Please Help With DTC codes - Bimmerfest - BMW Forums
Old 12-06-2019, 12:03 AM
Cstewart541 Cstewart541 is offline
Mein Auto:
New here.. Just purchased a 2008 750li.. Have run into some issues and not sure where to start. I have some DTC codes that I am unable to find what they mean. Can someone please help me out .
ID:	874581   Click image for larger version
Old 12-06-2019, 02:53 PM
JCMech JCMech is offline
Mein Auto: F10|E66|E38|E34
Undervoltage and communication issues between the Kombi and other modules.
What are the symptoms?
Old 12-08-2019, 12:01 AM
Mein Auto:
It just goes into a reduced engine power mode. It won't accelerate like normal. Also after replacing battery due to the old one not holding a charge. This new one does not hold a charge.
Old 12-10-2019, 12:25 PM
How's the output voltage from the alternator?
Old 12-10-2019, 01:49 PM
Mein Auto:
At 14volts..
Old 12-13-2019, 09:29 AM
Can you update your profile and add your location?
If you are in a cold location, then with a weak battery the voltage should be around 14.8 - 15. 14 would suggest a faulty alternator.
Is this reading from the engine bay or the battery at the rear?
Can you scan the car with INPA or ISTA and let us know the error codes?
What does the cluster shows when you experience the issue.
Ideally you can do a video from key in, start then drive and what it shows on your cluster.
Old 12-13-2019, 09:33 AM
Doug Huffman's Avatar
Nuclear engineer
https://bmwfault.codes/
