AC performance vs prior generation - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 G05 (2018 - Current)
G05 BMW X5 produced between 2018 to Current. Discuss the G05 X5 with other BMW owners here.
Old 07-13-2019, 10:57 AM
tj40371 tj40371 is offline
Mein Auto: 2015 435i 8AT MPPK MPE
It seemed to be a pretty common issue with the 14-18s having weak AC performance especially in hot climates such as Texas and Arizona. Does anyone know if the G05’s perform any better?
Old 07-13-2019, 12:18 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
I believe that the AC capacity tests and acceptance criteria are identical. www.NewTIS.info.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 07-13-2019, 05:11 PM
TheTurtleBoy TheTurtleBoy is online now
Mein Auto: 2019 X5 40i
The air conditioner cools extremely well. If you adjust the settings correctly it will freeze you out in no time. I have not seen anyone here or on the other forum complain about performance once they understand how to adjust the air flow temp.
Old 07-14-2019, 03:04 PM
Schnee38 Schnee38 is offline
Mein Auto: 2018 X3 M40i
My '15 F15 was pretty cold once set correctly too. I think many people didn't realize you can adjust fan speed separately while still keeping temp in AUTO mode.
Sent from my iPad using Bimmerfest
2018 X3 M40i
2017 Audi S6 (sold)
2016 Infiniti QX50 (husband's commuter)
2015 X5 xDrive35i (sold)
2015 X3 xDrive28i (sold)
Old 07-14-2019, 03:34 PM
Nuclear engineer
I did not realize that even having studied IHKA closely. In the only technical description of IHKA from BMW that I have ever found, I find this ...
“Air Flow Control/Blower Speed Control
Air flow control is dependent on the following settings and parameters. Blower control automatic mode If automatic mode has been activated in the IHKA control unit, the blower speed is controlled in accordance with a characteristic map depending on the required nominal temperature and the interior and ambient temperature. The relevant automatic blower control is switched off by operating one of the blower buttons of the IHKA.”
I thought that meant that if one selected blower speed up / down then AUTO is disabled. I’ll have to check when next I remember while driving.
When I want to vary the apparent AC ‘power’ then I toggle AUTO through characteristic maps Gentle, Moderate and Intensive, but the AUTO mode lighted button remains lighted.
Old 07-14-2019, 07:59 PM
Even more importantly many folks don't know that they can/need to adjust the temperature of the air coming through the vents to make it colder. Without doing that the air coming out will not be as cold as it can be.
Old 07-15-2019, 12:36 PM
omaralt omaralt is offline
Mein Auto: 2013 550i
i thought my 19 x5 ac was weak.. then i found out that red/blue dial is now buried in the climate control menu and it's set in the middle by default. you have to move it toward the blue area and it quickly freezes you
i will say i absolutely hate the temperature buttons. i wish they still had the rotary knob
2014 BMW 435i M-sport, BSM/Coral 6spd
2013 BMW 550i M-sport, Alpine white/Cinnamon (retired)
2012 BMW 535i M-sport (retired)
Old 07-20-2019, 08:14 AM
cjrizzo cjrizzo is offline
Mein Auto: '13 528i, '11 335i Conv
I have had a great experience with my AC in the new model vs my '15. Very strong performance in the deep summer North Carolina heat.
Old 09-11-2019, 08:52 PM
Milam Milam is offline
Mein Auto: 2017 BMW i3
I have a 2018 X5 Diesel.
We live in Oklahoma.
How do you get the airconditioning to cool properly?
Our i3 electric does a much better job.
Our Honda CNG with automatic temperature control, does a better job.
Even out 2002 Suburban does a better job. We leave that at the Buena Vista, Colorado airport. Even our Cirrus SR22 TN has better airconditioning.
Is there a software update?
Is there a secret setting?
Sometimes it works great, then falls off.
Most of the time, it is just plain lethargic.
I have the fan speed set to high.
I have the rear airconditioning set to off.
I have the blue knobs showing.
Other than that, the Diesel X5 is great.
Well, except for the Blind Spot Detector.
Any help would be very helpful and appreciated.
The dealer says that is it working properly.
They loaned us an X3, while they looked at our X5.
The 2019 X3 air-conditioner worked great.
Somethimes, ours works well. Then falls off a cliff.
Sometimes the heat comes on in the middle of the Summer.
Old 09-13-2019, 12:22 AM
jadnashuanh jadnashuanh is offline
Mein Auto: 535ix-drive GT; i3 BEV
If you want the dash vents to blow colder air, make sure you adjust the knobs accordingly. Adjusting the fan control manually will still allow it to keep the auto temperature, just not fully control the fan speed.
Jim DeBruycker
Old 09-13-2019, 10:20 AM
Thank you
Is there a coding change I could make on the 2008 X5 Diesel?
I have the equipment,
I have never coded the X5.
Can we change the programming on the airconditioning for more comfortable levels?
Thanks,
/s/ Tom Milam, Jr.
Old 10-09-2019, 07:06 AM
TXPearl's Avatar
TXPearl TXPearl is offline
Mein Auto: 2020 X5 M50i
The issue with the prior generation AC seems to be a programming/sensor issue. When the vehicle has been sitting in the sun, the system is pathetically slow to get the AC going to full cool upon startup.
Old 10-09-2019, 07:27 AM
Nuclear engineer
BMW IHKA compressor and evaporator are by default ALWAYS FULLY LOADED, cooling as hard as they can. UNLESS YOU have diddled with the buttons.
Old 10-09-2019, 09:04 AM
TXPearl's Avatar
Negative on diddling. Fully automatic. Fan set to highest auto setting.
Not sure what "ALWAYS FULLY LOADED, cooling as hard as they can" means in real life situations. Obviously, the system isn't always cooling as hard as it can, e.g. in cool weather.
And the whole "Max AC" button is another quirk.
Old 10-09-2019, 09:16 AM
Nuclear engineer
Obviously I did not say the system is cooling as hard as it can, only the compressor and evaporator.
BMW IHKA is a hot water temperature controlled system with engine coolant radiator(s) downstream of the evaporator. Cabin temperature is controlled by throttling hot water flow to the radiator(s) by the Hot-water Control Valve(s). OBVIOUSLY even in cool weather. The first function of the IHKA is humidity control for the many electronics modules obviously.
On my IHKA manual control of blower speed defeats AUTO, as does MAX.
I have posted the PDF of IHKA technical description many times; of course BMW designed a unique system for YOUR model / car.
Old 10-09-2019, 10:42 AM
Nuclear engineer
Cold Start Interlock
The cold start interlock prevents the customer from being subjected to unpleasantly cold
air when the engine starts and the engine temperature is cold.
The front ventilation and footwell flaps are closed.
The rear footwell flaps and the rear air blending flaps are also closed.
When the heating system heater core reaches the temperature level of the selected
specified value, the air flap controllers are switched to automatic mode
Old 10-09-2019, 10:50 AM
TXPearl's Avatar
Cold Start Interlock sounds like a heating feature that wouldn't affect cooling function. No need to wait for heater core warmup to cool vehicle.
