durham the service has been conducted by Durham of Southpoint (Durham, NC). Two months after purchasing my certified vehicle, the technician at Durham of Southpoint indicated I had aftermarket brakes on my vehicle. According to the service manager at the time that diagnosis was an error. But since then it's been error after error. For example, I purchased new tires from Durham of Southpoint 2 months ago and they told me this recent visit that I needed new tires. When I brought this to their attention they removed it from the report. Also, for some reason corporate nor Durham has my complete service history.
I don't have an extended warranty. Frankly I didn't think such a problem would occur at 100k miles. Now that I received this Drivetrain Malfunction error, I'm being told that I need a new transmission!!!! A new transmission for a 2014 vehicle with only 102,000 miles, a vehicle that has a complete service history with this location since purchase, AND BMW of Southpoint says that it will cost $12,000.00!!!! Further, I have come to find out that this error code is a reoccurring issue with BMW, specifically with 3-series, 535i and X-3/X-5. Even though this is a common issue there are no recalls for this issue.
This is very alarming and disappointing.
Sent from my iPhone
